How reset device from code to take effect of enabling access port protection? NVIC_SystemReset() doesn't work. I can read flash using j-link.
Device: nRF52832
Device: nRF52832
How do you enable the readback protection?
The two following ways seems to work:
You can set it as a const in e.g. your main.c file, outside any function:
const uint32_t approtect_set __attribute__((used,at(0x10001208))) = 0xFFFFFF00;
This will set the readback protection, and you don't need a system reset.
Otherwise, you can set it in the application, e.g. in the top of your main() function. This, however, requires a system reset, which you can do in application. Please use the delay, to prevent a system reset loop (which makes it difficult to reset the chip).
void nrf_nvmc_write_word(uint32_t address, uint32_t value)
// Enable write.
NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Wen;
__ISB();
__DSB();
*(uint32_t*)address = value;
while (NRF_NVMC->READY == NVMC_READY_READY_Busy) {;}
NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Ren;
__ISB();
__DSB();
nrf_delay_ms(1000);
if (NRF_UICR->APPROTECT == 0xFFFFFFFF)
nrf_nvmc_write_word((uint32_t)&(NRF_UICR->APPROTECT), 0xFFFFFF00);
NVIC_SystemReset();
nrf_gpio_cfg_output(LED_1);
nrf_gpio_cfg_output(LED_2);
while (true)
if (NRF_UICR->APPROTECT != 0xFFFFFFFF)
nrf_gpio_pin_toggle(LED_1);
nrf_gpio_pin_toggle(LED_2);
nrf_delay_ms(100);
You can of course remove the lines controlling the LEDs, but if you use a DK, it will show you that the registers are set correct.
Also, using nrfjprog to try to read the memory will give the return:
>nrfjprog --memrd 0x10001208
ERROR: The operation attempted is unavailable due to readback protection in
ERROR: your device. Please use --recover to unlock the device.
Edvin
I will try to add delay at begin. But why is it necessary? Why system can go into reset loop? Isn't APPROTECT register updated before program execution?
My code:
if ((NRF_UICR->APPROTECT & UICR_APPROTECT_PALL_Msk) != UICR_APPROTECT_PALL_Enabled)
uint32_t tmp;
/* Enable access to write to flash */
while (NRF_NVMC->READY == NVMC_READY_READY_Busy);
/* Enable Access Port Protection
* Access to CPU registers and memory will be disabled
* to disable protection ERASEALL command must be applied. */
tmp = NRF_UICR->APPROTECT & ~UICR_APPROTECT_PALL_Msk;
NRF_UICR->APPROTECT = tmp | UICR_APPROTECT_PALL_Enabled;
/* Perform reset to take effect of changes */
NVIC_SystemReset();
Console:
>nrfjprog --recover Recovering device. This operation might take 30s. Erasing user code and UICR flash areas. >nrfjprog --program "file.hex" Parsing hex file. Reading flash area to program to guarantee it is erased. Checking that the area to write is not protected. Programing device. >nrfjprog --memrd 0x10001208 0x10001208: FFFFFFFF |....| >nrfjprog --run Run. >nrfjprog --memrd 0x10001208 0x10001208: FFFFFFFF |....| >nrfjprog --reset Applying system reset. Run. >nrfjprog --memrd 0x10001208 ERROR: The operation attempted is unavailable due to readback protection in ERROR: your device. Please use --recover to unlock the device.
Lukasz
Sorry. I forgot to include the nrf_nvmc_write_word() function. I updated my previous reply. Please try to use the nrf_nvmc_write_word() function that is included now.
BR,
Edvin
