Eclipse ignores all breakpoints
Equipment: PCA10040 DK with SDK14
I'm currently having the same issue described in this post.
Essentially, I can program and build my project correctly in Eclipse, but I can't get the debugging console to work properly. I followed the Eclipse and GCC guide here and when I click on the debug icon, the debug perspective opens but the program never halts. Nothing happens really.
I've modified my makefile to have "-O0 -g3" for the optimizations and I've double checked that my debug settings are the same ones outlined in the Eclipse guide. This is the output from the JLinkGDBServer:
SEGGER J-Link GDB Server V6.22c Command Line Version
JLinkARM.dll V6.22c (DLL compiled Dec  8 2017 15:42:04)
Command line: -if swd -device NRF52832_xxaa -endian little -speed 1000 -port 2331 -swoport 2332 -telnetport 2333 -vd -ir -localhostonly 1 -singlerun -strict -timeout 0
-----GDB Server start settings-----
GDBInit file:                  none
GDB Server Listening port:     2331
SWO raw output listening port: 2332
Terminal I/O port:             2333
Accept remote connection:      localhost only
Generate logfile:              off
Verify download:               on
Init regs on start:            on
Silent mode:                   off
Single run mode:               on
Target connection timeout:     0 ms
------J-Link related settings------
J-Link Host interface:         USB
J-Link script:                 none
J-Link settings file:          none
------Target related settings------
Target device:                 NRF52832_xxaa
Target interface:              SWD
Target interface speed:        1000kHz
Target endian:                 little
Connecting to J-Link...
J-Link is connected.
Firmware: J-Link OB-SAM3U128-V2-NordicSemi compiled Jul 24 2017 17:30:12
Hardware: V1.00
S/N: 682707321
Checking target voltage...
Target voltage: 3.30 V
Listening on TCP/IP port 2331
Connecting to target...Connected to target
Waiting for GDB connection...Connected to 127.0.0.1
Reading all registers
Read 4 bytes @ address 0x00000000 (Data = 0x20000400)
Read 2 bytes @ address 0x00000000 (Data = 0x0400)
Received monitor command: speed 1000
Target interface speed set to 1000 kHz
Received monitor command: clrbp
Received monitor command: reset
Resetting target
Received monitor command: halt
Halting target CPU...
...Target halted (PC = 0x000008E8)
Received monitor command: regs
R0 = 00000000, R1 = 00000000, R2 = 00000000, R3 = 00000000
R4 = 00000000, R5 = 00000000, R6 = 00000000, R7 = 00000000
R8 = 00000000, R9 = 00000000, R10= 00000000, R11= 00000000
R12= 00000000, R13= 20000400, MSP= 20000400, PSP= 00000000
R14(LR) = FFFFFFFF, R15(PC) = 000008E8
XPSR 01000000, APSR 00000000, EPSR 01000000, IPSR 00000000
CFBP 00000000, CONTROL 00, FAULTMASK 00, BASEPRI 00, PRIMASK 00
Read 4 bytes @ address 0x000008E8 (Data = 0x47184B06)
Read 2 bytes @ address 0x000008E8 (Data = 0x4B06)
Received monitor command: speed auto
Select auto target interface speed (1000 kHz)
Received monitor command: flash breakpoints 1
Flash breakpoints enabled
Downloading 16016 bytes @ address 0x00023000 - Verified OK
Downloading 16048 bytes @ address 0x00026E90 - Verified OK
Downloading 16128 bytes @ address 0x0002AD40 - Verified OK
Downloading 5056 bytes @ address 0x0002EC40 - Verified OK
Downloading 16000 bytes @ address 0x00030000 - Verified OK
Downloading 16096 bytes @ address 0x00033E80 - Verified OK
Downloading 228 bytes @ address 0x00037D60 - Verified OK
Writing register (PC = 0x00034370)
Read 4 bytes @ address 0x00034370 (Data = 0x4A074906)
Read 2 bytes @ address 0x00034370 (Data = 0x4906)
Resetting target
Starting target CPU...
When I start the debug process, there is no initial halt when the debugger starts going through main and regardless of where I add breakpoints, the program never halts. I've also made sure that I'm programming both the application and the soft device. I'm not really sure where to go from here.
