Saving data to SD card every 5 sec (using app_timer)
I'm using evaluation board nrf52 (nrf52832) and using SDK 13 (nRF5_SDK_13.0.0_04a0bfd) and programing it using eclipse. Here is the code:
 * Copyright (c) 2016 - 2017, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup fatfs_example_main main.c
 * @ingroup fatfs_example
 * @brief FATFS Example Application main file.
 * This file contains the source code for a sample application using FAT filesystem and SD card library.
#include "app_timer.h"
#include "nrf.h"
#include "bsp.h"
#include "ff.h"
#include "diskio_blkdev.h"
#include "nrf_block_dev_sdc.h"
#define NRF_LOG_MODULE_NAME "APP"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define FILE_NAME   "NORDIC.TXT"
#define TEST_STRING "SD card example.\r\n"
#define SDC_SCK_PIN     ARDUINO_13_PIN  ///< SDC serial clock (SCK) pin.
#define SDC_MOSI_PIN    ARDUINO_11_PIN  ///< SDC serial data in (DI) pin.
#define SDC_MISO_PIN    ARDUINO_12_PIN  ///< SDC serial data out (DO) pin.
#define SDC_CS_PIN      ARDUINO_10_PIN  ///< SDC chip select (CS) pin.
//Timer
#define SD_SAVE_DATA_INTERVAL     APP_TIMER_TICKS(5000)                   /**< Tick / Ms */
APP_TIMER_DEF(sd_timer_id);
 * @brief  SDC block device definition
NRF_BLOCK_DEV_SDC_DEFINE(
		m_block_dev_sdc,
		NRF_BLOCK_DEV_SDC_CONFIG(
				SDC_SECTOR_SIZE,
				APP_SDCARD_CONFIG(SDC_MOSI_PIN, SDC_MISO_PIN, SDC_SCK_PIN, SDC_CS_PIN)
		NFR_BLOCK_DEV_INFO_CONFIG("Nordic", "SDC", "1.00")
 * @brief Function for demonstrating FAFTS usage.
static void fatfs_example()
	static uint32_t i;
	uint32_t id_sd = (i++);
	NRF_LOG_INFO("\r\n DO IT :%d \r\n\r\n",id_sd);
	static FATFS fs;
	static DIR dir;
	static FILINFO fno;
	static FIL file;
	uint32_t bytes_written;
	FRESULT ff_result;
	DSTATUS disk_state = STA_NOINIT;
	// Initialize FATFS disk I/O interface by providing the block device.
	static diskio_blkdev_t drives[] =
			DISKIO_BLOCKDEV_CONFIG(NRF_BLOCKDEV_BASE_ADDR(m_block_dev_sdc, block_dev), NULL)
	diskio_blockdev_register(drives, ARRAY_SIZE(drives));
	NRF_LOG_INFO("Initializing disk 0 (SDC)...\r\n");
	for (uint32_t retries = 3; retries && disk_state; --retries)
		disk_state = disk_initialize(0);
	if (disk_state)
		NRF_LOG_INFO("Disk initialization failed.\r\n");
		return;
	uint32_t blocks_per_mb = (1024uL * 1024uL) / m_block_dev_sdc.block_dev.p_ops->geometry(&m_block_dev_sdc.block_dev)->blk_size;
	uint32_t capacity = m_block_dev_sdc.block_dev.p_ops->geometry(&m_block_dev_sdc.block_dev)->blk_count / blocks_per_mb;
	NRF_LOG_INFO("Capacity: %d MB\r\n", capacity);
	NRF_LOG_INFO("Mounting volume...\r\n");
	ff_result = f_mount(&fs, "", 1);
	if (ff_result)
		NRF_LOG_INFO("Mount failed.\r\n");
		return;
	NRF_LOG_INFO("\r\n Listing directory: /\r\n");
	ff_result = f_opendir(&dir, "/");
	if (ff_result)
		NRF_LOG_INFO("Directory listing failed!\r\n");
		return;
	do
		ff_result = f_readdir(&dir, &fno);
		if (ff_result != FR_OK)
			NRF_LOG_INFO("Directory read failed.");
			return;
		if (fno.fname[0])
			if (fno.fattrib & AM_DIR)
				NRF_LOG_RAW_INFO("   <DIR>   %s\r\n",(uint32_t)fno.fname);
				NRF_LOG_RAW_INFO("%9lu  %s\r\n", fno.fsize, (uint32_t)fno.fname);
	while (fno.fname[0]);
	NRF_LOG_RAW_INFO("\r\n");
	NRF_LOG_INFO("Writing to file " FILE_NAME "...\r\n");
	ff_result = f_open(&file, FILE_NAME, FA_READ | FA_WRITE | FA_OPEN_APPEND);
		NRF_LOG_INFO("Unable to open or create file: " FILE_NAME ".\r\n");
		return;
	ff_result = f_write(&file, TEST_STRING, sizeof(TEST_STRING) - 1, (UINT *) &bytes_written);
		NRF_LOG_INFO("Write failed\r\n.");
		NRF_LOG_INFO("%d bytes written.\r\n", bytes_written);
	(void) f_close(&file);
	//bsp_board_led_invert(0);
	return;
// Timeout handler for the repeated timer
static void timer_sd_handler(void * p_context)
	NRF_LOG_INFO("\r\n Timer_SD_Handler.\r\n\r\n");
	UNUSED_PARAMETER(p_context);
	fatfs_example();
// Create timers
static void timers_init()
	NRF_LOG_INFO("\r\n Timer_INIT.\r\n\r\n");
	ret_code_t err_code;
	// Initialize timer module.
	err_code = app_timer_init();
/**	//    if(NRF_SUCCESS!=err_code){
	//    	NRF_LOG_INFO("Error while init. \r\n");
	//    }else {
	//    	NRF_LOG_INFO("App timer init. \r\n");
	// Create timers
	err_code = app_timer_create(&sd_timer_id,
			APP_TIMER_MODE_REPEATED,
			timer_sd_handler);
	NRF_LOG_INFO("\r\n Init and create timer.\r\n\r\n");
static void log_init(void)
/**@brief Function for starting timers.
static void application_timers_start(void)
	NRF_LOG_INFO("\r\n Timer_sd_start.\r\n\r\n");
	err_code = app_timer_start(sd_timer_id, SD_SAVE_DATA_INTERVAL, NULL);
	bsp_board_leds_init();
	log_init();
	NRF_LOG_INFO("\r\nFATFS.\r\n\r\n");
	// Init timers.
	timers_init();
	// Timers starts
	application_timers_start();
	while (true)
		__WFI();
Someting is not working and i'm not sure but in my opinion app_timer is not working correct. Log :
APP:INFO:
FATFS.
APP:INFO:
 Timer_INIT.
APP:INFO:
APP:INFO:
 Timer_sd_start.
After init timer and start it the timer_sd_handler() is not calling and i don't know why. Does anyone has any idea?
    app_timer does not start up the LFCLK source. Try starting up the LFCLK, then start the app_timer instance.
    Cheers,
    Håkon
  • It helps, i add
    // Init for LFCLK
    static void lfclk_request(void)
        ret_code_t err_code = nrf_drv_clock_init();
        if(nrf_drv_clock_lfclk_is_running()){
    		NRF_LOG_INFO("LFCLK: ON \r\n ");
    and in main
    	// Request LF clock.
    	    lfclk_request();
    later i must add this in sdk_config.h file
    // </e>
    // <e> CLOCK_ENABLED - nrf_drv_clock - CLOCK peripheral driver
    #ifndef CLOCK_ENABLED
    #define CLOCK_ENABLED 1
    #if  CLOCK_ENABLED
    // <o> CLOCK_CONFIG_XTAL_FREQ  - HF XTAL Frequency
    // <0=> Default (64 MHz)
    #ifndef CLOCK_CONFIG_XTAL_FREQ
    #define CLOCK_CONFIG_XTAL_FREQ 0
    // <o> CLOCK_CONFIG_LF_SRC  - LF Clock Source
    // <0=> RC
    // <1=> XTAL
    // <2=> Synth
    #ifndef CLOCK_CONFIG_LF_SRC
    #define CLOCK_CONFIG_LF_SRC 1
    // <o> CLOCK_CONFIG_IRQ_PRIORITY  - Interrupt priority
    // <i> Priorities 0,2 (nRF51) and 0,1,4,5 (nRF52) are reserved for SoftDevice
    // <0=> 0 (highest)
    // <1=> 1
    // <2=> 2
    // <3=> 3
    // <4=> 4
    // <5=> 5
    // <6=> 6
    // <7=> 7
    #ifndef CLOCK_CONFIG_IRQ_PRIORITY
    #define CLOCK_CONFIG_IRQ_PRIORITY 7
    // <e> CLOCK_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef CLOCK_CONFIG_LOG_ENABLED
    #define CLOCK_CONFIG_LOG_ENABLED 1
    #if  CLOCK_CONFIG_LOG_ENABLED
    // <o> CLOCK_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef CLOCK_CONFIG_LOG_LEVEL
    #define CLOCK_CONFIG_LOG_LEVEL 3
    // <o> CLOCK_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef CLOCK_CONFIG_INFO_COLOR
    #define CLOCK_CONFIG_INFO_COLOR 0
    // <o> CLOCK_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef CLOCK_CONFIG_DEBUG_COLOR
    #define CLOCK_CONFIG_DEBUG_COLOR 0
    #endif //CLOCK_CONFIG_LOG_ENABLED
    // </e>
    #endif //CLOCK_ENABLED
    but when i compile it, something stop the program and this is the finall log
    Process: JLinkGDBServer
    APP:INFO:
    FATFS.
    CLOCK:INFO:Function: nrf_drv_clock_init, error code: NRF_SUCCESS.
    APP:INFO:
     Timer_INIT.
    APP:INFO:
    APP:INFO:
     Timer_sd_start.
    APP:INFO:Timer was successfully started.
    APP:INFO:
     Timer_SD_Handler.
    APP:INFO:
     DO IT :0
    APP:INFO:Initializing disk 0 (SDC)...
    and when i check SD card nothing is save on it.
    Thanks for help, but now i need to solve other problem.
