I am trying to implement 128 bit uuid service and charachteristic and I am getting error 4(memory error) from
line 10: sd_ble_uuid_vs_add(&m_midi_service, &midi_init);
uint32_t err_code;
ble_nus_init_t nus_init;
ble_midi_service_init_t midi_init;
memset(&midi_init, 0, sizeof(midi_init));
midi_init.data_io_write_handler = data_io_write_handler;
err_code = ble_midi_service_init(&m_midi_service, &midi_init);
this is the midi_service code that i am using:
static uint32_t data_io_char_add(ble_midi_service_t * p_midi_service, const ble_midi_service_init_t * p_midi_service_init)
uint32_t err_code;
ble_gatts_char_md_t char_md;
ble_gatts_attr_md_t cccd_md;
ble_gatts_attr_t attr_char_value;
ble_uuid_t ble_uuid;
ble_gatts_attr_md_t attr_md;
memset(&cccd_md, 0, sizeof(cccd_md));
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm);
cccd_md.vloc = BLE_GATTS_VLOC_STACK;
memset(&char_md, 0, sizeof(char_md));
char_md.char_props.read = 1;
char_md.char_props.write_wo_resp = 1;
char_md.char_props.notify = 1;
char_md.p_char_user_desc = NULL;
char_md.p_char_pf = NULL;
char_md.p_user_desc_md = NULL;
char_md.p_cccd_md = &cccd_md;
char_md.p_sccd_md = NULL;
// Add the MIDI Data I/O Characteristic UUID
ble_uuid128_t base_uuid = BLE_UUID_MIDI_DATA_IO_CHAR_BASE_UUID;
err_code = sd_ble_uuid_vs_add(&base_uuid, &p_midi_service->uuid_type);
if (err_code != NRF_SUCCESS)
return err_code;
ble_uuid.type = p_midi_service->uuid_type;
ble_uuid.uuid = BLE_UUID_MIDI_DATA_IO_CHAR_UUID;
memset(&attr_md, 0, sizeof(attr_md));
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&attr_md.write_perm);
attr_md.vloc = BLE_GATTS_VLOC_STACK;
attr_md.rd_auth = 0;
attr_md.wr_auth = 0;
attr_md.vlen = 0;
memset(&attr_char_value, 0, sizeof(attr_char_value));
attr_char_value.p_uuid = &ble_uuid;
attr_char_value.p_attr_md = &attr_md;
attr_char_value.init_len = sizeof(uint8_t);
attr_char_value.init_offs = 0;
attr_char_value.max_len = sizeof(uint8_t);
attr_char_value.p_value = NULL;
return sd_ble_gatts_characteristic_add(p_midi_service->service_handle, &char_md,
&attr_char_value,
&p_midi_service->data_io_char_handles);
uint32_t ble_midi_service_init(ble_midi_service_t * p_midi_service, const ble_midi_service_init_t * p_midi_service_init)
uint32_t err_code;
// Initialize service structure
p_midi_service->conn_handle = BLE_CONN_HANDLE_INVALID;
p_midi_service->data_io_write_handler = p_midi_service_init->data_io_write_handler;
// Add service
ble_uuid128_t base_uuid = BLE_UUID_MIDI_SERVICE_BASE_UUID;
return err_code;
ble_uuid.uuid = BLE_UUID_MIDI_SERVICE_UUID;
err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY, &ble_uuid, &p_midi_service->service_handle);
return err_code;
err_code = data_io_char_add(p_midi_service, p_midi_service_init);
return err_code;
return NRF_SUCCESS;
this is the header code:
#define BLE_UUID_MIDI_SERVICE_BASE_UUID {{0x00, 0xC7, 0xC4, 0x4E, 0xE3, 0x6C, 0x51, 0xA7, 0x33, 0x4B, 0xE8, 0xED, 0x5A, 0x0E, 0xB8, 0x03}}
#define BLE_UUID_MIDI_SERVICE_UUID 0x0E5A
#define BLE_UUID_MIDI_DATA_IO_CHAR_BASE_UUID {{0xF3, 0x6B, 0x10, 0x9D, 0x66, 0xF2, 0xA9, 0xA1, 0x12, 0x41, 0x68, 0x38, 0xDB, 0xE5, 0x72, 0x77}}
#define BLE_UUID_MIDI_DATA_IO_CHAR_UUID 0xE5DB
// Forward declaration of the custom_service_t type.
typedef struct ble_midi_service_s ble_midi_service_t;
typedef void (*ble_midi_data_io_write_handler_t) (ble_midi_service_t * p_midi_service, uint8_t new_state);
typedef struct
ble_midi_data_io_write_handler_t data_io_write_handler; /**< Event handler to be called when MIDI Data I/O characteristic is written. */
} ble_midi_service_init_t;
/**@brief MIDI Service structure. This contains various status information for the service. */
uint16_t service_handle;
ble_gatts_char_handles_t data_io_char_handles;
uint8_t uuid_type;
uint16_t conn_handle;
} ble_midi_service_t;
(of course i include all neccery headers and declare all neccery functions..)
I was googling out the error and find an answare thats modified sdk_config.h file but I don't have it..
I have a file called softdevice_handler.c but I don't understand how to modify it for my needs..
