(MESH)Add more relaying node in mesh network, There is a great probability of failure in communication.
Board: custom board; Mesh SDK: V1.0.0; Softdevice: S132_5.0.0; IDE: SEGGER Embedded; BLE: nrf52832
When I test the example “Interactive PyACI”, I need one node(A) send message to  another node(B) by relay node(C、D、E).
And for solving the limit of server device quantity, I change this define "#define DSM_DEVICE_MAX   (10)" in nrf_mesh_config_app.h.
1.One relay node(A-->C-->B): the rate of packet loss is 4%.
2.Two relay node(A-->C-->D-->B): the rate of packet loss is 8%.
3.Three relay node(A-->C-->D-->E-->B): the rate of packet loss is 52%.
//Node A is in range of node C, node C is in range of node D, node D is in range of node E, node E is in range of node B, but node B is not in range of node A.
so, the rate of packet loss has a precipitous decline,i think that is unnomrol.
Is there any place to change for add more devices in mesh network?
And  when adding three relay node between node A and B, There is a great probability of failure in relay node, for making they relay the message countine we must reboot the relay node.
  • Hello Beike,
    Did you try to play with network and relay retransmission parameters? Also what TTL are you using?
  • Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    /** Device company identifier. */
    #define DEVICE_COMPANY_ID (ACCESS_COMPANY_ID_NONE)
    /** Device product identifier*/
    #define DEVICE_PRODUCT_ID (0x0000)
    /** Device version identifier */
    #define DEVICE_VERSION_ID (0x0000)
    /** Supported features of the device. @see config_feature_bit_t */
    #define DEVICE_FEATURES (CONFIG_FEATURE_RELAY_BIT)
    /** @} end of DEVICE_CONFIG */
    * @defgroup APP_ACCESS_CONFIG Access layer configuration
    * The default TTL value for the node.
    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    This is my nrf_mesh_config_app.h , and if I want to add 6 nodes in a subnet, how can I modify the configuration.
    It seems that it might be some poor link-quality. It is hard to say what is causing this issue, but do you have big distances between the nodes? The first scenario:
    seems to be the same as what we see, but something weird is happening between the second and third scenario. There is no reason for this to happen in the mesh code. See that the TTL-value is high enough in your packet, and that your nodes aren' too far apart. The mesh is more vulnerable for noise, since the packets are ACK-ed on end-to-end basis instead of per link
