I'm writing a python script to flash batches of boards with NRF52's.
This is the part of the script that flashes the boards:
def flash_program(hex_file_path, serial_number): # Detect the device family of your device. Initialize an API object with UNKNOWN family and read the device's family # This step is performed so this example can be run in all devices without customer input print "# Opening API with device family NRF52." # Initialize an API object with the target family. This will load nrfjprog.dll with the proper target family. api = API.API('NRF52') try: # Open the loaded DLL and connect to an emulator probe. If several are connected a pop up will appear. api.open() api.connect_to_emu_without_snr(1000) # Erase all the flash of the device. print "# Erasing all flash in the microcontroller." api.erase_all() # Parse the hex file with the help of the HEX module print "# Parsing hex file into segments." test_program = Hex.Hex(hex_file_path) # Program the parsed hex into the device's memory. print('# Writing %s to device.' % hex_file_path) for segment in test_program: api.write(segment.address, segment.data, True) # Free resources test_program = None print "# Writing serial number to memory address 0x10001080, use NVMC" api.write_u32(0x10001080, ctypes.c_uint32(serial_number).value, True) # Read back the serial number print "# Programmed serial number: " + hex(api.read_u32(0x10001080)) # Reset the device and run. api.sys_reset() api.go() print "# Application running." # Close the loaded DLL to free resources. api.close() print "# Programming finished." return 0 except Exception: # Close the loaded DLL to free resources. api.close() return -1
I call that function inside a for-loop until all the boards are flashed. The code works, the boards are flashed, but after a while I get a segmentation fault -11. Is it maybe a memory leak?
Any clues will be appreciated.
