Hello everybody,
I used SDK14.2 S132
I defined fds_write and read function like that;
static ret_code_t kls_fds_write(uint32_t file_id, uint32_t record_key , uint8_t write_data[], uint16_t length)
fds_record_t record;
fds_record_desc_t record_desc;
// Set up record.
record.file_id = file_id;
record.key = record_key;
record.data.p_data = &write_data;
record.data.length_words = length;
ret_code_t rc;
rc = fds_record_write(&record_desc, &record);
if (rc != FDS_SUCCESS)
/* Handle error. */
NRF_LOG_INFO("FDS Write Handle error.");
return rc;
NRF_LOG_INFO("Writing Record ID = %d \r\n",record_desc.record_id);
return NRF_SUCCESS;
static ret_code_t kls_fds_read(uint32_t file_id, uint32_t record_key , uint8_t read_data[])
fds_flash_record_t flash_record;
fds_find_token_t ftok;
/* It is required to zero the token before first use. */
memset(&ftok, 0x00, sizeof(fds_find_token_t));
uint32_t *data;
uint32_t err_code;
NRF_LOG_INFO("Start searching... \r\n");
// Loop until all records with the given key and file ID have been found.
while (fds_record_find(file_id, record_key, &record_desc, &ftok) == FDS_SUCCESS)
err_code = fds_record_open(&record_desc, &flash_record);
if ( err_code != FDS_SUCCESS)
return err_code;
NRF_LOG_INFO("Found Record ID = %d\r\n",record_desc.record_id);
NRF_LOG_INFO("Data = ");
data = (uint32_t *) flash_record.p_data;
for (uint8_t i=0;i<flash_record.p_header->length_words;i++)
NRF_LOG_INFO("0x%8x ",data[i]);
read_data[i] = data[i] ;
NRF_LOG_INFO("\r\n");
// Access the record through the flash_record structure.
// Close the record when done.
err_code = fds_record_close(&record_desc);
if (err_code != FDS_SUCCESS)
return err_code;
return NRF_SUCCESS;
Also, I wrote a function to register particular data;
static void save_data( uint8_t *p_data)
NRF_LOG_INFO("save_data");
uint8_t source_data_0[10] ;
// assign source datas ********************************
for (uint32_t i = 0; i < 10; i++)
source_data_0[i] = p_data[i];
while (flag_write_fds == false);
kls_fds_write(FILE_ID, RECORD_KEY ,source_data_0, 10);
NRF_LOG_RAW_HEXDUMP_INFO(source_data_0, 10);
allow_advertisement = false;
Then I used save_data like this;
save_data(nus_data_array);
Then I read data via fds_read
while (flag_write_fds == 0);
kls_fds_read(FILE_ID_SSN, RECORD_KEY_SSN, dest_data_0);
NRF_LOG_INFO("dest_data_0 : ");
NRF_LOG_HEXDUMP_INFO(dest_data_0, 10);
As a result;
0> <info> app: save_data
0> <info> app: Writing Record ID = 1
0>
0> 41 30 31 31 30 30 30 34|A0110004
0> 30 00 |0.
This is exactly what I want it to be. There is no problem, But when I want to read save_data array;
Result is;
0> <info> app: Start searching...
0> <info> app: Found Record ID = 1
0>
0> <info> app: Data =
0> <info> app: 0x20005CC8
0> <info> app: 0x 9731
0> <info> app: 0x20005CE8
0> <info> app: 0x 971B
0> <info> app: 0x 29
0> <info> app: 0x 0
0> <info> app: 0x200027B0
0> <info> app: 0x 2
0> <info> app: 0x 12A3
0> <info> app:
0>
0> <info> app: dest_data_0 :
0> <info> app: C8 31 C8 E8 1B 29 00 B0|È1Èè.).°
0> <info> app: 02 A3 |.£
It's a meaningless result.
Q1- Is the problem reading data or writing data or all of them?
Q2- What do I need to do to correctly write and read the data?
