How to switch the functions between beacon advertising to connectable advertising?
Hello, I want to switch the functions between beacon advertising to connectable advertising.
In the code , it can be initial as a beacon advertising or normal advertising ( connectable advertising), then switch to another.
My main code as below:
 * @details Encodes the required advertising data and passes it to the stack.
 *          Also builds a structure to be passed to the stack when starting advertising.
void beacon_advertising_init(void)
    uint32_t      err_code;
    ble_advdata_t advdata;
    uint8_t       flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
    ble_advdata_manuf_data_t manuf_specific_data;
    manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
#if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
    // If USE_UICR_FOR_MAJ_MIN_VALUES is defined, the major and minor values will be read from the
    // UICR instead of using the default values. The major and minor values obtained from the UICR
    // are encoded into advertising data in big endian order (MSB First).
    // To set the UICR used by this example to a desired value, write to the address 0x10001080
    // using the nrfjprog tool. The command to be used is as follows.
    // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val <your major/minor value>
    // For example, for a major value and minor value of 0xabcd and 0x0102 respectively, the
    // the following command should be used.
    // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val 0xabcd0102
    uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
    uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
    uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
    m_beacon_info[index++] = MSB_16(major_value);
    m_beacon_info[index++] = LSB_16(major_value);
    m_beacon_info[index++] = MSB_16(minor_value);
    m_beacon_info[index++] = LSB_16(minor_value);
    manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
    manuf_specific_data.data.size   = APP_BEACON_INFO_LENGTH;
    // Build and set advertising data.
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type             = BLE_ADVDATA_NO_NAME;
    advdata.flags                 = flags;
    advdata.p_manuf_specific_data = &manuf_specific_data;
    err_code = ble_advdata_set(&advdata, NULL);
    // Initialize advertising parameters (used when starting advertising).
    memset(&m_adv_params, 0, sizeof(m_adv_params));
    m_adv_params.type        = BLE_GAP_ADV_TYPE_ADV_NONCONN_IND;
    m_adv_params.p_peer_addr = NULL;    // Undirected advertisement.
    m_adv_params.fp          = BLE_GAP_ADV_FP_ANY;
    m_adv_params.interval    = NON_CONNECTABLE_ADV_INTERVAL;
    m_adv_params.timeout     = 0;       // Never time out.
void beacon_advertising_start(void)
    ret_code_t err_code;
    err_code = sd_ble_gap_adv_start(&m_adv_params, APP_BLE_CONN_CFG_TAG);
    ble_advertising_init_t init;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = true;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
    init.config.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
static void advertising_start(bool erase_bonds)
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED evetnt
        ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
void app_ble_advertising_init(void)
	bool erase_bonds;
    ble_stack_init();
    gap_params_init();
    gatt_init();
    advertising_init();
    services_init();
    conn_params_init();
    peer_manager_init();
    // Start execution.
    NRF_LOG_INFO("Template example started.");
    application_timers_start();
    advertising_start(erase_bonds);
void app_ble_beacon_init(void)
	ble_stack_init();
	beacon_advertising_init();
	beacon_advertising_start();
    bool erase_bonds;
    // Initialize.
    log_init();
    timers_init();
	app_ble_beacon_init();
	while(1)
	    nrf_delay_ms(5000);
		sd_ble_gap_adv_stop();      // Here I want to stop the beacon advertisingadvertising.
		nrf_delay_ms(5000);
		app_ble_advertising_init(); // Here I want to start the connectable advertising ,but code error and restart.
		while(1);
The test board is PCA10040, which main chip is nRF52832.
Now I can start the beacon advertising, then stop it, then restart it , in the main cycle.
I can start the connectable advertising normally.
But I can't switch the two functions to each other.
How can I switch them successfully?
Thank you!
  • Hey cadillacxlr,
    You need to stop advertisements by calling sd_ble_gap_adv_stop,  change the advertisement data with sd_ble_gap_adv_data_set, and finnaly restart advertisements with sd_ble_gap_adv_start.
    Cheers,
    Håkon.
  • Thanks for your reply! And I notice that if the function "ble_stack_init()" is called twice, the chip will restart.
    Now in my code, I can switch the two advertising mode smoothly. Thank you very much!
  • Hello, main code as belows:
            delete_bonds();
    void systick_handler(void * p_context)
    	bool erase_bonds;
        ble_stack_init();
        gap_params_init();
        gatt_init();
        advertising_init();
        services_init();
        conn_params_init();
        // Start execution.
    void change_to_app_ble_advertising_init(void)
    	bool erase_bonds;
    	gap_params_init();
        gatt_init();
        advertising_init();
        services_init();
        conn_params_init();
    	ble_stack_init();
    void change_to_app_ble_beacon_init(void)
    /**@brief Function for application main entry.
    uint8_t press_flag_3, press_flag_4;
        bool erase_bonds;
        // Initialize.
        log_init();
        timers_init();
    	ble_stack_init();
    	while(1)
    		change_to_app_ble_advertising_init();
    		nrf_delay_ms(2000);
    		nrf_delay_ms(200);
    		change_to_app_ble_beacon_init();
    		nrf_gpio_pin_write(LED_2,0);
    		nrf_delay_ms(2000);
    		nrf_delay_ms(200);
