sd_softdevice_enable() Hanging on Custom Board
I'm trying develop on a custom board based on the nRF52832 and am running into some issues. When I run the blinky application (with no SD) the application executes fine. However when I try to run the ble_app_blinky application it hangs (no return) when trying to execute the below line:
ret_code = sd_softdevice_enable(&clock_lf_cfg, app_error_fault_handler);
I am using custom hardware with no external LF clock and have made the changes to the application (though I've left the original bootloader) as described here:
https://devzone.nordicsemi.com/f/nordic-q-a/24310/nrf52832-custom-board-power-on-question#post-id-163330
I'm not 100% sure I have the IROM and IRAM settings correct. Could a hardware issue cause the sd_softdevice_enable to hang? If no, what else can cause it to. If yes, then what should I be looking for?
My setup is as follows:
nRF52832 QFAAB0
SDK14.2
SD S132 V5.0.0
IROM Start = 0x23000 Size = 0x5D000
IRAM Start = 0x20002180 Size = 0xDE80
