Hi
Where can I find "light_switch demo" and what programs do I need to run it?
I'm have the nrf52840
i hope some can help
Hi
ok, you should be able to look at the debug output from each client/server(s) instance to determine the last log message reported...
If running under Segger Embedded Studio (SES) look at the Debug Terminal window for output similar to the following...
<t: 0>, main.c, 119, ----- BLE Mesh Light Switch Server Demo ----- <t: 306>, main.c, 85, Initializing and adding models <t: 392>, nrf_mesh_node_config.c, 296, Found previous provisioning data <t: 398>, main.c, 95, Successfully provisioned <t: 328072>, access.c, 453, Src Addr: 0x0100, Dst Addr: 0x0001, ttl: 1 <t: 655783>, access.c, 453, Src Addr: 0x0100, Dst Addr: 0x0001, ttl: 1 <t: 983496>, access.c, 453, Src Addr: 0x0100, Dst Addr: 0x0001, ttl: 1
<t: 0>, main.c, 431, ----- BLE Mesh Light Switch Client Demo ----- <t: 0>, nrf_mesh_sdk.c, 190, Initializing softdevice <t: 0>, nrf_mesh_sdk.c, 125, Initializing SoftDevice... <t: 2>, nrf_mesh_sdk.c, 134, Ram base: 0x200019C0 <t: 14>, nrf_mesh_sdk.c, 200, Initializing mesh stack <t: 301>, nrf_mesh_sdk.c, 208, Enabling mesh stack <t: 306>, main.c, 183, Setting up access layer and models <t: 780589>, main.c, 305, Node 0x0100 alive with 0 active fault(s), RSSI: -22 <t: 1108509>, main.c, 305, Node 0x0100 alive with 0 active fault(s), RSSI: -22 <t: 1436233>, main.c, 305, Node 0x0100 alive with 0 active fault(s), RSSI: -21
If you are provisioning a server the first time around (or after flash erase) you should see something similar to the following on the client console...
<t: 0>, main.c, 432, ----- BLE Mesh Light Switch Client Demo ----- <t: 0>, nrf_mesh_sdk.c, 190, Initializing softdevice <t: 0>, nrf_mesh_sdk.c, 125, Initializing SoftDevice... <t: 2>, nrf_mesh_sdk.c, 134, Ram base: 0x200031B8 <t: 18>, nrf_mesh_sdk.c, 200, Initializing mesh stack <t: 296>, nrf_mesh_sdk.c, 208, Enabling mesh stack <t: 301>, main.c, 183, Setting up access layer and models <t: 3157745>, provisioner.c, 226, Starting provisioning for dev-uuid: 0xAA:BB:CC:DD:EE:8D <t: 3313091>, provisioner.c, 278, Local provisioning link established... <t: 3423959>, provisioner.c, 264, Using static authentication <t: 3710813>, main.c, 402, Provisioning complete. Adding address 0x0100. <t: 3815676>, provisioner.c, 111, Getting composition data <t: 3987315>, provisioner.c, 233, Local provisioning link closed... <t: 3989603>, provisioner.c, 321, Composition data: 0059000000000020000100000002010000020059000000 <t: 4092674>, provisioner.c, 119, Adding appkey <t: 4182852>, provisioner.c, 128, Binding appkey to the Health model <t: 4275555>, provisioner.c, 140, Binding appkey to the Simple On/Off model <t: 4540729>, provisioner.c, 165, Setting publication address for the health server to 0x0001 <t: 4646250>, provisioner.c, 187, Setting publication address for the On/Off server to 0x0001 <t: 4715953>, provisioner.c, 196, Adding subscription <t: 4720264>, main.c, 365, Configuration of device 0 successful <t: 4870118>, main.c, 305, Node 0x0100 alive with 0 active fault(s), RSSI: -22 <t: 5197769>, main.c, 305, Node 0x0100 alive with 0 active fault(s), RSSI: -21 <t: 5525929>, main.c, 305, Node 0x0100 alive with 0 active fault(s), RSSI: -23
Here's an example of how the Debug Terminal should look from SES...
If you aren't running within SES then the J-Link RTT Viewer client can be used to monitor debug output from each client and respective server(s).
hi i have now try to debug it, i can see that the server do not get into the two config_params.setup_callback = configuration_setup;
config_params.complete_callback = provisioning_complete;
also on the client falling into Hardfault_handler
