Hard fault when adding service UUID to softdevice S132
Hi, I get a hard fault when I try to add an own UUID to the softdevice S132. I'm using Eclipse with GCC compiler, Rigado BMD350 eval board with the nRF52832 chip on it. As project template I use the ble_peripherals_template from the SDK 14.2.0 and went through the beginners tutorial BLE services.
When I add the own_service_init function in the service_init in main.c (see the tutorial) the controller runs into hard fault. Without the own_service routine the device connects perfectly to a cell phone. I debugged it with the debugger on the eval board and I can run the programm to the point where the Service and the vendor specific UUID must be added to the softdevices UUID list. I searched the internet and found out that the memory allocated for the softdevice is to short in the linker script (I read this in the documentation of the softdevice v5.0). I changed the linker script,m but that didn't help also. The line of code is where the hard fault is caused is the following:
err_code = sd_ble_uuid_vs_add(&base_uuid, &service_uuid.type);
I'm guessing that my application can't call the function in the softdevice, but I'm not quite sure.
Can anybody help or give an advice where to look or what I've done wrong?
Thanks in advance everybody!!!
