Merging SPI, TWI and Buttonless dfu
Hi Everyone
I am working on nrf52832 with sdk 14.0.0 on iar IDE.  TWI and SPI separately working fine in buttonless_dfu then i merged SPI and TWI in buttonless_dfu itself but due to adding both codes they stuck . .
i also try to change the priority( 2 , 3 or same) of both (TWI and SPI) and also enable the peripheral resouce sharing bit.
  • Could you please describe in what way it is "stuck"? Does the code compile? Does it run, but you can't see anything on the SPI or TWI (or both), or does it crash due to an APP_ERROR_CHECK()? If you set a breakpoint on the last line before the for (;;) loop, does it hit, or does it stop before this?
    Can you also try to define "DEBUG" in your preprocessor defines, set optimization to 0 (-O0), and set a breakpoint in app_error.c on line 73, and see if it breaks there?
    Edvin
  • Hi Edvin,
    Thanks for reply,
    We were using same instance of i2c and spi and same priority for both that causing device stuck. Now we are using twi0 and spi1 now it working and changed the priority also.
    Now the problem is as described below:
    in our application we are trying to write a chunk of 4.8k bytes to external spi flash w25q32fw (winbond flash), collected from sensors interfaced with I2C lines. The SPI behavior is very random as some time all the commands and data goes well into external flash and sometime it fails. It seems likes MOSI line is not working properly. We also debugged the issue on CRO and saw same behavior.
    The SPI code is as follows
    * Copyright (c) 2015 - 2017, Nordic Semiconductor ASA
    * All rights reserved.
    #include "spi_flash.h"
    #include "sensor_nrf.h"
    #define SPI_INSTANCE  1 /**< SPI instance index. */
    static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);  /**< SPI instance. */
    static volatile bool spi_xfer_done;  /**< Flag used to indicate that SPI instance completed the transfer. */
    //static uint16_t curr_page = 1;
    bool pageOverflow;
    //s_flash flash;
      uint16_t read_page = 0;
      uint8_t  read_index = 0;
      uint16_t write_page = 0;
      uint8_t  write_index = 0;
    uint32_t getFlashAddr(uint16_t page_number, uint8_t offset)
      uint32_t address =0;
      address = page_number << 8;
      address += offset;
      return address;
    //Checks to see if pageOverflow is permitted and assists with determining next address to write to.
    uint8_t W25Q32_AddrCheck(uint32_t address)
      if (address > 0x3FFFFF)
        if (!pageOverflow)
          return (1);
          return (2);
        return (0);
    * File Name : spi_flash.c
    * Function Name :
    * Parameters :
    * Return :
    * Description : determine whether W25Q32 busy busy function returns 1
    uint8_t W25Q32_BUSY (void)
      uint8_t flag = 0;
      uint8_t buf[1]={0};
      const uint8_t wBuff[] = {W25Q32_READ_STATUS_REG1};
      spi_xfer_done = false;
      APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, wBuff, sizeof(wBuff), buf, sizeof(buf)));
      while (!spi_xfer_done)
        __WFE();
      flag = buf[0];
      flag &= 0x01;
      return flag;
    uint8_t W25Q32_WEL(void)
      uint8_t flag = 0;
      uint8_t buf[1]={0};
      const uint8_t wBuff[] = {W25Q32_WRITE_ENABLE};
        __WFE();
      flag = buf[0];
      flag &= WRTEN;
      return flag;
    * Function Name :
    * Parameters :
    * Return :
    * Description : erase the entire chip
    bool W25Q32_erase(uint16_t page_number, uint8_t offset, size_t length)
      /* Note that Block erase might be more efficient when the floor map
      * is well planned for OTA but to simplify for the temporary implementation,
      * sector erase is used blindly. */
      uint8_t wBuf[4];
      uint8_t buf[1];
      uint32_t address;
      size_t i, numsectors;
      if(page_number >= TOTAL_PAGES || offset >= OFFSET_RANGE)
          return false;
      address = getFlashAddr(page_number, offset);
      wBuf[0] = W25Q32_SECTOR_ERASE;
       //wBuf[0] = BLS_CODE_ERASE_64K;
        size_t endoffset = address + length-1;//offset + length - 1;
        address = (address / W25Q32_SECTOR_SIZE) * W25Q32_SECTOR_SIZE;
        numsectors = (endoffset - address + W25Q32_SECTOR_SIZE - 1) /
          W25Q32_SECTOR_SIZE;
      for (i = 0; i < numsectors; i++)
        /* Wait till previous erase/program operation completes */
    //   while((W25Q32_BUSY() == BUSY)&&(W25Q32_WEL() == WRTEN));
        while((W25Q32_BUSY() == BUSY));
        //nrf_delay_ms(1);
        W25Q32_WEL();
        wBuf[1] = (address >> 16) & 0xff;
        wBuf[2] = (address >> 8) & 0xff;
        wBuf[3] = address & 0xff;
        APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, wBuf, sizeof(wBuf), buf, sizeof(buf)));
          __WFE();
        address += W25Q32_SECTOR_SIZE;
      return true;
    * Function Name :
    * Parameters :
    * Return :
    * Description : write prohibit function
    void Write_Disable(void)
      const uint8_t wBuff[1] = {W25Q32_DISABLE_ENABLE};
      uint8_t infoBuf[1]={0};
      //  uint8_t flag;
      APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, wBuff, sizeof(wBuff), infoBuf, sizeof(infoBuf)));
        __WFE();
      //  flag = infoBuf[0];
      //  flag &= WRTEN;
      //  return flag;
    * Function Name :
    * Parameters :
    * Return :
    * Description : write "len" bytes from "data" to "address" on W25Q32
    bool W25Q32_writeBytes(uint16_t page_number, uint8_t offset, uint8_t* pdataBuff, size_t length)
      uint8_t buf[1]={0};
      uint8_t wBuff[255]={0};
      size_t pgSize = 256;
    //  uint8_t byteCtr = 0;
      size_t ilen;
    //  ilen = 256-(offset%256);
      while (length > 0)
        /* Wait till previous operation completes */
    //   while((W25Q32_BUSY() == BUSY)&&(W25Q32_WEL() != WRTEN));
    //    nrf_delay_ms(1);
        W25Q32_WEL();
        if(length <ilen)
          ilen = length;
          switch(ilen)
          case 255:
            ilen = ilen-4;
          case 254:
            ilen = ilen-3;
          case 253:
            ilen = ilen-2;
          case 252:
            ilen = ilen-1;
            ilen = length;
          ilen = ilen-5;
        wBuff[0] = W25Q32_PAGE_PROGRAM ;
        wBuff[1] = (address >> 16)&0xff;
        wBuff[2] = (address >> 8)&0xff;
        wBuff[3] = (address)&0xff;
        memcpy(&wBuff[4], pdataBuff, ilen);
          __WFE();
        pdataBuff += ilen;
    //    address += ilen;
        offset += ilen;
        length -= ilen;
    //    while(byteCtr != 255)
    //      wBuff[byteCtr] = 0;
    //      byteCtr++;
    //    byteCtr = 0;
        if((offset != 0)&&(length >0))
          uint8_t len2;
          len2 = pgSize - offset;
    //      W25Q32_Write (page_number, offset, pdataBuff, len2);
          offset += len2;
          page_number++;
    //      pdataBuff += len2;
    //      address += len2;
    //      length -= len2;
    //    ilen = 256;
      return true;
    void W25Q32_Write(uint16_t page_number, uint8_t offset, uint8_t* pdataBuff, uint8_t len)
      uint8_t buf[1]={0};
      //  uint8_t* pArray[2] = {wBuff, pdataBuff};
    //    nrf_delay_ms(1);
        W25Q32_WEL();
      memcpy(&wBuff[4], pdataBuff, len);
        __WFE();
    * Function Name :
    * Parameters :
    * Return :
    * Description : read "len" bytes from "address" to "data" from W25Q32
    bool W25Q32_readBytes(uint16_t page_number, uint8_t offset, uint8_t* pdataBuff , size_t length)
      uint8_t wBuff[4]={0};
      uint8_t buf[255]={0};
      size_t ilen;// = 256-(offset%256);  // Force the first set of bytes to stay within the first page
      while(length>0)
        Write_Disable();
        while ((W25Q32_BUSY() == BUSY));
        if(length<ilen)
          ilen = length;
          switch(ilen)
          case 255:
            ilen = ilen-4;
          case 254:
            ilen = ilen-3;
          case 253:
            ilen = ilen-2;
          case 252:
            ilen = ilen-1;
            ilen = length;
          ilen = ilen-5;
        wBuff[0] = W25Q32_READ_DATA;
          __WFE();
        memcpy(pdataBuff, &buf[4], ilen);
        pdataBuff += ilen;
        offset += ilen;
        length -= ilen;
        ilen = pgSize - offset;
        if((ilen != 0)&&(length>0))
    //      W25Q32_Read (page_number, offset, pdataBuff , ilen);
          offset += ilen;
          page_number++;
    //      pdataBuff += ilen;
    //      length -= ilen;
          ilen = 0;
    //    ilen = 256;
      return true;
    void W25Q32_Read(uint16_t page_number, uint8_t offset, uint8_t* pdataBuff , uint8_t len)
      uint8_t buf[255] ={0};
      Write_Disable();
      while ((W25Q32_BUSY() == BUSY));//&&(Write_Disable() == WRTEN));
        __WFE();
      memcpy(pdataBuff, &buf[4], len);
    void W25Q32_ReadOnlyReg(uint8_t cmd, uint8_t* dummyBytes, uint8_t len1, uint8_t* pdataBuff , uint8_t len2)
      uint8_t wBuff[5];
      wBuff[0] = cmd;
      memcpy(&wBuff[1], dummyBytes, len1);
      APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, wBuff, sizeof(wBuff), pdataBuff,len2));
        __WFE();
    * @brief SPI user event handler.
    * @param event
    void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
                           void *                    p_context)
      spi_xfer_done = true;
    void spi_init(void)
      nrf_drv_spi_config_t spi_config;// = NRF_DRV_SPI_DEFAULT_CONFIG;
      spi_config.ss_pin   = SPIM0_SS_PIN; //P0.5
      spi_config.miso_pin = SPIM0_MISO_PIN; //P0.6
      spi_config.mosi_pin = SPIM0_MOSI_PIN; //P0.3
      spi_config.sck_pin  = SPIM0_SCK_PIN;  //P0.4
      spi_config.frequency = NRF_DRV_SPI_FREQ_4M; //4 Mbps
      spi_config.bit_order = NRF_DRV_SPI_BIT_ORDER_MSB_FIRST; //Most significant bit shifted out first.
      spi_config.irq_priority = 2; // 7 :Interrupt priority.
      spi_config.mode = NRF_DRV_SPI_MODE_3; //SCK active low ((clk polarity)CPOL = 0), sample on trailing edge of clock ((clk phase)CPHA = 0).
      spi_config.orc = 0xFF; //Over-run character.
      APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
    void Write_Shot_Info(uint8_t *data, uint8_t len)
      W25Q32_erase(0, 0, 256);
      W25Q32_writeBytes(0, 0, data, len);
    void Read_Shot_Info(uint8_t *data, uint8_t len)
      W25Q32_readBytes(0, 0, data, len);
    void Write_Shot_Sample(void)
    //  W25Q32_writeBytes(flash.write_page, 0, &sample_buffer[0][0], sizeof(sample_buffer));
      W25Q32_writeBytes(write_page, 0, &sample_buffer[0][0], sizeof(sample_buffer));
      nrf_delay_ms(3);
      //flash.write_page = flash.write_page + 20;
      write_page = write_page + 20;
    void Read_Shot_Sample(void)
      W25Q32_readBytes(read_page, 0, &sample_buffer[0][0], sizeof(sample_buffer));
    //  W25Q32_readBytes(flash.read_page, 0, &sample_buffer[0][0], sizeof(sample_buffer));
      //flash.read_page = flash.read_page + 20;
      read_page = read_page + 20;
  • What IRQ level are you calling the SPI functions from? Where does the code get stuck? Is it in a "while (!spi_xfer_done)"? Or is it an APP_ERROR_CHECK() that returns?
    Or does the code run fine, but it is only the transfer of data that is not working? Have you tried to analyse the MOSI pin, using a logic analyzer or an oscilloscope?
    Would it be possible to send a stripped down version of the product that can reproduce the issue?
    BR,
    Edvin
