NRF51822 Audio Application & Compression
I am working on an application that involves sampling audio data ~8KHz. I have a few questions
  1. The real time clock module has a maximum interrupt frequency of 32768/5 = 6554 Hz. Is there another mechanism to achieve a slightly greater interrupt frequency ~8KHz using the RTC? Or will I need to move to the Timer/Counter. Does nordic provide support for the Timer peripheral like it does for the RTC?
  2. Considering the BLE throughput limitation of the Iphone 5s = 4KB/s I will need to compress the audio data before transmission. Is nordic aware of any codec that works well on the Cortex M0 core of the NRF51822?
Lucas
  • Hi Lucas
    Is the RTC interrupt handler limited to 32768/5 Hz? I haven't heard of that before. The interrupt handler is executed perhaps 3-5 microseconds after the RTC event is triggered and will perhaps take a few microseconds to execute, given your code in the handler is relatively short, so there should be plenty of CPU time available for the RTC interrupt handler to execute with 8kHz frequency or even up to 32kHz frequency.
    Is perhaps something else in your code that is using CPU time, thereby limiting the CPU time left for the RTC interrupt handler. Is your code execution in the RTC interrupt handler perhaps taking a long time to execute, thereby limiting the sampling frequency. Also, if you have softdevice enabled it will limit your sampling rate since the CPU is blocked for 1ms-6ms during a BLE radio event.
  • If you however use the softdevice things are done pretty much automatically for you. When you enable the softdevice you specify which low frequency clock source you want to use. The softdevice also automatically enables the external high frequency crystal when the radio is enabled.
