I am trying to use the comparator to wake me up when a potentiometer is moved a certain amount.
Before I sleep I read the ADC value of the comparator and use this to set the upper and lower value of the comparator.
My issue is this only works when I move the POT down. For some reason the UP direction is not working.
I am including the NRF_DRV_COMP_EVT_EN_UP_MASK in my nrf_drv_comp_start command. What else needs to be added to get an event when the voltage crosses the upper threshold?
This is using the nRF52832 , SDK14
#define COMPTH_MAX 63
#define COMPTH_INTERVAL 5
void zoom_comp_init(void)
uint32_t err_code;
nrf_saadc_value_t vdd, adcval;
nrf_drv_comp_uninit();
APP_ERROR_CHECK(nrf_drv_saadc_sample_convert(4, &vdd));
APP_ERROR_CHECK(nrf_drv_saadc_sample_convert(0, &adcval));
// hw_adc_disable();
float frac = (float)adcval / (float)vdd;
// ref_setting = frac*16.0;
static uint8_t myrefval = 0; //(0-16)
frac *= 64.0;
myrefval = (uint8_t)frac;
nrf_drv_comp_config_t myCompConfig = NRF_DRV_COMP_DEFAULT_CONFIG(NRF_COMP_INPUT_0);
myCompConfig.input = NRF_COMP_INPUT_0;
myCompConfig.main_mode = NRF_COMP_MAIN_MODE_SE;
myCompConfig.reference = NRF_COMP_REF_VDD;
myCompConfig.speed_mode = NRF_COMP_SP_MODE_Normal;
//myCompConfig.hyst = NRF_COMP_HYST_50mV;
myCompConfig.isource = COMP_ISOURCE_ISOURCE_Off;
myCompConfig.interrupt_priority = 6;
if (myrefval > (COMPTH_MAX - COMPTH_INTERVAL) )
myCompConfig.threshold.th_down = COMPTH_MAX - COMPTH_INTERVAL*2;
myCompConfig.threshold.th_up = COMPTH_MAX;
else if (myrefval < COMPTH_INTERVAL)
myCompConfig.threshold.th_down = 0;
myCompConfig.threshold.th_up = COMPTH_INTERVAL*2;
myCompConfig.threshold.th_down = myrefval - COMPTH_INTERVAL;
myCompConfig.threshold.th_up = myrefval + COMPTH_INTERVAL;
NRF_LOG_INFO("ZOOM | Reference Value=%d", myrefval);
NRF_LOG_INFO("ZOOM | TH_DOWN=%d TH_UP=%d", myCompConfig.threshold.th_down, myCompConfig.threshold.th_up);
err_code = nrf_drv_comp_init(&myCompConfig, comp_event_handler);
nrf_drv_comp_start( NRF_DRV_COMP_EVT_EN_DOWN_MASK | NRF_DRV_COMP_EVT_EN_UP_MASK ,
NRF_DRV_COMP_SHORT_STOP_AFTER_UP_EVT | NRF_DRV_COMP_SHORT_STOP_AFTER_DOWN_EVT | NRF_DRV_COMP_SHORT_STOP_AFTER_CROSS_EVT);
static void comp_event_handler(nrf_comp_event_t event)
asm("nop;");
NRF_LOG_INFO("Comp Event.");
switch (event)
case NRF_COMP_EVENT_CROSS:
NRF_LOG_INFO("Comp CROSS Event.");
sysEvents.zoom_change = 1;
case NRF_COMP_EVENT_DOWN:
// sysEvents.zoom_change = 1;
//if (update_zoom())
NRF_LOG_INFO("Comp DOWN Event.");
case NRF_COMP_EVENT_UP:
NRF_LOG_INFO("Comp UP Event.");
