Hi guys,
I start with SDK13 and i want to create SDcard saver same information every 5 second on card. This is my code, i have no idea why it din't work.
* Copyright (c) 2016 - 2017, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup fatfs_example_main main.c
* @ingroup fatfs_example
* @brief FATFS Example Application main file.
* This file contains the source code for a sample application using FAT filesystem and SD card library.
#include "app_timer.h"
#include "nrf.h"
#include "bsp.h"
#include "ff.h"
#include "diskio_blkdev.h"
#include "nrf_block_dev_sdc.h"
#define NRF_LOG_MODULE_NAME "APP"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define FILE_NAME "NORDIC.TXT"
#define TEST_STRING "SD card example.\r\n"
#define SDC_SCK_PIN ARDUINO_13_PIN ///< SDC serial clock (SCK) pin.
#define SDC_MOSI_PIN ARDUINO_11_PIN ///< SDC serial data in (DI) pin.
#define SDC_MISO_PIN ARDUINO_12_PIN ///< SDC serial data out (DO) pin.
#define SDC_CS_PIN ARDUINO_10_PIN ///< SDC chip select (CS) pin.
//Timer
#define SD_SAVE_DATA_INTERVAL APP_TIMER_TICKS(5000) /**< Tick / Ms */
APP_TIMER_DEF(sd_timer_id);
* @brief SDC block device definition
NRF_BLOCK_DEV_SDC_DEFINE(
m_block_dev_sdc,
NRF_BLOCK_DEV_SDC_CONFIG(
SDC_SECTOR_SIZE,
APP_SDCARD_CONFIG(SDC_MOSI_PIN, SDC_MISO_PIN, SDC_SCK_PIN, SDC_CS_PIN)
NFR_BLOCK_DEV_INFO_CONFIG("Nordic", "SDC", "1.00")
* @brief Function for demonstrating FAFTS usage.
static void fatfs_example()
static uint32_t i;
uint32_t id_sd = (i++);
NRF_LOG_INFO("\r\nDO IT :%d \r\n\r\n",id_sd);
static FATFS fs;
static DIR dir;
static FILINFO fno;
static FIL file;
uint32_t bytes_written;
FRESULT ff_result;
DSTATUS disk_state = STA_NOINIT;
// Initialize FATFS disk I/O interface by providing the block device.
static diskio_blkdev_t drives[] =
DISKIO_BLOCKDEV_CONFIG(NRF_BLOCKDEV_BASE_ADDR(m_block_dev_sdc, block_dev), NULL)
diskio_blockdev_register(drives, ARRAY_SIZE(drives));
NRF_LOG_INFO("Initializing disk 0 (SDC)...\r\n");
for (uint32_t retries = 3; retries && disk_state; --retries)
disk_state = disk_initialize(0);
if (disk_state)
NRF_LOG_INFO("Disk initialization failed.\r\n");
return;
uint32_t blocks_per_mb = (1024uL * 1024uL) / m_block_dev_sdc.block_dev.p_ops->geometry(&m_block_dev_sdc.block_dev)->blk_size;
uint32_t capacity = m_block_dev_sdc.block_dev.p_ops->geometry(&m_block_dev_sdc.block_dev)->blk_count / blocks_per_mb;
NRF_LOG_INFO("Capacity: %d MB\r\n", capacity);
NRF_LOG_INFO("Mounting volume...\r\n");
ff_result = f_mount(&fs, "", 1);
if (ff_result)
NRF_LOG_INFO("Mount failed.\r\n");
return;
NRF_LOG_INFO("\r\n Listing directory: /\r\n");
ff_result = f_opendir(&dir, "/");
if (ff_result)
NRF_LOG_INFO("Directory listing failed!\r\n");
return;
do
ff_result = f_readdir(&dir, &fno);
if (ff_result != FR_OK)
NRF_LOG_INFO("Directory read failed.");
return;
if (fno.fname[0])
if (fno.fattrib & AM_DIR)
NRF_LOG_RAW_INFO(" <DIR> %s\r\n",(uint32_t)fno.fname);
NRF_LOG_RAW_INFO("%9lu %s\r\n", fno.fsize, (uint32_t)fno.fname);
while (fno.fname[0]);
NRF_LOG_RAW_INFO("\r\n");
NRF_LOG_INFO("Writing to file " FILE_NAME "...\r\n");
ff_result = f_open(&file, FILE_NAME, FA_READ | FA_WRITE | FA_OPEN_APPEND);
NRF_LOG_INFO("Unable to open or create file: " FILE_NAME ".\r\n");
return;
ff_result = f_write(&file, TEST_STRING, sizeof(TEST_STRING) - 1, (UINT *) &bytes_written);
NRF_LOG_INFO("Write failed\r\n.");
NRF_LOG_INFO("%d bytes written.\r\n", bytes_written);
(void) f_close(&file);
return;
// Timeout handler for the repeated timer
static void timer_sd_handler(void * p_context)
UNUSED_PARAMETER(p_context);
bsp_board_led_invert(0);
fatfs_example();
NRF_LOG_INFO("\r\nDO IT0.\r\n\r\n");
// Create timers
static void timers_init()
ret_code_t err_code;
// Initialize timer module.
err_code = app_timer_init();
// Create timers
err_code = app_timer_create(&sd_timer_id,
APP_TIMER_MODE_REPEATED,
timer_sd_handler);
NRF_LOG_INFO("\r\nDO IT.\r\n\r\n");
static void log_init(void)
/**@brief Function for starting timers.
static void application_timers_start(void)
err_code = app_timer_start(sd_timer_id, SD_SAVE_DATA_INTERVAL, NULL);
bsp_board_leds_init();
log_init();
NRF_LOG_INFO("\r\nFATFS example.\r\n\r\n");
// Init timers.
timers_init();
// Timers starts
application_timers_start();
//fatfs_example();
while (true)
__WFI();
I red that there are many changes since sdk11.
I found that Tutorial, but it's for sdk11 not sdk13 and i'm not sure it this changes are good.
