rssi vial serial communication
Hi All,
1.One master BLE has to connect to Slave BLE, then both device should read other RSSI and sent the data through UART.sending the RSSI should be every 200 millisec or setted time.
please suggest how to achieve this . We have urgent demo to client . please help which profile to use to achieve this ..how to send realtime RSSI values via UART.
thanks in advance
Pavan S K
    I suggest basing this on the ble_app_uart (slave) and ble_app_uart_c (master) examples in the SDK, and use two nRF52832 DK for the demo. I recommened using the latest SDK version 14.2 for this.
    Changes that need to be done one ble_app_uart(slave):
    In function ble_evt_handler() under the event BLE_GAP_EVT_CONNECTED, start the rssi reporting when the connection is established, with sd_ble_gap_rssi_start(m_conn_handle,1,1);
    Define, and implement the rssi app timer used to print the RSSI value:
    APP_TIMER_DEF(m_rssi_timer_id);
    #define RSSI_MEAS_INTERVAL         APP_TIMER_TICKS(200)
    static void rssi_timeout_handler(void * p_context)
        UNUSED_PARAMETER(p_context);
        int8_t p_rssi;
        if(m_conn_handle != BLE_CONN_HANDLE_INVALID)
           if(sd_ble_gap_rssi_get(m_conn_handle,&p_rssi) == NRF_SUCCESS)
            printf("RSSI = %d\r\n",p_rssi);
    In main(), make sure that you create and start the rssi app timer, with app_timer_create() and app_timer_start(). The main() should then look like this:
        uint32_t err_code;
        bool     erase_bonds;
        // Initialize.
        err_code = app_timer_init();
        err_code = app_timer_create(&m_rssi_timer_id,
                                    APP_TIMER_MODE_REPEATED,
                                    rssi_timeout_handler);
        err_code = app_timer_start(m_rssi_timer_id, RSSI_MEAS_INTERVAL, NULL);
        uart_init();
        log_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        printf("\r\nUART Start!\r\n");
        NRF_LOG_INFO("UART Start!");
        err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
        // Enter main loop.
        for (;;)
            UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
            power_manage();
    Use the same method with ble_app_uart_c.
    The RSSI values will be printed over UART. If you have connected the DKs to the PC, open a terminal, such as Termite to view the RSSI values. I have attached the main.c files I used when testing this for both slave and master. I used SDK 14.2 for this.
     * Copyright (c) 2014 - 2017, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_FEATURE_NOT_SUPPORTED       BLE_GATT_STATUS_ATTERR_APP_BEGIN + 2        /**< Reply when unsupported features are requested. */
    #define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_TIMEOUT_IN_SECONDS      180                                         /**< The advertising timeout (in units of seconds). */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    BLE_NUS_DEF(m_nus);        /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_nus    Nordic UART Service structure.
     * @param[in] p_data   Data to be send to UART module.
     * @param[in] length   Length of the data.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length-1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
        uint32_t       err_code;
        ble_nus_init_t nus_init;
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        APP_ERROR_HANDLER(nrf_error);
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                sd_ble_gap_rssi_start(m_conn_handle,1,2);
                NRF_LOG_INFO("Disconnected");
    #ifndef S140
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
    #if !defined (S112)
             case BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST:
                ble_gap_data_length_params_t dl_params;
                // Clearing the struct will effectivly set members to @ref BLE_GAP_DATA_LENGTH_AUTO
                memset(&dl_params, 0, sizeof(ble_gap_data_length_params_t));
                err_code = sd_ble_gap_data_length_update(p_ble_evt->evt.gap_evt.conn_handle, &dl_params, NULL);
            } break;
    #endif //!defined (S112)
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
            case BLE_EVT_USER_MEM_REQUEST:
                err_code = sd_ble_user_mem_reply(p_ble_evt->evt.gattc_evt.conn_handle, NULL);
            case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
                ble_gatts_evt_rw_authorize_request_t  req;
                ble_gatts_rw_authorize_reply_params_t auth_reply;
                req = p_ble_evt->evt.gatts_evt.params.authorize_request;
                if (req.type != BLE_GATTS_AUTHORIZE_TYPE_INVALID)
                    if ((req.request.write.op == BLE_GATTS_OP_PREP_WRITE_REQ)     ||
                        (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_NOW) ||
                        (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL))
                        if (req.type == BLE_GATTS_AUTHORIZE_TYPE_WRITE)
                            auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
                            auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_READ;
                        auth_reply.params.write.gatt_status = APP_FEATURE_NOT_SUPPORTED;
                        err_code = sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle,
        &auth_reply);
            } break; // BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        ret_code_t err_code;
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, 64);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)))
                    do
                        err_code = ble_nus_string_send(&m_nus, data_array, &length);
                        if ( (err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_BUSY) )
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        init.config.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
    /**@brief Function for placing the application in low power state while waiting for events.
    static void power_manage(void)
        uint32_t err_code = sd_app_evt_wait();
        int8_t p_rssi;
    /**@brief Application main function.
        uint32_t err_code;
        bool     erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Enter main loop.
        for (;;)
            power_manage();
     * Copyright (c) 2016 - 2017, Nordic Semiconductor ASA
    #include <stdio.h>
    #include <stdint.h>
    #include <stdbool.h>
    #include "app_error.h"
    #include "ble_db_discovery.h"
    #include "app_util.h"
    #include "ble.h"
    #include "ble_gap.h"
    #include "nrf_pwr_mgmt.h"
    #include "ble_nus_c.h"
    #define APP_BLE_CONN_CFG_TAG    1                                       /**< A tag that refers to the BLE stack configuration we set with @ref sd_ble_cfg_set. Default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
    #define APP_BLE_OBSERVER_PRIO   3                                       /**< Application's BLE observer priority. You shoulnd't need to modify this value. */
    #define SCAN_INTERVAL           0x00A0                                  /**< Determines scan interval in units of 0.625 millisecond. */
    #define SCAN_WINDOW             0x0050                                  /**< Determines scan window in units of 0.625 millisecond. */
    #define SCAN_TIMEOUT            0x0000                                  /**< Timout when scanning. 0x0000 disables timeout. */
    #define MIN_CONNECTION_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS)         /**< Determines minimum connection interval in millisecond. */
    #define MAX_CONNECTION_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS)         /**< Determines maximum connection interval in millisecond. */
    #define SLAVE_LATENCY           0                                       /**< Determines slave latency in counts of connection events. */
    #define SUPERVISION_TIMEOUT     MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Determines supervision time-out in units of 10 millisecond. */
    #define UUID16_SIZE             2                                       /**< Size of 16 bit UUID */
    #define UUID32_SIZE             4                                       /**< Size of 32 bit UUID */
    #define UUID128_SIZE            16                                      /**< Size of 128 bit UUID */
    #define ECHOBACK_BLE_UART_DATA  1                                       /**< Echo the UART data that is received over the Nordic UART Service back to the sender. */
    BLE_NUS_C_DEF(m_ble_nus_c);                                             /**< BLE NUS service client instance. */
    BLE_DB_DISCOVERY_DEF(m_db_disc);                                        /**< DB discovery module instance. */
    static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    /**@brief Connection parameters requested for connection. */
    static ble_gap_conn_params_t const m_connection_param =
        (uint16_t)MIN_CONNECTION_INTERVAL,  // Minimum connection
        (uint16_t)MAX_CONNECTION_INTERVAL,  // Maximum connection
        (uint16_t)SLAVE_LATENCY,            // Slave latency
        (uint16_t)SUPERVISION_TIMEOUT       // Supervision time-out
    /** @brief Parameters used when scanning. */
    static ble_gap_scan_params_t const m_scan_params =
        .active   = 1,
        .interval = SCAN_INTERVAL,
        .window   = SCAN_WINDOW,
        .timeout  = SCAN_TIMEOUT,
        #if (NRF_SD_BLE_API_VERSION <= 2)
            .selective   = 0,
            .p_whitelist = NULL,
        #if (NRF_SD_BLE_API_VERSION >= 3)
            .use_whitelist = 0,
    /**@brief NUS uuid. */
    static ble_uuid_t const m_nus_uuid =
        .uuid = BLE_UUID_NUS_SERVICE,
        .type = NUS_SERVICE_UUID_TYPE
    /**@brief Function for asserts in the SoftDevice.
        app_error_handler(0xDEADBEEF, line_num, p_file_name);
    /**@brief Function to start scanning. */
    static void scan_start(void)
        ret_code_t ret;
        ret = sd_ble_gap_scan_start(&m_scan_params);
        APP_ERROR_CHECK(ret);
        ret = bsp_indication_set(BSP_INDICATE_SCANNING);
    /**@brief Function for handling database discovery events.
     * @details This function is callback function to handle events from the database discovery module.
     *          Depending on the UUIDs that are discovered, this function should forward the events
     *          to their respective services.
     * @param[in] p_event  Pointer to the database discovery event.
    static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
        ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
    /**@brief Function for handling characters received by the Nordic UART Service.
     * @details This function takes a list of characters of length data_len and prints the characters out on UART.
     *          If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
    static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
        ret_code_t ret_val;
        NRF_LOG_DEBUG("Receiving data.");
        NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
        for (uint32_t i = 0; i < data_len; i++)
            do
                ret_val = app_uart_put(p_data[i]);
                if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
                    APP_ERROR_CHECK(ret_val);
            } while (ret_val == NRF_ERROR_BUSY);
        if (p_data[data_len-1] == '\r')
        if (ECHOBACK_BLE_UART_DATA)
            // Send data back to peripheral.
            do
                ret_val = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len);
                    NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
        static uint16_t index = 0;
        uint32_t ret_val;
            /**@snippet [Handling data from UART] */
                index++;
                    do
                        ret_val = ble_nus_c_string_send(&m_ble_nus_c, data_array, index);
                        if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_BUSY) )
                    index = 0;
                NRF_LOG_ERROR("Communication error occurred while handling UART.");
                NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
    /**@brief Callback handling NUS Client events.
     * @details This function is called to notify the application of NUS client events.
     * @param[in]   p_ble_nus_c   NUS Client Handle. This identifies the NUS client
     * @param[in]   p_ble_nus_evt Pointer to the NUS Client event.
    /**@snippet [Handling events from the ble_nus_c module] */
    static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
        switch (p_ble_nus_evt->evt_type)
            case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
                NRF_LOG_INFO("Discovery complete.");
                err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
                err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
                NRF_LOG_INFO("Connected to device with Nordic UART Service.");
            case BLE_NUS_C_EVT_NUS_TX_EVT:
                ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
            case BLE_NUS_C_EVT_DISCONNECTED:
                NRF_LOG_INFO("Disconnected.");
                scan_start();
     * @brief Function for shutdown events.
     * @param[in]   event       Shutdown type.
    static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
        switch (event)
            case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
        return true;
    NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
    /**@brief Reads an advertising report and checks if a UUID is present in the service list.
     * @details The function is able to search for 16-bit, 32-bit and 128-bit service UUIDs.
     *          To see the format of a advertisement packet, see
     *          https://www.bluetooth.org/Technical/AssignedNumbers/generic_access_profile.htm
     * @param[in]   p_target_uuid The UUID to search for.
     * @param[in]   p_adv_report  Pointer to the advertisement report.
     * @retval      true if the UUID is present in the advertisement report. Otherwise false
    static bool is_uuid_present(ble_uuid_t               const * p_target_uuid,
                                ble_gap_evt_adv_report_t const * p_adv_report)
        ble_uuid_t   extracted_uuid;
        uint16_t     index  = 0;
        uint8_t    * p_data = (uint8_t *)p_adv_report->data;
        while (index < p_adv_report->dlen)
            uint8_t field_length = p_data[index];
            uint8_t field_type   = p_data[index + 1];
            if (   (field_type == BLE_GAP_AD_TYPE_16BIT_SERVICE_UUID_MORE_AVAILABLE)
                || (field_type == BLE_GAP_AD_TYPE_16BIT_SERVICE_UUID_COMPLETE))
                for (uint32_t i = 0; i < (field_length / UUID16_SIZE); i++)
                    err_code = sd_ble_uuid_decode(UUID16_SIZE,
                                                  &p_data[i * UUID16_SIZE + index + 2],
                                                  &extracted_uuid);
                    if (err_code == NRF_SUCCESS)
                        if (extracted_uuid.uuid == p_target_uuid->uuid)
                            return true;
            else if (   (field_type == BLE_GAP_AD_TYPE_32BIT_SERVICE_UUID_MORE_AVAILABLE)
                     || (field_type == BLE_GAP_AD_TYPE_32BIT_SERVICE_UUID_COMPLETE))
                for (uint32_t i = 0; i < (field_length / UUID32_SIZE); i++)
                    err_code = sd_ble_uuid_decode(UUID32_SIZE,
                                                  &p_data[i * UUID32_SIZE + index + 2],
                                                  &extracted_uuid);
                        if (   (extracted_uuid.uuid == p_target_uuid->uuid)
                            && (extracted_uuid.type == p_target_uuid->type))
                            return true;
            else if (   (field_type == BLE_GAP_AD_TYPE_128BIT_SERVICE_UUID_MORE_AVAILABLE)
                     || (field_type == BLE_GAP_AD_TYPE_128BIT_SERVICE_UUID_COMPLETE))
                err_code = sd_ble_uuid_decode(UUID128_SIZE, &p_data[index + 2], &extracted_uuid);
                        return true;
            index += field_length + 1;
        return false;
        ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
            case BLE_GAP_EVT_ADV_REPORT:
                ble_gap_evt_adv_report_t const * p_adv_report = &p_gap_evt->params.adv_report;
                if (is_uuid_present(&m_nus_uuid, p_adv_report))
                    err_code = sd_ble_gap_connect(&p_adv_report->peer_addr,
                                                  &m_scan_params,
                                                  &m_connection_param,
                                                  APP_BLE_CONN_CFG_TAG);
                        // scan is automatically stopped by the connect
                        NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
                                 p_adv_report->peer_addr.addr[0],
                                 p_adv_report->peer_addr.addr[1],
                                 p_adv_report->peer_addr.addr[2],
                                 p_adv_report->peer_addr.addr[3],
                                 p_adv_report->peer_addr.addr[4],
                                 p_adv_report->peer_addr.addr[5]
            }break; // BLE_GAP_EVT_ADV_REPORT
                NRF_LOG_INFO("Connected to target");
                err_code = ble_nus_c_handles_assign(&m_ble_nus_c, p_ble_evt->evt.gap_evt.conn_handle, NULL);
                // start discovery of services. The NUS Client waits for a discovery result
                err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
                // Start RSSI reporting and save connection handle
                sd_ble_gap_rssi_start(p_ble_evt->evt.gap_evt.conn_handle,1,2);
            case BLE_GAP_EVT_TIMEOUT:
                if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_SCAN)
                    NRF_LOG_INFO("Scan timed out.");
                    scan_start();
                else if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                    NRF_LOG_INFO("Connection Request timed out.");
                err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
            case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
                // Accepting parameters requested by peer.
                err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                                        &p_gap_evt->params.conn_param_update_request.conn_params);
    #ifndef S140
            } break;
        if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
            NRF_LOG_INFO("ATT MTU exchange completed.");
            NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
        switch (event)
                nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
                err_code = sd_ble_gap_disconnect(m_ble_nus_c.conn_handle,
    /**@brief Function for initializing the UART. */
            .baud_rate    = UART_BAUDRATE_BAUDRATE_Baud115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           err_code);
    /**@brief Function for initializing the NUS Client. */
    static void nus_c_init(void)
        ble_nus_c_init_t init;
        init.evt_handler = ble_nus_c_evt_handler;
        err_code = ble_nus_c_init(&m_ble_nus_c, &init);
    /**@brief Function for initializing buttons and leds. */
    static void buttons_leds_init(void)
        err_code = bsp_init(BSP_INIT_LED, bsp_event_handler);
    /**@brief Function for initializing the timer. */
    static void timer_init(void)
    /**@brief Function for initializing the nrf log module. */
    /**@brief Function for initializing the Power manager. */
    static void power_init(void)
        ret_code_t err_code = nrf_pwr_mgmt_init();
    /** @brief Function for initializing the Database Discovery Module. */
    static void db_discovery_init(void)
        ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
        int8_t p_rssi;
        log_init();
        timer_init();
        power_init();
        uart_init();
        buttons_leds_init();
        db_discovery_init();
        ble_stack_init();
        gatt_init();
        nus_c_init();
        // Start scanning for peripherals and initiate connection
        // with devices that advertise NUS UUID.
        printf("BLE UART central example started.\r\n");
        NRF_LOG_INFO("BLE UART central example started.");
        scan_start();
        for (;;)
                nrf_pwr_mgmt_run();
