nRF51822 - Radio will not receive (or not even send?)
Hi everyone,
I'm using the nRF51822 (pca10000 Dongle + pca10005). My plan is to send one byte over the radio.
I tried to use the SDK-Example as a template but it's not working for me :-(
My pca10000 Dongle pretends that it has sent my data, but the pca10005 is just waiting for end of packet all the time.
Here some code snippets:
radio.c:
#define PACKET0_S1_SIZE                  (0UL)  //!< S1 size in bits
#define PACKET0_S0_SIZE                  (0UL)  //!< S0 size in bits
#define PACKET0_PAYLOAD_SIZE             (0UL)  //!< payload size in bits
#define PACKET1_BASE_ADDRESS_LENGTH      (4UL)  //!< base address length in bytes
#define PACKET1_STATIC_LENGTH            (1UL)  //!< static length in bytes
#define PACKET1_PAYLOAD_SIZE             (1UL)  //!< payload size in bytes
static uint8_t packet[4];  ///< Packet to transmit
char* receivePacket(void);
void sendPacket(uint8_t addr, char msg);
void radioConfig(short me);
char* msg;
int i = 0;
/* These are set to zero as Shockburst packets don't have corresponding fields. */
#define PACKET_S1_FIELD_SIZE             (0UL)  /**< Packet S1 field size in bits. */
#define PACKET_S0_FIELD_SIZE             (0UL)  /**< Packet S0 field size in bits. */
#define PACKET_LENGTH_FIELD_SIZE         (0UL)  /**< Packet length field size in bits. */
 * @brief Function for swapping/mirroring bits in a byte.
 *@verbatim
 * output_bit_7 = input_bit_0
 * output_bit_6 = input_bit_1
 * output_bit_0 = input_bit_7
 *@endverbatim
 * @param[in] inp is the input byte to be swapped.
 * @return
 * Returns the swapped/mirrored input byte.
static uint32_t swap_bits(uint32_t inp);
 * @brief Function for swapping bits in a 32 bit word for each byte individually.
 * The bits are swapped as follows:
 * @verbatim
 * output[31:24] = input[24:31]
 * output[23:16] = input[16:23]
 * output[15:8]  = input[8:15]
 * output[7:0]   = input[0:7]
 * @endverbatim
 * @param[in] input is the input word to be swapped.
 * @return
 * Returns the swapped input byte.
static uint32_t bytewise_bitswap(uint32_t inp);
    uint32_t i;
    uint32_t retval = 0;
    inp = (inp & 0x000000FFUL);
    for(i = 0; i < 8; i++)
        retval |= ((inp >> i) & 0x01) << (7 - i);
    return retval;
      return (swap_bits(inp >> 24) << 24)
           | (swap_bits(inp >> 16) << 16)
           | (swap_bits(inp >> 8) << 8)
           | (swap_bits(inp));
	static uint8_t volatile packet[4];
	short boolvar = 0;
	  while(1)
		  gpio_set(GPIO_6);
		NRF_RADIO->PACKETPTR = (uint32_t) packet;
	    NRF_RADIO->EVENTS_READY = 0U;
	    // Enable radio and wait for ready
	    NRF_RADIO->TASKS_RXEN = 1U;
	    while(NRF_RADIO->EVENTS_READY == 0U)
	    NRF_RADIO->EVENTS_END = 0U;
	    // Start listening and wait for address received event
	    NRF_RADIO->TASKS_START = 1U;
		  gpio_set(GPIO_1);
	    // Wait for end of packet
	    while(NRF_RADIO->EVENTS_END == 0U)
	    	gpio_toggle(GPIO_6);
        	delay(1*1000*1000);
		  gpio_clear(GPIO_1);
	    // Write received data to LED0 and LED1 on CRC match
	    if (NRF_RADIO->CRCSTATUS == 1U)
	    	msg = packet;
	    	boolvar = 1;
	    NRF_RADIO->EVENTS_DISABLED = 0U;
	    // Disable radio
	    NRF_RADIO->TASKS_DISABLE = 1U;
	    while(NRF_RADIO->EVENTS_DISABLED == 0U)
	        	gpio_clear(GPIO_6);
	        	delay(1*1000*1000);
	    if(boolvar) break;
	    for( int i = 0; i < 10;i++)  {
			delay(0.3*1000*1000);
	return msg;
	LED_GREEN_OFF;
	  // Set payload pointer
	  NRF_RADIO->PACKETPTR = (uint32_t)packet;
	    // Place the read character in the payload, enable the radio and
	    // send the packet:
	    packet[0] = msg;
	    NRF_RADIO->TASKS_TXEN = 1;
	    while (NRF_RADIO->EVENTS_READY == 0U)
	    	delay(5*100*1000);
	    	LED_RED_ON;
	    	delay(5*100*1000);
	    	LED_RED_OFF;
	    	delay(5*100*1000);
	    	LED_BLUE_ON;
	    	delay(5*100*1000);
	    	LED_BLUE_OFF;
	    // Disable radio
LED_GREEN_ON;
	NRF_RADIO->POWER = 0;
	delay(5*100*1000);
	NRF_RADIO->POWER = 1;
	 /* Start 16 MHz crystal oscillator */
	  /* Wait for the external oscillator to start up */
	  while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0)
	  // Radio config
	  if(me != 1) NRF_RADIO->TXPOWER = (RADIO_TXPOWER_TXPOWER_0dBm << RADIO_TXPOWER_TXPOWER_Pos);
	  NRF_RADIO->FREQUENCY = 7UL;                // Frequency bin 7, 2407MHz
	  NRF_RADIO->MODE = (RADIO_MODE_MODE_Nrf_2Mbit << RADIO_MODE_MODE_Pos);
	  // Radio address config
	  /*NRF_RADIO->PREFIX0 = 0xC4C3C2E7UL;  // Prefix byte of addresses 3 to 0
	  NRF_RADIO->PREFIX1 = 0xC5C6C7C8UL;  // Prefix byte of addresses 7 to 4
	          ((uint32_t)swap_bits(0xC3) << 24) // Prefix byte of address 3 converted to nRF24L series format
	        | ((uint32_t)swap_bits(0xC2) << 16) // Prefix byte of address 2 converted to nRF24L series format
	        | ((uint32_t)swap_bits(0xC1) << 8)  // Prefix byte of address 1 converted to nRF24L series format
	        | ((uint32_t)swap_bits(0xC0) << 0); // Prefix byte of address 0 converted to nRF24L series format
	          ((uint32_t)swap_bits(0xC7) << 24) // Prefix byte of address 7 converted to nRF24L series format
	        | ((uint32_t)swap_bits(0xC6) << 16) // Prefix byte of address 6 converted to nRF24L series format
	        | ((uint32_t)swap_bits(0xC4) << 0); // Prefix byte of address 4 converted to nRF24L series format
	  NRF_RADIO->BASE0       = bytewise_bitswap(0x01234567UL);  // Base address for prefix 0 converted to nRF24L series format
	  NRF_RADIO->BASE1       = bytewise_bitswap(0x89ABCDEFUL);  // Base address for prefix 1-7 converted to nRF24L series format
	  if(me == 1)  {
		  NRF_RADIO->TXADDRESS = 0x01UL;      // Set device address 0 to use when transmitting
		  NRF_RADIO->RXADDRESSES = 0x00UL;    // Enable device address 0 to use which receiving
	  else  {
		  NRF_RADIO->TXADDRESS = 0x00UL;      // Set device address 0 to use when transmitting
		  NRF_RADIO->RXADDRESSES = 0x01UL;    // Enable device address 0 to use which receiving
	  // Packet configuration
	  NRF_RADIO->PCNF0 = (PACKET0_S1_SIZE << RADIO_PCNF0_S1LEN_Pos) |
	                     (PACKET0_S0_SIZE << RADIO_PCNF0_S0LEN_Pos) |
	                     (PACKET0_PAYLOAD_SIZE << RADIO_PCNF0_LFLEN_Pos); //lint !e845 "The right argument to operator '|' is certain to be 0"
	   NRF_RADIO->PCNF1 = (RADIO_PCNF1_WHITEEN_Disabled << RADIO_PCNF1_WHITEEN_Pos)    |
	                      (RADIO_PCNF1_ENDIAN_Big << RADIO_PCNF1_ENDIAN_Pos)           |
	                      (PACKET1_BASE_ADDRESS_LENGTH << RADIO_PCNF1_BALEN_Pos)       |
	                      (PACKET1_STATIC_LENGTH << RADIO_PCNF1_STATLEN_Pos)           |
	                      (PACKET1_PAYLOAD_SIZE << RADIO_PCNF1_MAXLEN_Pos); //lint !e845 "The right argument to operator '|' is certain to be 0"
	  // CRC Config
	  NRF_RADIO->CRCCNF = (RADIO_CRCCNF_LEN_Two << RADIO_CRCCNF_LEN_Pos); // Number of checksum bits
	  if ((NRF_RADIO->CRCCNF & RADIO_CRCCNF_LEN_Msk) == (RADIO_CRCCNF_LEN_Two << RADIO_CRCCNF_LEN_Pos))
	    NRF_RADIO->CRCINIT = 0xFFFFUL;      // Initial value
	    NRF_RADIO->CRCPOLY = 0x11021UL;     // CRC poly: x^16+x^12^x^5+1
	  else if ((NRF_RADIO->CRCCNF & RADIO_CRCCNF_LEN_Msk) == (RADIO_CRCCNF_LEN_One << RADIO_CRCCNF_LEN_Pos))
	    NRF_RADIO->CRCINIT = 0xFFUL;        // Initial value
	    NRF_RADIO->CRCPOLY = 0x107UL;       // CRC poly: x^8+x^2^x^1+1
board.c (pca10005 [receiver] - where I use the radio functions):
gpio_init_out(GPIO_6, GPIO_NOPULL);
gpio_init_out(GPIO_1, GPIO_NOPULL);
radioConfig(1);
char* msg = "Hallo";
if(strcmp(msg, "Hallo") == 0)  {
	gpio_set(GPIO_6);
	delay(2*1000*1000);
	gpio_clear(GPIO_6);
delay(2*1000*1000);
msg = receivePacket();
Connected to my gpio's there are just some LEDs
Here the code snippet of board.c of pca10000 Dongle:
	radioConfig(0);
	char msg = 'Q';
while(1) {
	// sending all the time some message
	sendPacket(1, msg);
	delay(3*1000*1000);
Because I already tried many things, come parts of the code maybe seem not relevant. So don't be confused by this :-)
I hope that I can get some tipps, what could went wrong.
Greetings nRF51822
