What should I start in order to use the maximum memory space in fstorage?
Hello everybody,
I just started using fStorage. When I examine the example, it starts from write address 0x3e000.
err_code = nrf_fstorage_write(&fstorage, 0x3e000, m_hello_world, sizeof(m_hello_world), NULL);
Q-1 How is this write address determined?
Q-2 For example, when I write12 bytes data, what should I start with the next write address?
Thank you.
  • FormerMember
    0 FormerMember
    I would think that the address 0x3e000 is chosen arbitrary. If you want to store data to flash, I would recommend you to use the  FDS module (Flash Data Storage). FDS provides an easy-to-use interface for storing and handling stored data. FDS uses fstorage.
    FDS stores data in the last flash pages available.
  • Thanks for your answer, Kristin. Unfortunately,I could not use FDS. I tried so hard to use it, but I failed. If you want to look my question that is related to FDS, you can find in this LINK .
  • FormerMember
    0 FormerMember in reply to purgoufr
    Okay, I see. So what you really want to do is to write a an array to flash and then retrieve it again? If so, you can do that the following way:
    static ret_code_t fds_read(void)
    		fds_flash_record_t  flash_record;
    		fds_record_desc_t   record_desc;
    		fds_find_token_t    ftok ={0};//Important, make sure you zero init the ftok token
    		uint8_t *data;
    		uint32_t err_code;
    		NRF_LOG_INFO("Start searching... \r\n");
    		// Loop until all records with the given key and file ID have been found.
    		while (fds_record_find(FILE_ID_FDS_TEST, REC_KEY_FDS_TEST, &record_desc, &ftok) == FDS_SUCCESS)
    				err_code = fds_record_open(&record_desc, &flash_record);
    				if ( err_code != FDS_SUCCESS)
    					return err_code;
    				NRF_LOG_INFO("Found Record ID = %d\r\n",record_desc.record_id);
    				NRF_LOG_INFO("Data = ");
    				data = (uint8_t *) flash_record.p_data;
    				for (uint8_t i=0;i<flash_record.p_header->length_words;i++)
    					NRF_LOG_INFO("0x%8x ",data[i]);
    				NRF_LOG_INFO("\r\n");
    				// Access the record through the flash_record structure.
    				// Close the record when done.
    				err_code = fds_record_close(&record_desc);
    				if (err_code != FDS_SUCCESS)
    					return err_code;
    		return NRF_SUCCESS;
    To easily test it, you can replace main.c in ble_app_hrs in SDK 14.2 by this file:
     * Copyright (c) 2014 - 2017, Nordic Semiconductor ASA
     * All rights reserved.
    /** @example examples/ble_peripheral/ble_app_hrs/main.c
     * @brief Heart Rate Service Sample Application main file.
     * This file contains the source code for a sample application using the Heart Rate service
     * (and also Battery and Device Information services). This application uses the
     * @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "nrf_sdm.h"
    #include "app_error.h"
    #include "ble.h"
    #include "ble_err.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_bas.h"
    #include "ble_hrs.h"
    #include "ble_dis.h"
    #include "ble_conn_params.h"
    #include "sensorsim.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_sdh_soc.h"
    #include "app_timer.h"
    #include "bsp_btn_ble.h"
    #include "peer_manager.h"
    #include "fds.h"
    #include "nrf_ble_gatt.h"
    #include "ble_conn_state.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    /***  Used for testing FDS ***/
    static volatile uint8_t write_flag_fds_test = 0;
    #define FILE_ID_FDS_TEST     0x1111
    #define REC_KEY_FDS_TEST     0x2222
    #define DEVICE_NAME                         "Nordic_HRM"                            /**< Name of device. Will be included in the advertising data. */
    #define MANUFACTURER_NAME                   "NordicSemiconductor"                   /**< Manufacturer. Will be passed to Device Information Service. */
    #define APP_ADV_INTERVAL                    300                                     /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
    #define APP_ADV_TIMEOUT_IN_SECONDS          180                                     /**< The advertising timeout in units of seconds. */
    #define APP_BLE_CONN_CFG_TAG                1                                       /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_BLE_OBSERVER_PRIO               3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define BATTERY_LEVEL_MEAS_INTERVAL         APP_TIMER_TICKS(2000)                   /**< Battery level measurement interval (ticks). */
    #define MIN_BATTERY_LEVEL                   81                                      /**< Minimum simulated battery level. */
    #define MAX_BATTERY_LEVEL                   100                                     /**< Maximum simulated 7battery level. */
    #define BATTERY_LEVEL_INCREMENT             1                                       /**< Increment between each simulated battery level measurement. */
    #define HEART_RATE_MEAS_INTERVAL            APP_TIMER_TICKS(1000)                   /**< Heart rate measurement interval (ticks). */
    #define MIN_HEART_RATE                      140                                     /**< Minimum heart rate as returned by the simulated measurement function. */
    #define MAX_HEART_RATE                      300                                     /**< Maximum heart rate as returned by the simulated measurement function. */
    #define HEART_RATE_INCREMENT                10                                      /**< Value by which the heart rate is incremented/decremented for each call to the simulated measurement function. */
    #define RR_INTERVAL_INTERVAL                APP_TIMER_TICKS(300)                    /**< RR interval interval (ticks). */
    #define MIN_RR_INTERVAL                     100                                     /**< Minimum RR interval as returned by the simulated measurement function. */
    #define MAX_RR_INTERVAL                     500                                     /**< Maximum RR interval as returned by the simulated measurement function. */
    #define RR_INTERVAL_INCREMENT               1                                       /**< Value by which the RR interval is incremented/decremented for each call to the simulated measurement function. */
    #define SENSOR_CONTACT_DETECTED_INTERVAL    APP_TIMER_TICKS(5000)                   /**< Sensor Contact Detected toggle interval (ticks). */
    #define MIN_CONN_INTERVAL                   MSEC_TO_UNITS(400, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.4 seconds). */
    #define MAX_CONN_INTERVAL                   MSEC_TO_UNITS(650, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (0.65 second). */
    #define SLAVE_LATENCY                       0                                       /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                    MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory timeout (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY      APP_TIMER_TICKS(5000)                   /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY       APP_TIMER_TICKS(30000)                  /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT        3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
    #define SEC_PARAM_BOND                      1                                       /**< Perform bonding. */
    #define SEC_PARAM_MITM                      0                                       /**< Man In The Middle protection not required. */
    #define SEC_PARAM_LESC                      0                                       /**< LE Secure Connections not enabled. */
    #define SEC_PARAM_KEYPRESS                  0                                       /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES           BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
    #define SEC_PARAM_OOB                       0                                       /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE              7                                       /**< Minimum encryption key size. */
    #define SEC_PARAM_MAX_KEY_SIZE              16                                      /**< Maximum encryption key size. */
    #define DEAD_BEEF                           0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define APP_FEATURE_NOT_SUPPORTED           BLE_GATT_STATUS_ATTERR_APP_BEGIN + 2    /**< Reply when unsupported features are requested. */
    BLE_HRS_DEF(m_hrs);                                                 /**< Heart rate service instance. */
    BLE_BAS_DEF(m_bas);                                                 /**< Structure used to identify the battery service. */
    NRF_BLE_GATT_DEF(m_gatt);                                           /**< GATT module instance. */
    BLE_ADVERTISING_DEF(m_advertising);                                 /**< Advertising module instance. */
    APP_TIMER_DEF(m_battery_timer_id);                                  /**< Battery timer. */
    APP_TIMER_DEF(m_heart_rate_timer_id);                               /**< Heart rate measurement timer. */
    APP_TIMER_DEF(m_rr_interval_timer_id);                              /**< RR interval timer. */
    APP_TIMER_DEF(m_sensor_contact_timer_id);                           /**< Sensor contact detected timer. */
    static uint16_t m_conn_handle         = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
    static bool     m_rr_interval_enabled = true;                       /**< Flag for enabling and disabling the registration of new RR interval measurements (the purpose of disabling this is just to test sending HRM without RR interval data. */
    static sensorsim_cfg_t   m_battery_sim_cfg;                         /**< Battery Level sensor simulator configuration. */
    static sensorsim_state_t m_battery_sim_state;                       /**< Battery Level sensor simulator state. */
    static sensorsim_cfg_t   m_heart_rate_sim_cfg;                      /**< Heart Rate sensor simulator configuration. */
    static sensorsim_state_t m_heart_rate_sim_state;                    /**< Heart Rate sensor simulator state. */
    static sensorsim_cfg_t   m_rr_interval_sim_cfg;                     /**< RR Interval sensor simulator configuration. */
    static sensorsim_state_t m_rr_interval_sim_state;                   /**< RR Interval sensor simulator state. */
    static ble_uuid_t m_adv_uuids[] =                                   /**< Universally unique service identifiers. */
        {BLE_UUID_HEART_RATE_SERVICE,           BLE_UUID_TYPE_BLE},
        {BLE_UUID_BATTERY_SERVICE,              BLE_UUID_TYPE_BLE},
        {BLE_UUID_DEVICE_INFORMATION_SERVICE,   BLE_UUID_TYPE_BLE}
    /**@brief Callback function for asserts in the SoftDevice.
     * @param[in] line_num   Line number of the failing ASSERT call.
     * @param[in] file_name  File name of the failing ASSERT call.
    /**@brief Clear bond information from persistent storage.
    static void delete_bonds(void)
        ret_code_t err_code;
        NRF_LOG_INFO("Erase bonds!");
        err_code = pm_peers_delete();
    void advertising_start(bool erase_bonds)
        if (erase_bonds == true)
            delete_bonds();
            // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
            err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    /**@brief Function for handling File Data Storage events.
     * @param[in] p_evt  Peer Manager event.
     * @param[in] cmd
    static void fds_evt_handler(fds_evt_t const * const p_evt)
        if (p_evt->id == FDS_EVT_GC)
            NRF_LOG_DEBUG("GC completed\n");
    /**@brief Function for handling Peer Manager events.
    static void pm_evt_handler(pm_evt_t const * p_evt)
        switch (p_evt->evt_id)
            case PM_EVT_BONDED_PEER_CONNECTED:
                NRF_LOG_INFO("Connected to a previously bonded device.");
            } break;
            case PM_EVT_CONN_SEC_SUCCEEDED:
                NRF_LOG_INFO("Connection secured: role: %d, conn_handle: 0x%x, procedure: %d.",
                             ble_conn_state_role(p_evt->conn_handle),
                             p_evt->conn_handle,
                             p_evt->params.conn_sec_succeeded.procedure);
            } break;
            case PM_EVT_CONN_SEC_FAILED:
                /* Often, when securing fails, it shouldn't be restarted, for security reasons.
                 * Other times, it can be restarted directly.
                 * Sometimes it can be restarted, but only after changing some Security Parameters.
                 * Sometimes, it cannot be restarted until the link is disconnected and reconnected.
                 * Sometimes it is impossible, to secure the link, or the peer device does not support it.
                 * How to handle this error is highly application dependent. */
            } break;
            case PM_EVT_CONN_SEC_CONFIG_REQ:
                // Reject pairing request from an already bonded peer.
                pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false};
                pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
            } break;
            case PM_EVT_STORAGE_FULL:
                // Run garbage collection on the flash.
                err_code = fds_gc();
                if (err_code == FDS_ERR_BUSY || err_code == FDS_ERR_NO_SPACE_IN_QUEUES)
                    // Retry.
            } break;
                NRF_LOG_DEBUG("PM_EVT_PEERS_DELETE_SUCCEEDED");
                advertising_start(false);
            } break;
            case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED:
                // The local database has likely changed, send service changed indications.
                pm_local_database_has_changed();
            } break;
            case PM_EVT_PEER_DATA_UPDATE_FAILED:
                // Assert.
                APP_ERROR_CHECK(p_evt->params.peer_data_update_failed.error);
            } break;
            case PM_EVT_PEER_DELETE_FAILED:
                // Assert.
                APP_ERROR_CHECK(p_evt->params.peer_delete_failed.error);
            } break;
            case PM_EVT_PEERS_DELETE_FAILED:
                // Assert.
                APP_ERROR_CHECK(p_evt->params.peers_delete_failed_evt.error);
            } break;
            case PM_EVT_ERROR_UNEXPECTED:
                // Assert.
                APP_ERROR_CHECK(p_evt->params.error_unexpected.error);
            } break;
            case PM_EVT_CONN_SEC_START:
            case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
            case PM_EVT_PEER_DELETE_SUCCEEDED:
            case PM_EVT_LOCAL_DB_CACHE_APPLIED:
            case PM_EVT_SERVICE_CHANGED_IND_SENT:
            case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED:
    /**@brief Function for performing battery measurement and updating the Battery Level characteristic
     *        in Battery Service.
    static void battery_level_update(void)
        uint8_t  battery_level;
        battery_level = (uint8_t)sensorsim_measure(&m_battery_sim_state, &m_battery_sim_cfg);
        err_code = ble_bas_battery_level_update(&m_bas, battery_level);
        if ((err_code != NRF_SUCCESS) &&
            (err_code != NRF_ERROR_INVALID_STATE) &&
            (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
            APP_ERROR_HANDLER(err_code);
    /**@brief Function for handling the Battery measurement timer timeout.
     * @details This function will be called each time the battery level measurement timer expires.
     * @param[in] p_context  Pointer used for passing some arbitrary information (context) from the
     *                       app_start_timer() call to the timeout handler.
    static void battery_level_meas_timeout_handler(void * p_context)
        UNUSED_PARAMETER(p_context);
        battery_level_update();
    /**@brief Function for handling the Heart rate measurement timer timeout.
     * @details This function will be called each time the heart rate measurement timer expires.
     *          It will exclude RR Interval data from every third measurement.
    static void heart_rate_meas_timeout_handler(void * p_context)
        static uint32_t cnt = 0;
        uint16_t        heart_rate;
        heart_rate = (uint16_t)sensorsim_measure(&m_heart_rate_sim_state, &m_heart_rate_sim_cfg);
        cnt++;
        err_code = ble_hrs_heart_rate_measurement_send(&m_hrs, heart_rate);
        // Disable RR Interval recording every third heart rate measurement.
        // NOTE: An application will normally not do this. It is done here just for testing generation
        // of messages without RR Interval measurements.
        m_rr_interval_enabled = ((cnt % 3) != 0);
    /**@brief Function for handling the RR interval timer timeout.
     * @details This function will be called each time the RR interval timer expires.
    static void rr_interval_timeout_handler(void * p_context)
        if (m_rr_interval_enabled)
            uint16_t rr_interval;
            rr_interval = (uint16_t)sensorsim_measure(&m_rr_interval_sim_state,
                                                      &m_rr_interval_sim_cfg);
            ble_hrs_rr_interval_add(&m_hrs, rr_interval);
    /**@brief Function for handling the Sensor Contact Detected timer timeout.
     * @details This function will be called each time the Sensor Contact Detected timer expires.
    static void sensor_contact_detected_timeout_handler(void * p_context)
        static bool sensor_contact_detected = false;
        sensor_contact_detected = !sensor_contact_detected;
        ble_hrs_sensor_contact_detected_update(&m_hrs, sensor_contact_detected);
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module. This creates and starts application timers.
    static void timers_init(void)
        // Initialize timer module.
        err_code = app_timer_init();
        // Create timers.
        err_code = app_timer_create(&m_battery_timer_id,
                                    APP_TIMER_MODE_REPEATED,
                                    battery_level_meas_timeout_handler);
        err_code = app_timer_create(&m_heart_rate_timer_id,
                                    heart_rate_meas_timeout_handler);
        err_code = app_timer_create(&m_rr_interval_timer_id,
                                    rr_interval_timeout_handler);
        err_code = app_timer_create(&m_sensor_contact_timer_id,
                                    sensor_contact_detected_timeout_handler);
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
        err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_HEART_RATE_SENSOR_HEART_RATE_BELT);
    /**@brief GATT module event handler.
    static void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
            NRF_LOG_INFO("GATT ATT MTU on connection 0x%x changed to %d.",
                         p_evt->conn_handle,
                         p_evt->params.att_mtu_effective);
        ble_hrs_on_gatt_evt(&m_hrs, p_evt);
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
     * @details Initialize the Heart Rate, Battery and Device Information services.
        ble_hrs_init_t hrs_init;
        ble_bas_init_t bas_init;
        ble_dis_init_t dis_init;
        uint8_t        body_sensor_location;
        // Initialize Heart Rate Service.
        body_sensor_location = BLE_HRS_BODY_SENSOR_LOCATION_FINGER;
        memset(&hrs_init, 0, sizeof(hrs_init));
        hrs_init.evt_handler                 = NULL;
        hrs_init.is_sensor_contact_supported = true;
        hrs_init.p_body_sensor_location      = &body_sensor_location;
        // Here the sec level for the Heart Rate Service can be changed/increased.
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&hrs_init.hrs_hrm_attr_md.cccd_write_perm);
        BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_hrm_attr_md.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_hrm_attr_md.write_perm);
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&hrs_init.hrs_bsl_attr_md.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_bsl_attr_md.write_perm);
        err_code = ble_hrs_init(&m_hrs, &hrs_init);
        // Initialize Battery Service.
        memset(&bas_init, 0, sizeof(bas_init));
        // Here the sec level for the Battery Service can be changed/increased.
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_char_attr_md.cccd_write_perm);
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_char_attr_md.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&bas_init.battery_level_char_attr_md.write_perm);
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_report_read_perm);
        bas_init.evt_handler          = NULL;
        bas_init.support_notification = true;
        bas_init.p_report_ref         = NULL;
        bas_init.initial_batt_level   = 100;
        err_code = ble_bas_init(&m_bas, &bas_init);
        // Initialize Device Information Service.
        memset(&dis_init, 0, sizeof(dis_init));
        ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, (char *)MANUFACTURER_NAME);
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&dis_init.dis_attr_md.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&dis_init.dis_attr_md.write_perm);
        err_code = ble_dis_init(&dis_init);
    /**@brief Function for initializing the sensor simulators.
    static void sensor_simulator_init(void)
        m_battery_sim_cfg.min          = MIN_BATTERY_LEVEL;
        m_battery_sim_cfg.max          = MAX_BATTERY_LEVEL;
        m_battery_sim_cfg.incr         = BATTERY_LEVEL_INCREMENT;
        m_battery_sim_cfg.start_at_max = true;
        sensorsim_init(&m_battery_sim_state, &m_battery_sim_cfg);
        m_heart_rate_sim_cfg.min          = MIN_HEART_RATE;
        m_heart_rate_sim_cfg.max          = MAX_HEART_RATE;
        m_heart_rate_sim_cfg.incr         = HEART_RATE_INCREMENT;
        m_heart_rate_sim_cfg.start_at_max = false;
        sensorsim_init(&m_heart_rate_sim_state, &m_heart_rate_sim_cfg);
        m_rr_interval_sim_cfg.min          = MIN_RR_INTERVAL;
        m_rr_interval_sim_cfg.max          = MAX_RR_INTERVAL;
        m_rr_interval_sim_cfg.incr         = RR_INTERVAL_INCREMENT;
        m_rr_interval_sim_cfg.start_at_max = false;
        sensorsim_init(&m_rr_interval_sim_state, &m_rr_interval_sim_cfg);
    /**@brief Function for starting application timers.
    static void application_timers_start(void)
        // Start application timers.
        err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
        err_code = app_timer_start(m_heart_rate_timer_id, HEART_RATE_MEAS_INTERVAL, NULL);
        err_code = app_timer_start(m_rr_interval_timer_id, RR_INTERVAL_INTERVAL, NULL);
        err_code = app_timer_start(m_sensor_contact_timer_id, SENSOR_CONTACT_DETECTED_INTERVAL, NULL);
    /**@brief Function for handling the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module which
     *          are passed to the application.
     *          @note All this function does is to disconnect. This could have been done by simply
     *                setting the disconnect_on_fail config parameter, but instead we use the event
     *                handler mechanism to demonstrate its use.
    /**@brief Function for handling a Connection Parameters error.
        APP_ERROR_HANDLER(nrf_error);
        cp_init.start_on_notify_cccd_handle    = m_hrs.hrm_handles.cccd_handle;
        // Prepare wakeup buttons.
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
                NRF_LOG_INFO("Fast advertising.");
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected.");
                NRF_LOG_INFO("Disconnected, reason %d.",
                              p_ble_evt->evt.gap_evt.params.disconnected.reason);
    #ifndef S140
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
            case BLE_EVT_USER_MEM_REQUEST:
                err_code = sd_ble_user_mem_reply(m_conn_handle, NULL);
            case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
                ble_gatts_evt_rw_authorize_request_t  req;
                ble_gatts_rw_authorize_reply_params_t auth_reply;
                req = p_ble_evt->evt.gatts_evt.params.authorize_request;
                if (req.type != BLE_GATTS_AUTHORIZE_TYPE_INVALID)
                    if ((req.request.write.op == BLE_GATTS_OP_PREP_WRITE_REQ)     ||
                        (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_NOW) ||
                        (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL))
                        if (req.type == BLE_GATTS_AUTHORIZE_TYPE_WRITE)
                            auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
                            auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_READ;
                        auth_reply.params.write.gatt_status = APP_FEATURE_NOT_SUPPORTED;
                        err_code = sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle,
        &auth_reply);
            } break;
                // No implementation needed.
        uint32_t ram_start = 0;
        // Enable BLE stack.
     * @param[in]   event   Event generated by button press.
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
            case BSP_EVENT_WHITELIST_OFF:
    /**@brief Function for the Peer Manager initialization.
    static void peer_manager_init(void)
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        sec_param.kdist_own.enc  = 1;
        sec_param.kdist_own.id   = 1;
        sec_param.kdist_peer.enc = 1;
        sec_param.kdist_peer.id  = 1;
        err_code = fds_register(fds_evt_handler);
        ble_advertising_init_t init;
        init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
        init.advdata.include_appearance      = true;
        init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
        init.config.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
        bsp_event_t startup_event;
        err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
    /**@brief Function for the Power manager.
    static void power_manage(void)
        ret_code_t err_code = sd_app_evt_wait();
    static void my_fds_evt_handler(fds_evt_t const * const p_fds_evt)
        switch (p_fds_evt->id)
            case FDS_EVT_INIT:
                if (p_fds_evt->result != FDS_SUCCESS)
                    // Initialization failed.
    				case FDS_EVT_WRITE:
    						if (p_fds_evt->result == FDS_SUCCESS)
    							write_flag_fds_test=1;
    static ret_code_t fds_test_write(void)
    		//static uint32_t const m_deadbeef[2] = {0xDEADBEEF,0xBAADF00D};
    		static uint8_t const m_deadbeef[4] = {0x1,0x2,0x3,0x4};
    		fds_record_t        record;
    		// Set up data.
    		// Set up record.
    		record.file_id              = FILE_ID_FDS_TEST;
    		record.key              		= REC_KEY_FDS_TEST;
    		record.data.p_data       = &m_deadbeef;
    		//record.data.length_words   = sizeof(m_deadbeef)/sizeof(uint32_t);
    		record.data.length_words   = sizeof(m_deadbeef)/sizeof(uint8_t);
    		ret_code_t ret = fds_record_write(&record_desc, &record);
    		if (ret != FDS_SUCCESS)
    				return ret;
    		 NRF_LOG_INFO("Writing Record ID = %d \r\n",record_desc.record_id);
    		return NRF_SUCCESS;
    		//uint32_t *data;
    		uint8_t *data;
    		uint32_t err_code;
    					return err_code;
    				//data = (uint32_t *) flash_record.p_data;
    					return err_code;
    		return NRF_SUCCESS;
    static ret_code_t fds_test_find_and_delete (void)
    		fds_find_token_t    ftok;
    		ftok.page=0;
    		ftok.p_addr=NULL;
    		// Loop and find records with same ID and rec key and mark them as deleted.
    			fds_record_delete(&record_desc);
    			NRF_LOG_INFO("Deleted record ID: %d \r\n",record_desc.record_id);
    		// call the garbage collector to empty them, don't need to do this all the time, this is just for demonstration
    		ret_code_t ret = fds_gc();
    				return ret;
    		return NRF_SUCCESS;
    static ret_code_t fds_test_init (void)
    		ret_code_t ret = fds_register(my_fds_evt_handler);
    					return ret;
    		ret = fds_init();
    				return ret;
    		return NRF_SUCCESS;
    /**@brief Function for application main entry.
    		uint32_t err_code;
        bool erase_bonds;
        // Initialize.
        log_init();
        timers_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        advertising_init();
        services_init();
        sensor_simulator_init();
        conn_params_init();
        peer_manager_init();
    		// Test FDS:
    		err_code =fds_test_init();
    		err_code = fds_test_find_and_delete();
    		err_code =fds_test_write();
    		//wait until the write is finished.
    		while (write_flag_fds_test==0);
    		err_code = fds_read();
        // Start execution.
        NRF_LOG_INFO("Heart Rate Sensor example started.");
        application_timers_start();
        advertising_start(erase_bonds);
        // Enter main loop.
        for (;;)
                power_manage();
  • Kristin, I learned a lot from your answer. If I can read and write a 10 byte uint8_t data(such as below), I will reach the purpose.
    static uint8_t m_deadbeef[10] = {0x41,0x30,0x31,0x31,0x30,0x30,0x30,0x34,0x30,0x24};
    Could you tell me how to write this uint8_t m_deadbeef[10]?
  • FormerMember
    The function fds_test_write() shows how to do that.
