gpio interrupt with ble
hi hi ;
i'm trying to control gpio pin 20 with my smart phone and with event at gpio pin 5 (when the state of the pin 5 changes the gpio pin 20 toggeles )
but my problem is when i add the function gpio_init() the ble stops working .
any help will be appreciated
i'm using nrf51822 s110 sdk 9 pca 20006
/* Copyright (c) 2014 Nordic Semiconductor. All Rights Reserved.
 * The information contained herein is property of Nordic Semiconductor ASA.
 * Terms and conditions of usage are described in detail in NORDIC
 * SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
 * Licensees are granted free, non-transferable use of the information. NO
 * WARRANTY of ANY KIND is provided. This heading must NOT be removed from
 * the file.
/** @file
 * @brief BLE Services, a beginner's tutorial project main file.
 * This example is meant to be used togheter with the tutorial "BLE Services, a beginner's tutorial"
 * found at https://devzone.nordicsemi.com/tutorials/8/ble-services-a-beginners-tutorial/.
 * The purpose of this tutorial is to get you started with the basics of the nRF51x22 and Bluetooth Low Energy (BLE).
 * More specifically this tutorial will go through the bare minimum of steps to get your first services
 * up and running. The tutorial is fairly superficial and is meant to be a hands-on introduction to BLE services.
 * It is intended to be a natural continuation of the tutorial "BLE Advertising, a beginner's tutorial".
 * It can easily be used as a starting point for creating a new application, the comments identified
 * with 'OUR_JOB' indicates where the work described in the tutorial needs to be done.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "nrf51_bitfields.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "boards.h"
#include "softdevice_handler.h"
#include "app_timer.h"
#include "device_manager.h"
#include "pstorage.h"
#include "app_trace.h"
#include "bsp.h"
#include "bsp_btn_ble.h"
#include "our_service.h"
#include "SEGGER_RTT.h"
#include "msgs.h"
#include "nrf_drv_gpiote.h"
#define IS_SRVC_CHANGED_CHARACT_PRESENT  1                                          /**< Include or not the service_changed characteristic. if not enabled, the server's database cannot be changed for the lifetime of the device*/
#define DEVICE_NAME                      "OhmaneService"                               /**< Name of device. Will be included in the advertising data. */
#define APP_ADV_INTERVAL                 50                                        /**< The advertising interval (in units of 0.625 ms. This value corresponds to 25 ms). */
#define APP_ADV_TIMEOUT_IN_SECONDS       180                                        /**< The advertising timeout in units of seconds. */
#define APP_TIMER_PRESCALER              0                                          /**< Value of the RTC1 PRESCALER register. */
#define APP_TIMER_MAX_TIMERS             (6+BSP_APP_TIMERS_NUMBER)                  /**< Maximum number of simultaneously created timers. */
#define APP_TIMER_OP_QUEUE_SIZE          4                                          /**< Size of timer operation queues. */
#define MIN_CONN_INTERVAL                MSEC_TO_UNITS(100, UNIT_1_25_MS)           /**< Minimum acceptable connection interval (0.1 seconds). */
#define MAX_CONN_INTERVAL                MSEC_TO_UNITS(200, UNIT_1_25_MS)           /**< Maximum acceptable connection interval (0.2 second). */
#define SLAVE_LATENCY                    0                                          /**< Slave latency. */
#define CONN_SUP_TIMEOUT                 MSEC_TO_UNITS(4000, UNIT_10_MS)            /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY    APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER)/**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT     3                                          /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND                   1                                          /**< Perform bonding. */
#define SEC_PARAM_MITM                   0                                          /**< Man In The Middle protection not required. */
#define SEC_PARAM_IO_CAPABILITIES        BLE_GAP_IO_CAPS_NONE                       /**< No I/O capabilities. */
#define SEC_PARAM_OOB                    0                                          /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE           7                                          /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE           16                                         /**< Maximum encryption key size. */
#define DEAD_BEEF                        0xDEADBEEF                                 /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
static dm_application_instance_t         m_app_handle;                               /**< Application identifier allocated by device manager */
static uint16_t                          m_conn_handle = BLE_CONN_HANDLE_INVALID;   /**< Handle of the current connection. */
int h=0;
// OUR_JOB: Declare a ble_os_t service structure for our application
// FROM_SERVICE_TUTORIAL: Declare a service structure for our application
ble_os_t m_our_service;
//int i=01;
// OUR_JOB: Step 3.G, Declare an app_timer id variable and define our timer interval and define a timer interval
static ble_uuid_t       m_adv_uuids[] = {{BLE_UUID_OUR_SERVICE_UUID, BLE_UUID_TYPE_VENDOR_BEGIN}};
// OUR_JOB: For advertising, declare a ble_uuid_t variable holding our service UUID
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in] line_num   Line number of the failing ASSERT call.
 * @param[in] file_name  File name of the failing ASSERT call.
#define LED_20 9          //etteint
#define LED_11 5        //allumer
#define PIR 20
#ifdef BSP_BUTTON_0
    #define PIN_IN 5
#ifndef PIN_IN
    #error "Please indicate input pin"
#ifdef BSP_LED_0
    #define PIN_OUT 20
#ifndef PIN_OUT
    #error "Please indicate output pin"
ce programme permet de alimenter une led relier � un relay par les deux sortie pin 5 et pin 11 en se basant sur l'information r�cup�r�e de PIR
qui branch� a l'entr�e pin 20.
la dur�e de l"allimentation est 1 seconde la dur�e d'excitation desz deux pin 5 et 11 est une seconde
 * @brief Function for application main entry.
 int i=0;
 int ii=0;
 int iii=0;
 int j=0;
 int time=6250;
 bool temoin= true;
/*void init_timer(void)
    NRF_TIMER0->TASKS_STOP = 1;
    // Create an Event-Task shortcut to clear TIMER0 on COMPARE[0] event
    NRF_TIMER0->MODE        = TIMER_MODE_MODE_Timer;
    NRF_TIMER0->BITMODE     = (TIMER_BITMODE_BITMODE_24Bit << TIMER_BITMODE_BITMODE_Pos);
    NRF_TIMER0->PRESCALER   = 4;  // 1us resolution
    NRF_TIMER0->TASKS_CLEAR = 1;               // clear the task first to be usable for later
    NRF_TIMER0->CC[0] =  1000; //first timeout
    //NRF_TIMER0->CC[1] =  1000;   //second timeout
    NRF_TIMER0->INTENSET    = TIMER_INTENSET_COMPARE0_Enabled << TIMER_INTENSET_COMPARE0_Pos;
    NRF_TIMER0->INTENSET    = TIMER_INTENSET_COMPARE1_Enabled << TIMER_INTENSET_COMPARE1_Pos;
   // Create an Event-Task shortcut to clear TIMER0 on COMPARE[0] event.
    NRF_TIMER0->SHORTS      = (TIMER_SHORTS_COMPARE1_CLEAR_Enabled << TIMER_SHORTS_COMPARE1_CLEAR_Pos);
    NRF_TIMER0->TASKS_START = 1;
void TIMER0_IRQHandler(void)
	if ((NRF_TIMER0->EVENTS_COMPARE[0] != 0) )
		NRF_TIMER0->EVENTS_COMPARE[0] = 0;
		i+=1;
		if(i==45)
			i=0;
			nrf_gpio_pin_clear(20);
			NRF_TIMER0->TASKS_STOP = 1;  //stoptimer2
void start_timer(void)
  NRF_TIMER2->MODE = TIMER_MODE_MODE_Timer;  // Set the timer in Counter Mode
  NRF_TIMER2->TASKS_CLEAR = 1;               // clear the task first to be usable for later
	NRF_TIMER2->PRESCALER = 4;                             //Set prescaler. Higher number gives slower timer. Prescaler = 0 gives 16MHz timer
	NRF_TIMER2->BITMODE = TIMER_BITMODE_BITMODE_16Bit;		 //Set counter to 16 bit resolution
	NRF_TIMER2->CC[0] = 1000;                             //Set value for TIMER2 compare register 0
	NRF_TIMER2->CC[1] = 1000;
  NRF_TIMER2->CC[2] = 1000;                          //Set value for TIMER2 compare register 1
  // Enable interrupt on Timer 2, both for CC[0] and CC[1] compare match events
	NRF_TIMER2->INTENSET = (TIMER_INTENSET_COMPARE0_Enabled << TIMER_INTENSET_COMPARE0_Pos) | (TIMER_INTENSET_COMPARE1_Enabled << TIMER_INTENSET_COMPARE1_Pos);
  NVIC_EnableIRQ(TIMER2_IRQn);
  NRF_TIMER2->TASKS_START = 1;               // Start TIMER2
void stop_timer(void)
  NRF_TIMER2->TASKS_STOP = 1;               // STOP TIMER2
void TIMER2_IRQHandler(void)
	if ((NRF_TIMER2->EVENTS_COMPARE[0] != 0) && ((NRF_TIMER2->INTENSET & TIMER_INTENSET_COMPARE0_Msk) != 0))
		NRF_TIMER2->EVENTS_COMPARE[0] = 0;
		i+=1;
		if(i==15)
			i=0;
	//	nrf_gpio_pin_set(20);
	if ((NRF_TIMER2->EVENTS_COMPARE[1] != 0) && ((NRF_TIMER2->INTENSET & TIMER_INTENSET_COMPARE0_Msk) != 0))
		NRF_TIMER2->EVENTS_COMPARE[1] = 0;
		ii+=1;
		if(ii==time)
			ii=0;
			setvalue(1);
			stop_timer();
	if ((NRF_TIMER2->EVENTS_COMPARE[2] != 0) && ((NRF_TIMER2->INTENSET & TIMER_INTENSET_COMPARE0_Msk) != 0))
		NRF_TIMER2->EVENTS_COMPARE[2] = 0;
		iii+=1;
		if(iii==2730)
			iii=0;
void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
    nrf_drv_gpiote_out_toggle(PIN_OUT);
 * @brief Function for configuring: PIN_IN pin for input, PIN_OUT pin for output,
 * and configures GPIOTE to give an interrupt on pin change.
static void gpio_init(void)
    ret_code_t err_code;
    //config.sense = NRF_GPIOTE_POLARITY_LOTOHI;
    nrf_drv_gpiote_out_config_t out_config = GPIOTE_CONFIG_OUT_SIMPLE(false);
    err_code = nrf_drv_gpiote_out_init(PIN_OUT, &out_config);
      nrf_drv_gpiote_in_config_t config;
    memset(&config, 0, sizeof(nrf_drv_gpiote_in_config_t));
   // config.sense = NRF_GPIOTE_POLARITY_HITOLO;
    //config.pull = NRF_GPIO_PIN_PULLUP;
	//  config.pull = GPIO_PIN_CNF_PULL_Disabled;
	config.pull =GPIO_PIN_CNF_PULL_Pulldown;
    config.hi_accuracy = false;
    config.is_watcher = false;
    nrf_drv_gpiote_in_init(PIR, &config, in_pin_handler);
    nrf_drv_gpiote_in_event_enable(PIN_IN, true);
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_MAX_TIMERS, APP_TIMER_OP_QUEUE_SIZE, false);
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
	 uint32_t                err_code;
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    // OUR_JOB: Add code to initialize the services used by the application.
	//our_service_init(&m_our_service);
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module which
 *          are passed to the application.
 *          @note All this function does is to disconnect. This could have been done by simply
 *                setting the disconnect_on_fail config parameter, but instead we use the event
 *                handler mechanism to demonstrate its use.
   /* uint32_t err_code;
	uint32_t err_code;
/**@brief Function for handling a Connection Parameters error.
   // APP_ERROR_HANDLER(nrf_error);
/**@brief Function for starting timers.
static void application_timers_start(void)
    // Prepare wakeup buttons.
	uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
/**@brief Function for handling the Application's BLE Stack events.
 * @param[in] p_ble_evt  Bluetooth stack event.
static void on_ble_evt(ble_evt_t * p_ble_evt)
	uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            // No implementation needed.
/**@brief Function for dispatching a BLE stack event to all modules with a BLE stack event handler.
 * @details This function is called from the BLE Stack event interrupt handler after a BLE stack
 *          event has been received.
static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
	  dm_ble_evt_handler(p_ble_evt);
    ble_conn_params_on_ble_evt(p_ble_evt);
    bsp_btn_ble_on_ble_evt(p_ble_evt);
    ble_advertising_on_ble_evt(p_ble_evt);
	  ble_our_service_on_ble_evt(&m_our_service, p_ble_evt);
/**@brief Function for dispatching a system event to interested modules.
 * @details This function is called from the System event interrupt handler after a system
 * @param[in] sys_evt  System stack event.
static void sys_evt_dispatch(uint32_t sys_evt)
   /* pstorage_sys_event_handler(sys_evt);
    ble_advertising_on_sys_evt(sys_evt);*/
    uint32_t err_code;
    // Initialize the SoftDevice handler module.
    SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_XTAL_20_PPM, NULL);
#if defined(S110) || defined(S130)
    // Enable BLE stack.
    ble_enable_params_t ble_enable_params;
    memset(&ble_enable_params, 0, sizeof(ble_enable_params));
#ifdef S130
    ble_enable_params.gatts_enable_params.attr_tab_size   = BLE_GATTS_ATTR_TAB_SIZE_DEFAULT;
    ble_enable_params.gatts_enable_params.service_changed = IS_SRVC_CHANGED_CHARACT_PRESENT;
    err_code = sd_ble_enable(&ble_enable_params);
    // Register with the SoftDevice handler module for BLE events.
    err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
    err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
 * @param[in]   event   Event generated by button press.
		uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
            err_code = ble_advertising_restart_without_whitelist();
/**@brief Function for handling the Device Manager events.
 * @param[in] p_evt  Data associated to the device manager event.
static uint32_t device_manager_evt_handler(dm_handle_t const * p_handle,
                                           dm_event_t const  * p_event,
                                           ret_code_t        event_result)
   /* APP_ERROR_CHECK(event_result);
#ifdef BLE_DFU_APP_SUPPORT
    if (p_event->event_id == DM_EVT_LINK_SECURED)
        app_context_load(p_handle);
#endif // BLE_DFU_APP_SUPPORT
    return NRF_SUCCESS;*/
    return NRF_SUCCESS;
/**@brief Function for the Device Manager initialization.
 * @param[in] erase_bonds  Indicates whether bonding information should be cleared from
 *                         persistent storage during initialization of the Device Manager.
static void device_manager_init(bool erase_bonds)
    dm_init_param_t        init_param = {.clear_persistent_data = erase_bonds};
    dm_application_param_t register_param;
    // Initialize persistent storage module.
    err_code = pstorage_init();
    err_code = dm_init(&init_param);
    memset(&register_param.sec_param, 0, sizeof(ble_gap_sec_params_t));
    register_param.sec_param.bond         = SEC_PARAM_BOND;
    register_param.sec_param.mitm         = SEC_PARAM_MITM;
    register_param.sec_param.io_caps      = SEC_PARAM_IO_CAPABILITIES;
    register_param.sec_param.oob          = SEC_PARAM_OOB;
    register_param.sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
    register_param.sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
    register_param.evt_handler            = device_manager_evt_handler;
    register_param.service_type           = DM_PROTOCOL_CNTXT_GATT_SRVR_ID;
    err_code = dm_register(&m_app_handle, &register_param);
		uint32_t      err_code;
    ble_advdata_t advdata;
    // Build advertising data struct to pass into ble_advertising_init().
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    ble_adv_modes_config_t options = {0};
    options.ble_adv_fast_enabled  = BLE_ADV_FAST_ENABLED;
    options.ble_adv_fast_interval = APP_ADV_INTERVAL;
    options.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
    // OUR_JOB: Create a scan response packet and include the list of UUIDs
    ble_advdata_t srdata;
    memset(&srdata, 0, sizeof(srdata));
    srdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    srdata.uuids_complete.p_uuids = m_adv_uuids;
    err_code = ble_advertising_init(&advdata, &srdata, &options, on_adv_evt, NULL);
   /* bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS,
                                 APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
                                 bsp_event_handler);
    *p_erase_bonds = (startup_event == BSP_EVENT_CLEAR_BONDING_DATA);*/
                                 bsp_event_handler);
/**@brief Function for the Power manager.
static void power_manage(void)
   /* uint32_t err_code = sd_app_evt_wait();
    APP_ERROR_CHECK(err_code);*/
/**@brief Function for application main entry.
	time=6250;
		uint32_t err_code;
    bool erase_bonds;
    // Initialize.
    timers_init();
    ble_stack_init();
    device_manager_init(erase_bonds);
    gap_params_init();
    services_init();
    advertising_init();
    conn_params_init();
    // Start execution.
    application_timers_start();
    err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
		nrf_gpio_cfg_output(20);
		services_init();
		start_timer();
		gpio_init();
    for (;;)
        power_manage();
		__WFE();
		  __SEV();
		//	sd_nvic_EnableIRQ(TIMER2_IRQn);
			//  start_timer();
	if(returnei()==0)
				//NVIC_EnableIRQ(TIMER0_IRQn);
			 // start_timer();
			else if(returnei()==1)
			//	stop_timer();
			else if(returnei()==2)
				time=6250*2;//20secondes
			else if(returnei()==3)
				time=6250*3;//30secondes
	else if(returnei()==4)
				time=6250;//10secondes
#include <stdint.h>
#include <string.h>
#include "nrf_gpio.h"
volatile int iiii=2;
void setvalue(int f)
	iiii=f;
int returnei ()
	return iiii;
static void on_ble_write(ble_os_t * p_our_service, ble_evt_t * p_ble_evt)
    // Declare buffer variable to hold received data. The data can only be 32 bit long.
    uint32_t data_buffer;
    // Populate ble_gatts_value_t structure to hold received data and metadata.
    ble_gatts_value_t rx_data;
    rx_data.len = sizeof(uint32_t);
    rx_data.offset = 0;
    rx_data.p_value = (uint8_t*)&data_buffer;
    // Check if write event is performed on our characteristic or the CCCD
    if(p_ble_evt->evt.gatts_evt.params.write.handle == p_our_service->char_handles.value_handle)
				//ii=0;
        // Get data
        sd_ble_gatts_value_get(p_our_service->conn_handle, p_our_service->char_handles.value_handle, &rx_data);
        // Print handle and value
        //printf("Value received on handle %#06x: %#010x\r\n", p_ble_evt->evt.gatts_evt.params.write.handle, data_buffer);
			  if(data_buffer == 0x00000001)
           // printf("Notification enabled\r\n");
					iiii=1;
        else if(data_buffer == 0x00000000)
           // printf("Notification disabled\r\n");
					iiii=0;
				else if(data_buffer == 0x00000002)
					iiii=2;
				else if(data_buffer == 0x00000003)
					iiii=3;
				else if(data_buffer == 0x00000004)
					iiii=4;
    else if(p_ble_evt->evt.gatts_evt.params.write.handle == p_our_service->char_handles.cccd_handle)
        // Get data
		//	ii=0;
        sd_ble_gatts_value_get(p_our_service->conn_handle, p_our_service->char_handles.cccd_handle, &rx_data);
       // printf("Value received on handle %#06x: %#06x\r\n", p_ble_evt->evt.gatts_evt.params.write.handle, data_buffer);
			if(data_buffer == 0x0001)
				//	ii=0;
        else if(data_buffer == 0x0000)
				//	ii=1;
// ALREADY_DONE_FOR_YOU: Declaration of a function that will take care of some housekeeping of ble connections related to our service and characteristic
void ble_our_service_on_ble_evt(ble_os_t * p_our_service, ble_evt_t * p_ble_evt)
        case BLE_GATTS_EVT_WRITE:
            on_ble_write(p_our_service, p_ble_evt);
            p_our_service->conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
            p_our_service->conn_handle = BLE_CONN_HANDLE_INVALID;
/**@brief Function for adding our new characterstic to "Our service" that we initiated in the previous tutorial.
 * @param[in]   p_our_service        Our Service structure.
static uint32_t our_char_add(ble_os_t * p_our_service)
    uint32_t   err_code = 0; // Variable to hold return codes from library and softdevice functions
    ble_uuid_t          char_uuid;
    ble_uuid128_t       base_uuid = BLE_UUID_OUR_BASE_UUID;
    char_uuid.uuid      = BLE_UUID_OUR_CHARACTERISTC_UUID;
    sd_ble_uuid_vs_add(&base_uuid, &char_uuid.type);
    ble_gatts_char_md_t char_md;
    memset(&char_md, 0, sizeof(char_md));
    char_md.char_props.read = 1;
    char_md.char_props.write = 1;
    ble_gatts_attr_md_t cccd_md;
    memset(&cccd_md, 0, sizeof(cccd_md));
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm);
    cccd_md.vloc                = BLE_GATTS_VLOC_STACK;
    char_md.p_cccd_md           = &cccd_md;
    char_md.char_props.notify   = 1;
    ble_gatts_attr_md_t attr_md;
    memset(&attr_md, 0, sizeof(attr_md));
    attr_md.vloc        = BLE_GATTS_VLOC_STACK;
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.write_perm);
    ble_gatts_attr_t    attr_char_value;
    memset(&attr_char_value, 0, sizeof(attr_char_value));
    attr_char_value.p_uuid      = &char_uuid;
    attr_char_value.p_attr_md   = &attr_md;
    attr_char_value.max_len     = 8;
    attr_char_value.init_len    = 8;
    uint8_t value[8]            = {0x12,0x34,0x56,0x78,0x12,0x34,0x56,0x78};
    attr_char_value.p_value     = value;
    err_code = sd_ble_gatts_characteristic_add(p_our_service->service_handle,
                                       &char_md,
                                       &attr_char_value,
                                       &p_our_service->char_handles);
    return NRF_SUCCESS;
/**@brief Function for initiating our new service.
void our_service_init(ble_os_t * p_our_service)
    uint32_t   err_code; // Variable to hold return codes from library and softdevice functions
    // FROM_SERVICE_TUTORIAL: Declare 16-bit service and 128-bit base UUIDs and add them to the BLE stack
    ble_uuid_t        service_uuid;
    service_uuid.uuid = BLE_UUID_OUR_SERVICE_UUID;
    err_code = sd_ble_uuid_vs_add(&base_uuid, &service_uuid.type);
    // OUR_JOB: Step 3.B, Set our service connection handle to default value. I.e. an invalid handle since we are not yet in a connection.
    // FROM_SERVICE_TUTORIAL: Add our service
    err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY,
                                        &service_uuid,
                                        &p_our_service->service_handle);
    // OUR_JOB: Call the function our_char_add() to add our new characteristic to the service.
    our_char_add(p_our_service);
// ALREADY_DONE_FOR_YOU: Function to be called when updating characteristic value
void our_temperature_characteristic_update(ble_os_t *p_our_service, int32_t *temperature_value)
    // OUR_JOB: Step 3.E, Update characteristic value
    if (p_our_service->conn_handle != BLE_CONN_HANDLE_INVALID)
        uint16_t               len = 4;
        ble_gatts_hvx_params_t hvx_params;
        memset(&hvx_params, 0, sizeof(hvx_params));
        hvx_params.handle = p_our_service->char_handles.value_handle;
        hvx_params.type   = BLE_GATT_HVX_NOTIFICATION;
        hvx_params.offset = 0;
        hvx_params.p_len  = &len;
        hvx_params.p_data = (uint8_t*)temperature_value;
        sd_ble_gatts_hvx(p_our_service->conn_handle, &hvx_params);
our_service.h
