Changes needed to start developing Laird BL652 the old way (NRF+Keil)
Hello fellows,
I did my master's thesis with the nrf51 and now some years later I need some help setting up a Laird BL652 to work with my beloved NRF+Keil tools.
Here's what I did and what's working so far:
nrf52840 DK Preview connected to a Laid BL652 via SWD.
Erased all with nRFgo Studio.
Able to flash SD132 and e.g. ble_app_uart example. (The one out of the PCA10040 folder using Keil5) ( nRF5_SDK_14.2.0_17b948a\examples\ble_peripheral\ble_app_uart\pca10040\s132\arm5_no_packs )
I found this document: https://assets.lairdtech.com/home/brandworld/files/Getting%20Started%20with%20DVK-BL652%20and%20Nordic%20SDK%20Development%20using%20Eclipse%20and%20GCC.pdf and changed the pca10040.h
.source= NRF_CLOCK_LF_SRC_XTAL,\
.rc_ctiv= 0,\
.rc_temp_ctiv = 0,\
 lines to
.sourcev= NRF_CLOCK_LF_SRC_RC,\
.rc_ctiv= 16,\
.rc_temp_ctiv = 2,
But it just won't run/start. I can't find it scanning with my mobile using nRF Connect. What/Where else do I need to change stuff or shall I look into?
  • nRF5_SDK\components\softdevice\common\nrf_sdh.c
    I'm routinely using BL652 in my projects ant all I've always needed was chip erase from nRF Go studio. Are you sure that modifying the SDK is necessary?
  • Hi Keton,
    the better way to change the values of clock source is to change only the sdk_config.h in the respective example. this file is located in the respective config directory (i.e. nRF5_SDK_15.0.0_a53641a\examples\ble_peripheral\my_ble_app_blinky\pca10040\s132\config).
    Change the SoftDevice clock configuration to the values specified in the LAIRD documentation like this:
    // </h>
    // <h> Clock - SoftDevice clock configuration
    // <o> NRF_SDH_CLOCK_LF_SRC  - SoftDevice clock source.
    // <0=> NRF_CLOCK_LF_SRC_RC
    // <1=> NRF_CLOCK_LF_SRC_XTAL
    // <2=> NRF_CLOCK_LF_SRC_SYNTH
    #ifndef NRF_SDH_CLOCK_LF_SRC
    #define NRF_SDH_CLOCK_LF_SRC 0
    // <o> NRF_SDH_CLOCK_LF_RC_CTIV - SoftDevice calibration timer interval.
    #ifndef NRF_SDH_CLOCK_LF_RC_CTIV
    #define NRF_SDH_CLOCK_LF_RC_CTIV 16
    // <o> NRF_SDH_CLOCK_LF_RC_TEMP_CTIV - SoftDevice calibration timer interval under constant temperature.
    // <i> How often (in number of calibration intervals) the RC oscillator shall be calibrated
    // <i>  if the temperature has not changed.
    #ifndef NRF_SDH_CLOCK_LF_RC_TEMP_CTIV
    #define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 2
    // <o> NRF_SDH_CLOCK_LF_ACCURACY  - External clock accuracy used in the LL to compute timing.
    // <0=> NRF_CLOCK_LF_ACCURACY_250_PPM
    // <1=> NRF_CLOCK_LF_ACCURACY_500_PPM
    // <2=> NRF_CLOCK_LF_ACCURACY_150_PPM
    // <3=> NRF_CLOCK_LF_ACCURACY_100_PPM
    // <4=> NRF_CLOCK_LF_ACCURACY_75_PPM
    // <5=> NRF_CLOCK_LF_ACCURACY_50_PPM
    // <6=> NRF_CLOCK_LF_ACCURACY_30_PPM
    // <7=> NRF_CLOCK_LF_ACCURACY_20_PPM
    // <8=> NRF_CLOCK_LF_ACCURACY_10_PPM
    // <9=> NRF_CLOCK_LF_ACCURACY_5_PPM
    // <10=> NRF_CLOCK_LF_ACCURACY_2_PPM
    // <11=> NRF_CLOCK_LF_ACCURACY_1_PPM
    #ifndef NRF_SDH_CLOCK_LF_ACCURACY
    #define NRF_SDH_CLOCK_LF_ACCURACY 7
    // </h>
    The relevant lines are:
    So, you do not need to change the SDK.
