ble_gap_scan_params_t definition is different than document.
Below is from SDK14.2.0 ble_gap.h
There is no white list variable.
/**@brief GAP scanning parameters. */
typedef struct
  uint8_t  active         : 1;  /**< If 1, perform active scanning (scan requests). */
  uint8_t  use_whitelist  : 1;  /**< If 1, filter advertisers using current active whitelist. */
  uint8_t  adv_dir_report : 1;  /**< If 1, also report directed advertisements where the initiator field is set to a private resolvable address,
                                     even if the address did not resolve to an entry in the device identity list. A report will be generated
                                     even if the peer is not in the whitelist. */
  uint16_t interval;            /**< Scan interval between 0x0004 and 0x4000 in 0.625 ms units (2.5 ms to 10.24 s). */
  uint16_t window;              /**< Scan window between 0x0004 and 0x4000 in 0.625 ms units (2.5 ms to 10.24 s). */
  uint16_t timeout;             /**< Scan timeout between 0x0001 and 0xFFFF in seconds, 0x0000 disables timeout. */
} ble_gap_scan_params_t;
Below is from Nordic SDK document.
Data Fields
uint8_t  active: 1
uint8_t  selective: 1
ble_gap_whitelist_t *  p_whitelist
uint16_t  interval
uint16_t  window
uint16_t  timeout
