node cannot receive message
I use access_model_pulish to send group message by a server, and make other servers listen. the message can go through, but after 5~30 mins, one of the receiver server cannot receive the message any more. message sending are controlled by a timer which send one message out every 100ms. the code is based on the light_switch example from mesh v1.0.0.  I post the code here, if any one knows what's going on and why it stop listening, please help. thanks.
/* Copyright (c) 2010 - 2017, Nordic Semiconductor ASA
 * All rights reserved.
 * list of conditions and the following disclaimer.
#include <stdint.h>
#include <string.h>
/* HAL */
#include "nrf.h"
#include "boards.h"
#include "nrf_mesh_sdk.h"
#include "nrf_delay.h"
#include "simple_hal.h"
/* Core */
#include "nrf_mesh.h"
#include "nrf_mesh_events.h"
#include "log.h"
#include "access.h"
#include "access_config.h"
#include "device_state_manager.h"
#include "nrf_mesh_node_config.h"
#include "simple_on_off_server.h"
#include "simple_on_off_common.h"
#include "light_switch_example_common.h"
#include "test_config.h"
#include "uart.h"
#include "test_timer.h"
 * Definitions
#define GROUP_ADDRESS (0xCAFE)
 * Static data
static simple_on_off_server_t m_server;
/* Forward declaration */
static bool get_cb(const simple_on_off_server_t * p_server);
static bool set_cb(const simple_on_off_server_t * p_server, bool value);
static dsm_handle_t m_central_handle;
extern uint8_t dataready;
extern char cmd_buf[128];
typedef struct {
    bool active;
    uint16_t count;
} timer_ctrl_t;
timer_ctrl_t test_ctrl_timer = { .active = false, .count = 0 };
 * Static utility functions
 uint32_t address_set(uint16_t addr) {
    uint32_t status = 0xFF;
    ERROR_CHECK(dsm_address_publish_add(addr, &m_central_handle));
    status = access_model_publish_address_set(m_server.model_handle, m_central_handle);
    return status;
static void configuration_setup(void * p_unused)
    m_server.get_cb = get_cb;
    m_server.set_cb = set_cb;
    ERROR_CHECK(simple_on_off_server_init(&m_server, 0));
    ERROR_CHECK(access_model_subscription_list_alloc(m_server.model_handle));
static void provisioning_complete(void * p_unused)
    uart_writef(DEBUG_PRINT, "Successfully provisioned\r\n");
    nrf_gpio_pin_set(RGB_LED_RED);
 * Simple OnOff Callbacks
    return true;
    nrf_gpio_pin_toggle(RGB_LED_GREEN);
    return value;
uint8_t test_message = 0;
void half_ms_tasks(void) {
    access_message_tx_t msg;
    static uint16_t count = 0;
    if (count % 2 == 0) {
        if (test_ctrl_timer.active == true) {
            test_ctrl_timer.count++;
            if (test_ctrl_timer.count >= 100) {
                test_ctrl_timer.count = 0;
                msg.opcode.opcode = SIMPLE_ON_OFF_OPCODE_SET;
                msg.opcode.company_id = ACCESS_COMPANY_ID_NORDIC;
                msg.p_buffer = &test_message;
                msg.length = sizeof(uint8_t);
                access_model_publish(m_server.model_handle, &msg);
                nrf_gpio_pin_toggle(RGB_LED_RED);
    count++;
    if (count >= 2000) count = 0;
void input_handler(void) {
    if (dataready) {
        switch (cmd_buf[0]) {
            case 'S':
                uart_writef(DEBUG_PRINT, "Start sending message\r\n");
                test_ctrl_timer.active = true;
                address_set(GROUP_ADDRESS);
    static const uint8_t static_auth_data[NRF_MESH_KEY_SIZE] = STATIC_AUTH_DATA;
    static nrf_mesh_node_config_params_t config_params =
        {.prov_caps = NRF_MESH_PROV_OOB_CAPS_DEFAULT(ACCESS_ELEMENT_COUNT)};
    config_params.p_static_data = static_auth_data;
    config_params.complete_callback = provisioning_complete;
    config_params.setup_callback = configuration_setup;
    config_params.irq_priority = NRF_MESH_IRQ_PRIORITY_LOWEST;
    /*clock settings for ivani board*/
    config_params.lf_clk_cfg.source        = NRF_CLOCK_LF_SRC_RC;
    config_params.lf_clk_cfg.rc_ctiv       = 16;
    config_params.lf_clk_cfg.rc_temp_ctiv  = 2;
    config_params.lf_clk_cfg.accuracy = NRF_CLOCK_LF_ACCURACY_20_PPM;
    uart_init();
    timer_init(half_ms_tasks);
    nrf_gpio_cfg_output(RGB_LED_RED);
    nrf_gpio_cfg_output(RGB_LED_GREEN);
    nrf_gpio_cfg_output(RGB_LED_BLUE);
    nrf_gpio_pin_clear(RGB_LED_RED);
    nrf_gpio_pin_set(RGB_LED_GREEN);
    nrf_gpio_pin_set(RGB_LED_BLUE);
    ERROR_CHECK(nrf_mesh_node_config(&config_params));
    while (true) {
        input_handler();
        flush_uart_buffer();
  • A similar test was run to be even more similar to the light_switch example.
    • Server code was only modified to use different pins for our board and to toggle an LED when they receive a group message.
    • Client code was modified to
      • Have a timer that ticks every half ms
      • Have a divided down variant that ticks every 100ms
      • When 100ms timer ticks
        • Toggle an LED
        • Send a group message using access_model_publish (this is doing the same thing as simple_on_off_client_set_unreliable in the example)
    Doing this we see client and 3 servers all blink every 100ms initially (as expected).
    After some time, which can vary, we see a server stop blinking.
    Eventually the other servers also stop blinking.
    This is still in line with our earlier findings that servers are not reliably receiving messages for a large volume of messages over time.
    I suspect that the issue might be that you are calling the mesh from different IRQ levels. I suggest you to take a look at this to start with. On line 179 in your code, you set the mesh IRQ priority to LOWEST, you have to keep the code consistent and see to that all of the code are on the same level. You have two functions that is being called in your main-loop that ends up calling the mesh, which is something that breaks this. You also have to check that your timer-callback comes back in LOWEST.
  • Yes, all the timer and uart things are under priority 7, which is the lowest of mesh
  • Do you get any errors returns from the access in the client? Do you see the mesh-messages on the air if you scan with nRF Connect app or a sniffer? Does the device crash, or does it stop sending? Do you have persistent storage enabled?
  • Hi, given that the wording is almost exactly the same, did you work with Edvin on case 200832? We've already responded there about this. Here it is for convenience:
    • No error is returned.
    • Mesh messages are still being sent. This is known because it was tried with 1 client and 3 servers. The servers don't all stop receiving at once, rather each one fails on its own after some time.
      • FWIW, we have seen 2 failure modes:
        • Radio doesn't appear to receive, but UART still works
        • Radio doesn't appear to receive, UART also unresponsive
    • No persistent storage is used.
