Can anyone explain this SPI SDK example sdk_config.h? Sloppy code?
Looking at
\NORDIC\SDK\examples\peripheral\spi\pca10040\blank\config\sdk_config.h
These lines repeat over and over. Was there a reason for this? The first time the infdef runs it'll define a value, then the rest will get ignored. Is this just a sloppy copy and paste job - or is there something else going on here?
#ifndef SPI_MISO_PIN
#define SPI_MISO_PIN 28
#define SPI_MISO_PIN 31
<occurs a total of 9 times in the same file>
  • hahah! That's not all yet man! You'll need more defines to get it to compile.
  • Their SPI example built fine for me. It's just a terrible header for an example people are supposed to use.
  • Their example compiles for sure since it already have the sdk_config.h with all defines set for it.  If you create a new project from scratch or change to a different SPI number.  Then... see all the defines bellow for enabling SPI. Just enable SPI_ENABLED is not enough to compile you have to enable SPI number for the code to compile.  Sloppy code, you bet.  Every single source file in the SDK has that kind of define guarding it from compilation.  So just adding the source to your project is not enough to get it compiles.  Imagine that sdk_config.h has over 3000 lines!!!
