I'm trying to use the ADC and internal reference to measure battery voltage on the nrf51422, while S210 is enabled.
From the example nrf51-ble-app-temp-master, I found
#define VBAT_MAX_IN_MV 3300 //3.3v - set this to battery max voltage in mV
uint8_t battery_level_get(void) //Returns battery level as a percentage
// Configure ADC
NRF_ADC->CONFIG = (ADC_CONFIG_RES_8bit << ADC_CONFIG_RES_Pos) |
(ADC_CONFIG_INPSEL_SupplyOneThirdPrescaling << ADC_CONFIG_INPSEL_Pos) |
(ADC_CONFIG_REFSEL_VBG << ADC_CONFIG_REFSEL_Pos) |
(ADC_CONFIG_PSEL_Disabled << ADC_CONFIG_PSEL_Pos) |
(ADC_CONFIG_EXTREFSEL_None << ADC_CONFIG_EXTREFSEL_Pos);
NRF_ADC->EVENTS_END = 0;
NRF_ADC->ENABLE = ADC_ENABLE_ENABLE_Enabled;
NRF_ADC->EVENTS_END = 0; // Stop any running conversions.
NRF_ADC->TASKS_START = 1;
while (!NRF_ADC->EVENTS_END)
uint16_t vbg_in_mv = 1200;
uint8_t adc_max = 255;
uint16_t vbat_current_in_mv = (NRF_ADC->RESULT * 3 * vbg_in_mv) / adc_max;
NRF_ADC->TASKS_STOP = 1;
return (uint8_t) ((vbat_current_in_mv * 100) / VBAT_MAX_IN_MV);
However, when I run this in my code, the debugger shows it stalls in the while (!NRF_ADC->EVENTS_END) loop.
What is the chip doing while this loop runs? Any ideas why its stalling, what I need to fix, or a better way of measuring battery level?
Thanks
