hi ;
now after i maked a successful connection between smart phone and nrf51822 and i could change the state of gpio pin 20 i find a new problem
i want my pin is still an state high until 3 secondes after that, it change its state to low, when i aded a timer to my code something weird happened, the adevrtising stopped i can't find my ble with my smartphon and the code don't work any more until i elemeiminate start_timer () (comment it)
i'm using sdk9 nrf51822 pca 20006 with s110
/* Copyright (c) 2014 Nordic Semiconductor. All Rights Reserved.
* The information contained herein is property of Nordic Semiconductor ASA.
* Terms and conditions of usage are described in detail in NORDIC
* SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
* Licensees are granted free, non-transferable use of the information. NO
* WARRANTY of ANY KIND is provided. This heading must NOT be removed from
* the file.
/** @file
* @brief BLE Services, a beginner's tutorial project main file.
* This example is meant to be used togheter with the tutorial "BLE Services, a beginner's tutorial"
* found at https://devzone.nordicsemi.com/tutorials/8/ble-services-a-beginners-tutorial/.
* The purpose of this tutorial is to get you started with the basics of the nRF51x22 and Bluetooth Low Energy (BLE).
* More specifically this tutorial will go through the bare minimum of steps to get your first services
* up and running. The tutorial is fairly superficial and is meant to be a hands-on introduction to BLE services.
* It is intended to be a natural continuation of the tutorial "BLE Advertising, a beginner's tutorial".
* It can easily be used as a starting point for creating a new application, the comments identified
* with 'OUR_JOB' indicates where the work described in the tutorial needs to be done.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "nrf51_bitfields.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "boards.h"
#include "softdevice_handler.h"
#include "app_timer.h"
#include "device_manager.h"
#include "pstorage.h"
#include "app_trace.h"
#include "bsp.h"
#include "bsp_btn_ble.h"
#include "our_service.h"
#include "SEGGER_RTT.h"
#include "msgs.h"
#include "nrf_drv_gpiote.h"
#define IS_SRVC_CHANGED_CHARACT_PRESENT 1 /**< Include or not the service_changed characteristic. if not enabled, the server's database cannot be changed for the lifetime of the device*/
#define DEVICE_NAME "OhmaneService" /**< Name of device. Will be included in the advertising data. */
#define APP_ADV_INTERVAL 50 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 25 ms). */
#define APP_ADV_TIMEOUT_IN_SECONDS 180 /**< The advertising timeout in units of seconds. */
#define APP_TIMER_PRESCALER 0 /**< Value of the RTC1 PRESCALER register. */
#define APP_TIMER_MAX_TIMERS (6+BSP_APP_TIMERS_NUMBER) /**< Maximum number of simultaneously created timers. */
#define APP_TIMER_OP_QUEUE_SIZE 4 /**< Size of timer operation queues. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(100, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.1 seconds). */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(200, UNIT_1_25_MS) /**< Maximum acceptable connection interval (0.2 second). */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER)/**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND 1 /**< Perform bonding. */
#define SEC_PARAM_MITM 0 /**< Man In The Middle protection not required. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */
#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
static dm_application_instance_t m_app_handle; /**< Application identifier allocated by device manager */
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
int h=0;
// OUR_JOB: Declare a ble_os_t service structure for our application
// FROM_SERVICE_TUTORIAL: Declare a service structure for our application
ble_os_t m_our_service;
//int i=01;
// OUR_JOB: Step 3.G, Declare an app_timer id variable and define our timer interval and define a timer interval
static ble_uuid_t m_adv_uuids[] = {{BLE_UUID_OUR_SERVICE_UUID, BLE_UUID_TYPE_VENDOR_BEGIN}};
// OUR_JOB: For advertising, declare a ble_uuid_t variable holding our service UUID
/**@brief Callback function for asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] file_name File name of the failing ASSERT call.
#define LED_20 9 //etteint
#define LED_11 5 //allumer
#define PIR 20
#ifdef BSP_BUTTON_0
#define PIN_IN 5
#ifndef PIN_IN
#error "Please indicate input pin"
#ifdef BSP_LED_0
#define PIN_OUT 20
#ifndef PIN_OUT
#error "Please indicate output pin"
ce programme permet de alimenter une led relier � un relay par les deux sortie pin 5 et pin 11 en se basant sur l'information r�cup�r�e de PIR
qui branch� a l'entr�e pin 20.
la dur�e de l"allimentation est 1 seconde la dur�e d'excitation desz deux pin 5 et 11 est une seconde
* @brief Function for application main entry.
int i=0;
int ii=0;
int iii=0;
int j=0;
bool temoin= true;
void start_timer(void)
NRF_TIMER2->MODE = TIMER_MODE_MODE_Timer; // Set the timer in Counter Mode
NRF_TIMER2->TASKS_CLEAR = 1; // clear the task first to be usable for later
NRF_TIMER2->PRESCALER = 4; //Set prescaler. Higher number gives slower timer. Prescaler = 0 gives 16MHz timer
NRF_TIMER2->BITMODE = TIMER_BITMODE_BITMODE_16Bit; //Set counter to 16 bit resolution
NRF_TIMER2->CC[0] = 1000; //Set value for TIMER2 compare register 0
NRF_TIMER2->CC[1] = 1000;
NRF_TIMER2->CC[2] = 1000; //Set value for TIMER2 compare register 1
// Enable interrupt on Timer 2, both for CC[0] and CC[1] compare match events
NRF_TIMER2->INTENSET = (TIMER_INTENSET_COMPARE0_Enabled << TIMER_INTENSET_COMPARE0_Pos) | (TIMER_INTENSET_COMPARE1_Enabled << TIMER_INTENSET_COMPARE1_Pos);
NVIC_EnableIRQ(TIMER2_IRQn);
NRF_TIMER2->TASKS_START = 1; // Start TIMER2
void TIMER2_IRQHandler(void)
if ((NRF_TIMER2->EVENTS_COMPARE[0] != 0) && ((NRF_TIMER2->INTENSET & TIMER_INTENSET_COMPARE0_Msk) != 0))
NRF_TIMER2->EVENTS_COMPARE[0] = 0;
i+=1;
if(i==45)
i=0;
nrf_gpio_pin_clear(20);
NRF_TIMER2->TASKS_STOP = 1; //stoptimer2
void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
nrf_drv_gpiote_out_toggle(PIN_OUT);
* @brief Function for configuring: PIN_IN pin for input, PIN_OUT pin for output,
* and configures GPIOTE to give an interrupt on pin change.
static void gpio_init(void)
ret_code_t err_code;
//config.sense = NRF_GPIOTE_POLARITY_LOTOHI;
nrf_drv_gpiote_out_config_t out_config = GPIOTE_CONFIG_OUT_SIMPLE(false);
err_code = nrf_drv_gpiote_out_init(PIN_OUT, &out_config);
nrf_drv_gpiote_in_config_t config;
memset(&config, 0, sizeof(nrf_drv_gpiote_in_config_t));
// config.sense = NRF_GPIOTE_POLARITY_HITOLO;
//config.pull = NRF_GPIO_PIN_PULLUP;
// config.pull = GPIO_PIN_CNF_PULL_Disabled;
config.pull =GPIO_PIN_CNF_PULL_Pulldown;
config.hi_accuracy = false;
config.is_watcher = false;
nrf_drv_gpiote_in_init(PIR, &config, in_pin_handler);
nrf_drv_gpiote_in_event_enable(PIN_IN, true);
/**@brief Function for the Timer initialization.
* @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_MAX_TIMERS, APP_TIMER_OP_QUEUE_SIZE, false);
* @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
* device including the device name, appearance, and the preferred connection parameters.
uint32_t err_code;
ble_gap_conn_params_t gap_conn_params;
(const uint8_t *)DEVICE_NAME,
strlen(DEVICE_NAME));
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
// OUR_JOB: Add code to initialize the services used by the application.
//our_service_init(&m_our_service);
/**@brief Function for handling the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module which
* are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply
* setting the disconnect_on_fail config parameter, but instead we use the event
* handler mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
/* uint32_t err_code;
uint32_t err_code;
/**@brief Function for handling a Connection Parameters error.
* @param[in] nrf_error Error code containing information about what went wrong.
// APP_ERROR_HANDLER(nrf_error);
uint32_t err_code;
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
/**@brief Function for starting timers.
static void application_timers_start(void)
// Prepare wakeup buttons.
* @param[in] ble_adv_evt Advertising event.
uint32_t err_code;
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
/**@brief Function for handling the Application's BLE Stack events.
* @param[in] p_ble_evt Bluetooth stack event.
static void on_ble_evt(ble_evt_t * p_ble_evt)
uint32_t err_code;
case BLE_GAP_EVT_CONNECTED:
// No implementation needed.
/**@brief Function for dispatching a BLE stack event to all modules with a BLE stack event handler.
* @details This function is called from the BLE Stack event interrupt handler after a BLE stack
* event has been received.
static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
dm_ble_evt_handler(p_ble_evt);
ble_conn_params_on_ble_evt(p_ble_evt);
bsp_btn_ble_on_ble_evt(p_ble_evt);
ble_advertising_on_ble_evt(p_ble_evt);
ble_our_service_on_ble_evt(&m_our_service, p_ble_evt);
/**@brief Function for dispatching a system event to interested modules.
* @details This function is called from the System event interrupt handler after a system
* @param[in] sys_evt System stack event.
static void sys_evt_dispatch(uint32_t sys_evt)
/* pstorage_sys_event_handler(sys_evt);
ble_advertising_on_sys_evt(sys_evt);*/
uint32_t err_code;
// Initialize the SoftDevice handler module.
SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_XTAL_20_PPM, NULL);
#if defined(S110) || defined(S130)
// Enable BLE stack.
ble_enable_params_t ble_enable_params;
memset(&ble_enable_params, 0, sizeof(ble_enable_params));
#ifdef S130
ble_enable_params.gatts_enable_params.attr_tab_size = BLE_GATTS_ATTR_TAB_SIZE_DEFAULT;
ble_enable_params.gatts_enable_params.service_changed = IS_SRVC_CHANGED_CHARACT_PRESENT;
err_code = sd_ble_enable(&ble_enable_params);
// Register with the SoftDevice handler module for BLE events.
err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
* @param[in] event Event generated by button press.
uint32_t err_code;
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
case BSP_EVENT_WHITELIST_OFF:
err_code = ble_advertising_restart_without_whitelist();
/**@brief Function for handling the Device Manager events.
* @param[in] p_evt Data associated to the device manager event.
static uint32_t device_manager_evt_handler(dm_handle_t const * p_handle,
dm_event_t const * p_event,
ret_code_t event_result)
/* APP_ERROR_CHECK(event_result);
#ifdef BLE_DFU_APP_SUPPORT
if (p_event->event_id == DM_EVT_LINK_SECURED)
app_context_load(p_handle);
#endif // BLE_DFU_APP_SUPPORT
return NRF_SUCCESS;*/
return NRF_SUCCESS;
/**@brief Function for the Device Manager initialization.
* @param[in] erase_bonds Indicates whether bonding information should be cleared from
* persistent storage during initialization of the Device Manager.
static void device_manager_init(bool erase_bonds)
uint32_t err_code;
dm_init_param_t init_param = {.clear_persistent_data = erase_bonds};
dm_application_param_t register_param;
// Initialize persistent storage module.
err_code = pstorage_init();
err_code = dm_init(&init_param);
memset(®ister_param.sec_param, 0, sizeof(ble_gap_sec_params_t));
register_param.sec_param.bond = SEC_PARAM_BOND;
register_param.sec_param.mitm = SEC_PARAM_MITM;
register_param.sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
register_param.sec_param.oob = SEC_PARAM_OOB;
register_param.sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
register_param.sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
register_param.evt_handler = device_manager_evt_handler;
register_param.service_type = DM_PROTOCOL_CNTXT_GATT_SRVR_ID;
err_code = dm_register(&m_app_handle, ®ister_param);
uint32_t err_code;
ble_advdata_t advdata;
// Build advertising data struct to pass into ble_advertising_init().
memset(&advdata, 0, sizeof(advdata));
advdata.name_type = BLE_ADVDATA_FULL_NAME;
advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
ble_adv_modes_config_t options = {0};
options.ble_adv_fast_enabled = BLE_ADV_FAST_ENABLED;
options.ble_adv_fast_interval = APP_ADV_INTERVAL;
options.ble_adv_fast_timeout = APP_ADV_TIMEOUT_IN_SECONDS;
// OUR_JOB: Create a scan response packet and include the list of UUIDs
ble_advdata_t srdata;
memset(&srdata, 0, sizeof(srdata));
srdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
srdata.uuids_complete.p_uuids = m_adv_uuids;
err_code = ble_advertising_init(&advdata, &srdata, &options, on_adv_evt, NULL);
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
/* bsp_event_t startup_event;
uint32_t err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS,
APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
bsp_event_handler);
*p_erase_bonds = (startup_event == BSP_EVENT_CLEAR_BONDING_DATA);*/
bsp_event_handler);
/**@brief Function for the Power manager.
static void power_manage(void)
/* uint32_t err_code = sd_app_evt_wait();
APP_ERROR_CHECK(err_code);*/
/**@brief Function for application main entry.
uint32_t err_code;
bool erase_bonds;
// Initialize.
timers_init();
ble_stack_init();
device_manager_init(erase_bonds);
gap_params_init();
services_init();
advertising_init();
conn_params_init();
// Start execution.
application_timers_start();
err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
nrf_gpio_cfg_output(20);
services_init();
start_timer();
for (;;)
power_manage();
//nrf_gpio_pin_set(20);
if(returnei()==0)
start_timer();
else if(returnei()!=0)
#include <stdint.h>
#include <string.h>
#include "nrf_gpio.h"
volatile int iiii=2;
int returnei ()
return iiii;
static void on_ble_write(ble_os_t * p_our_service, ble_evt_t * p_ble_evt)
// Declare buffer variable to hold received data. The data can only be 32 bit long.
uint32_t data_buffer;
// Populate ble_gatts_value_t structure to hold received data and metadata.
ble_gatts_value_t rx_data;
rx_data.len = sizeof(uint32_t);
rx_data.offset = 0;
rx_data.p_value = (uint8_t*)&data_buffer;
// Check if write event is performed on our characteristic or the CCCD
if(p_ble_evt->evt.gatts_evt.params.write.handle == p_our_service->char_handles.value_handle)
//ii=0;
// Get data
sd_ble_gatts_value_get(p_our_service->conn_handle, p_our_service->char_handles.value_handle, &rx_data);
// Print handle and value
//printf("Value received on handle %#06x: %#010x\r\n", p_ble_evt->evt.gatts_evt.params.write.handle, data_buffer);
if(data_buffer == 0x00000002)
// printf("Notification enabled\r\n");
iiii=1;
else if(data_buffer == 0x00000000)
// printf("Notification disabled\r\n");
iiii=0;
else if(p_ble_evt->evt.gatts_evt.params.write.handle == p_our_service->char_handles.cccd_handle)
// Get data
// ii=0;
sd_ble_gatts_value_get(p_our_service->conn_handle, p_our_service->char_handles.cccd_handle, &rx_data);
// printf("Value received on handle %#06x: %#06x\r\n", p_ble_evt->evt.gatts_evt.params.write.handle, data_buffer);
if(data_buffer == 0x0001)
// ii=0;
else if(data_buffer == 0x0000)
// ii=1;
// ALREADY_DONE_FOR_YOU: Declaration of a function that will take care of some housekeeping of ble connections related to our service and characteristic
void ble_our_service_on_ble_evt(ble_os_t * p_our_service, ble_evt_t * p_ble_evt)
case BLE_GATTS_EVT_WRITE:
on_ble_write(p_our_service, p_ble_evt);
p_our_service->conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
p_our_service->conn_handle = BLE_CONN_HANDLE_INVALID;
/**@brief Function for adding our new characterstic to "Our service" that we initiated in the previous tutorial.
* @param[in] p_our_service Our Service structure.
static uint32_t our_char_add(ble_os_t * p_our_service)
uint32_t err_code = 0; // Variable to hold return codes from library and softdevice functions
ble_uuid_t char_uuid;
ble_uuid128_t base_uuid = BLE_UUID_OUR_BASE_UUID;
char_uuid.uuid = BLE_UUID_OUR_CHARACTERISTC_UUID;
sd_ble_uuid_vs_add(&base_uuid, &char_uuid.type);
ble_gatts_char_md_t char_md;
memset(&char_md, 0, sizeof(char_md));
char_md.char_props.read = 1;
char_md.char_props.write = 1;
ble_gatts_attr_md_t cccd_md;
memset(&cccd_md, 0, sizeof(cccd_md));
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm);
cccd_md.vloc = BLE_GATTS_VLOC_STACK;
char_md.p_cccd_md = &cccd_md;
char_md.char_props.notify = 1;
ble_gatts_attr_md_t attr_md;
memset(&attr_md, 0, sizeof(attr_md));
attr_md.vloc = BLE_GATTS_VLOC_STACK;
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.write_perm);
ble_gatts_attr_t attr_char_value;
memset(&attr_char_value, 0, sizeof(attr_char_value));
attr_char_value.p_uuid = &char_uuid;
attr_char_value.p_attr_md = &attr_md;
attr_char_value.max_len = 8;
attr_char_value.init_len = 8;
uint8_t value[8] = {0x12,0x34,0x56,0x78,0x12,0x34,0x56,0x78};
attr_char_value.p_value = value;
err_code = sd_ble_gatts_characteristic_add(p_our_service->service_handle,
&char_md,
&attr_char_value,
&p_our_service->char_handles);
return NRF_SUCCESS;
/**@brief Function for initiating our new service.
void our_service_init(ble_os_t * p_our_service)
uint32_t err_code; // Variable to hold return codes from library and softdevice functions
// FROM_SERVICE_TUTORIAL: Declare 16-bit service and 128-bit base UUIDs and add them to the BLE stack
ble_uuid_t service_uuid;
service_uuid.uuid = BLE_UUID_OUR_SERVICE_UUID;
err_code = sd_ble_uuid_vs_add(&base_uuid, &service_uuid.type);
// OUR_JOB: Step 3.B, Set our service connection handle to default value. I.e. an invalid handle since we are not yet in a connection.
// FROM_SERVICE_TUTORIAL: Add our service
err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY,
&service_uuid,
&p_our_service->service_handle);
// OUR_JOB: Call the function our_char_add() to add our new characteristic to the service.
our_char_add(p_our_service);
// ALREADY_DONE_FOR_YOU: Function to be called when updating characteristic value
void our_temperature_characteristic_update(ble_os_t *p_our_service, int32_t *temperature_value)
// OUR_JOB: Step 3.E, Update characteristic value
if (p_our_service->conn_handle != BLE_CONN_HANDLE_INVALID)
uint16_t len = 4;
ble_gatts_hvx_params_t hvx_params;
memset(&hvx_params, 0, sizeof(hvx_params));
hvx_params.handle = p_our_service->char_handles.value_handle;
hvx_params.type = BLE_GATT_HVX_NOTIFICATION;
hvx_params.offset = 0;
hvx_params.p_len = &len;
hvx_params.p_data = (uint8_t*)temperature_value;
sd_ble_gatts_hvx(p_our_service->conn_handle, &hvx_params);
