nrF5 Command Line Tools dissappered
I’m facing a strange problem regarding  nrfjprog
I used it for many times without any problem
Now I’m preparing a VBNET app to program a flash sector of the nRF52832 and I decided to use it launched by a bat file which in turn is launched by the VBNET app
Here is the bat file code
set path=%path%;"%AppData%\Board_Code_Folder"
del %AppData%\Board_Code_Folder\outfile.hex
%AppData%\Board_Code_Folder\srec_cat  %AppData%\Board_Code_Folder\infile -binary -offset 0x2C000 -o %AppData%\Board_Code_Folder\outfile.hex -Intel
IF %errorlevel% EQU 1 GOTO out
set path=%path%;c:\Program Files (x86)\Nordic Semiconductor\nrf5x\bin\
nrfjprog --program %AppData%\Board_Code_Folder\outfile.hex  --sectorerase -f  NRF52
:out
 REM pause
 EXIT /B %ERRORLEVEL%
The file “nRF5x-Command-Line-Tools_9_7_2_Installer.exe” is launched by the setup file
I used inno setup installer and I can verify that the “Command-Line-Tools” is recalled and installed
PROBLEM
IN THE DIRECTORY “C:\ C:\Program Files (x86)\Nordic Semiconductor\nrf5x\bin”
the Nrfjprog.exe (previously it was there) DOES NOT APPEAR
Thus my BAT FILE FAILS where it calls :
I made many attempts uninstalling  the  nRF5x-Command-Line-Tools and reinstalling  it even manually
But the result is still the same
NO  TRACE OF NRFJPROG
ANY IDEA ?
Thanks
CAN YOU SEND IT APART OF THE INSTALLATION FILE ?
