Support for 24 bit stereo audio at 96 kHz on i2s bus
I would like to know whether 24 bit stereo audio at 96 kHz is supported on the nRF52840 in i2s slave mode using an external master clock source.
Using the internal clock it doesn't seem possible to achieve the necessary clock accuracy; please correct me if I used the clock table wrongly.
Thanks and regards.
  • Hey Luigi,
    Max sample rate is 48kHz for stereo. See table below of the valid configurations:
    MCK = 32MHz / Div LRCK [kHz]
     Div MCK [kHz] Ratio 32 Ratio 48 Ratio 64 Ratio 96 Ratio 128 Ratio 192 Ratio 256 Ratio 384 Ratio 512
    2 16 000               41.67 31.25
    3 10 667             41.67 27.78 20.83
    4 8 000           41.67 31.25 20.83 15.63
    5 6 400           33.33 25.00 16.67 12.50
    6 5 333         41.67 27.78 20.83 13.89 10.42
    8 4 000       41.67 31.25 20.83 15.63 10.42 7.81
    10 3 200       33.33 25.00 16.67 12.50 8.33 6.25
    11 2 909     45.45 30.30 22.73 15.15 11.36 7.58 5.68
    15 2 133   44.44 33.33 22.22 16.67 11.11 8.33 5.56 4.17
    16 2 000   41.67 31.25 20.83 15.63 10.42 7.81 5.21 3.91
    21 1 524 47.62 31.75 23.81 15.87 11.90 7.94 5.95 3.97 2.98
    23 1 391 43.48 28.99 21.74 14.49 10.87 7.25 5.43 3.62 2.72
    30 1 067 33.33 22.22 16.67 11.11 8.33 5.56 4.17 2.78 2.08
    31 1 032 32.26 21.51 16.13 10.75 8.06 5.38 4.03 2.69 2.02
    32 1 000 31.25 20.83 15.63 10.42 7.81 5.21 3.91 2.60 1.95
    42 762 23.81 15.87 11.90 7.94 5.95 3.97 2.98 1.98 1.49
    63 508 15.87 10.58 7.94 5.29 3.97 2.65 1.98 1.32 0.99
    125 256 8.00 5.33 4.00 2.67 2.00 1.33 1.00 0.67 0.50
    Bit width Allowed ratios
    8 ALL
    16 32 64 128 256 512
    24 48 96 192 384
    Cheers,
    Håkon.
  • Hi Håkon,
    thanks for the prompt reply.
    This table seems to be strictly related to the clocks that the nRF52840 can generate with the onboard 32 MHz master clock.
    Do the same limitations apply to the case in which the clock information is provided by the external amplifier and the nRF52840 is an i2s slave?
    Thanks.
    Cheers,
    Luigi
  • Yes, max sample rate is 48KHz in any configuration.
  • HI Håkon,
    I notice you said the max sample rate is 48KHz in any configuration,which makes me confused.
    when MCK is 16MHz and ratio is 32,the max sample rate is 500KHz.But why no set?
    Is there any relationship between Div and ratio?
  • You can try and see if it works, but I doubt it. We do not test for it, and therefore it's out of spec.
