I am advertising a service and providing scan response data. It is not clear to me whether I should be bothering setting up the values of the ble_adv_modes_config_t structure. Please clarify. As presented everything is working.
ret_code_t err_code;
ble_advdata_t advdata;
ble_adv_modes_config_t options;
// Build advertising data struct to pass into @ref ble_advertising_init.
memset(&advdata, 0, sizeof(advdata));
advdata.name_type = BLE_ADVDATA_FULL_NAME;
//advdata.include_appearance = true;
advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
advdata.uuids_complete.p_uuids = m_adv_uuids;
memset(&options, 0, sizeof(options));
options.ble_adv_whitelist_enabled = false; /**< Enable or disable use of the whitelist. */
options.ble_adv_directed_enabled = false; /**< Enable or disable direct advertising mode. */
options.ble_adv_directed_slow_enabled = false; /**< Enable or disable direct advertising mode. */
options.ble_adv_fast_enabled = true; /**< Enable or disable fast advertising mode. */
options.ble_adv_slow_enabled = false; /**< Enable or disable slow advertising mode. */
options.ble_adv_fast_interval = APP_ADV_INTERVAL;
options.ble_adv_fast_timeout = APP_ADV_TIMEOUT_IN_SECONDS;
err_code = ble_advertising_init(&advdata, NULL, &options, on_adv_evt, NULL);
#define APP_CFG_NON_CONN_ADV_TIMEOUT 0 /**< Time for which the device must be advertising in non-connectable mode (in seconds). 0 disables timeout. */
#define NON_CONNECTABLE_ADV_INTERVAL MSEC_TO_UNITS(100, UNIT_0_625_MS) /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */
// Initialize advertising parameters (used when starting advertising).
ble_gap_adv_params_t m_adv_params;
memset(&m_adv_params, 0, sizeof(m_adv_params));
m_adv_params.type = BLE_GAP_ADV_TYPE_ADV_SCAN_IND; //BLE_GAP_ADV_TYPE_ADV_NONCONN_IND;
m_adv_params.p_peer_addr = NULL; // Undirected advertisement.
m_adv_params.fp = BLE_GAP_ADV_FP_ANY; /**< Allow scan requests and connect requests from any device. */
m_adv_params.interval = NON_CONNECTABLE_ADV_INTERVAL; // setting the advertising interval to 100ms.
m_adv_params.timeout = APP_CFG_NON_CONN_ADV_TIMEOUT; // this define is 0, meaning that advertising will never timeout.
ret_code_t err_code = sd_ble_gap_adv_start(&m_adv_params, BLE_CONN_CFG_TAG_DEFAULT);
