I am trying to build examples from mesh SDK(light example). I have installed toolchain, CMake and Ninja but CMake fails. Below is the output of CMake.
$ cmake -G Ninja -DTOOLCHAIN=gccarmemb -DPLATFORM=nrf52832_xxAA ..
-- The C compiler identification is GNU 7.2.1
-- The CXX compiler identification is GNU 7.2.1
-- Check for working C compiler: C:/Program Files (x86)/GNU Tools ARM Embedded/7 2017-q4-major/bin/arm-none-eabi-gcc.exe
-- Check for working C compiler: C:/Program Files (x86)/GNU Tools ARM Embedded/7 2017-q4-major/bin/arm-none-eabi-gcc.exe -- broken
CMake Error at C:/Program Files/CMake/share/cmake-3.10/Modules/CMakeTestCCompiler.cmake:52 (message):
The C compiler
"C:/Program Files (x86)/GNU Tools ARM Embedded/7 2017-q4-major/bin/arm-none-eabi-gcc.exe"
is not able to compile a simple test program.
It fails with the following output:
Change Dir: E:/Prasad/Charlie_repo/SDK/nrf5_SDK_for_Mesh_v1.0.1_src/examples/light_switch/build/CMakeFiles/CMakeTmp
Run Build Command:"C:/ninja-win/ninja.exe" "cmTC_a50df"
[1/2] Building C object CMakeFiles/cmTC_a50df.dir/testCCompiler.c.obj
[2/2] Linking C executable cmTC_a50df.exe
FAILED: cmTC_a50df.exe
cmd.exe /C "cd . && C:\PROGRA~2\GNUTOO~1\72017-~1\bin\AR19DD~1.EXE CMakeFiles/cmTC_a50df.dir/testCCompiler.c.obj -o cmTC_a50df.exe -Wl,--out-implib,libcmTC_a50df.dll.a -Wl,--major-image-version,0,--minor-image-version,0 && cd ."
c:/progra~2/gnutoo~1/72017-~1/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/bin/ld.exe: unrecognized option '--major-image-version'
c:/progra~2/gnutoo~1/72017-~1/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/bin/ld.exe: use the --help option for usage information
collect2.exe: error: ld returned 1 exit status
CMake will not be able to correctly generate this project.
CMakeLists.txt
CMake Warning (dev) in CMakeLists.txt:
No cmake_minimum_required command is present. A line of code such as
cmake_minimum_required(VERSION 3.10)
should be added at the top of the file. The version specified may be lower
if you wish to support older CMake versions for this project. For more
information run "cmake --help-policy CMP0000".
This warning is for project developers. Use -Wno-dev to suppress it.
See also "E:/Prasad/Charlie_repo/SDK/nrf5_SDK_for_Mesh_v1.0.1_src/examples/light_switch/build/CMakeFiles/CMakeOutput.log".
See also "E:/Prasad/Charlie_repo/SDK/nrf5_SDK_for_Mesh_v1.0.1_src/examples/light_switch/build/CMakeFiles/CMakeError.log".
