Hi
Where can I find "light_switch demo" and what programs do I need to run it?
I'm have the nrf52840
i hope some can help
Hi
ohh yeah i have missed but now i have try and it will not run, it says is missing some librarys, so don't now what i'm doing wrong
ok, you will either have to document the exact errors that you are getting and/or include a screenshot if at all possible in your reply.
ok, i'm not sure what you did to hose your mesh setup but to get back on track I would suggest that you extract the nRF5-SDK-for-Mesh v1.0.1 SDK to your preferred folder/location and once that is in place simply extract the examples.zip file (provided by Hung Bui) over the %nrf5-mesh-sdk_v1.0.1%/examples folder (%nrf5-mesh-sdk_v1.0.1% = the folder where you extracted mesh).
With that in place, you should then be able to see:
(1) light_switch_server_nrf52840_xxAA_s140_5_0_0-3_alpha.emProject and
(2) light_switch_client_nrf52840_xxAA_s140_5_0_0-3_alpha.emProject in the
.\examples\light_switch\server and .\examples\light_switch\client folders respectively.
From there you should be able to launch those .emProject files in Segger Embedded Studio and build successfully.
it works now, but when I'm testing the program, I'm not sure if it works because it's like the the client does not always get any of the servers. somthing else i'm not syre of is it true that all 4 LEDs should light up once on one server and is it true that I should be able to manage 2 servers at Button 1
