We have an application built using sdk10 and sd110 on a nRF51822 chip using Segger Embedded Studio. The application works but it takes to long to start.
We have bootloader + application + sd!
/**@brief Function for application main entry.
int main(void) {
uint32_t err_code;
NRF_POWER->RESET = 1;
// Initialize.
app_timer_init();
app_bluetooth_ble_stack_init();
app_memory_init(); //External Memory init (SPI)
bool first_init = app_memory_system_on_first_time();
app_bluetooth_device_manager_init(first_init);
app_bluetooth_gap_params_init();
app_bluetooth_advertising_init();
app_bluetooth_services_init();
app_bluetooth_conn_params_init();
// Start execution.
app_bluetooth_advertising_start();
app_display_init(); //Initialize 8bit interface TFT display
app_battery_init(); //Battery monitor init (ADC)
app_touch_init(); //Touch sensor init (I2C)
app_heart_sensor_init(); //HRS init (I2C)
app_motor_init(); //Vibration Motor init (PWM)
#ifdef DEBUG
app_notification_init();
app_ui_flow_start(IDLE_VERTICE); //Idle screen set
#else
if (first_init)
app_notification_init_secure();
if (first_init)
app_ui_flow_start(FIRST_TIME_VERTICE); //First time screen set
app_motor_notify(INIT_MODE); //init vibration set (PWM init)
// Enter main loop.
for (;;) {
power_manage();
As we can see on my main() after all init sequence the vibration motor vibrates two times and goes off. The motor uses PWM and the Display uses a 8bit interface (nrf_gpio...)
The problem is that after the final vibration the application takes few seconds to realy work. If I wait few seconds (around 5 seconds) every thing works fine. Touch (I2C with a RDY pin) only works after few seconds.
If I request a screen just after the app_motor_notify(INIT_MODE); (see the code bellow), the screen function works but the motor does not vibrate.
app_ui_flow_start(MAIN_SCREEN_VERTICE);
Does anyone have an idea about how to fix this slow initialization?
