Compile C++ code on Segger Embedded Studio
Hi everyone :D
  I'm not being able to compile a c++ code on segger embedded studio.
  The same code compiles with the Makefile provided in the SDK 14.2, but not with the segger solution on the same SDK.
  I change the main extension to cpp (ble_app_blinky example for the pca10040) and change the include on the segger solution. When it compiles, it gives me this errors on the following lines:
  - _Static_assert’ was not declared in this scope
  - expected constructor, destructor, or type conversion before ‘(’ token
#define STATIC_ASSERT_SIMPLE(EXPR)      _Static_assert(EXPR, "unspecified message")
#define STATIC_ASSERT_MSG(EXPR, MSG)    _Static_assert(EXPR, MSG)
  I read the forum here and changed the "_Static_assert" to static_assert due to c++/c differences, but then it doesn't compile again and gives me this errors on these lines
  - expected declaration specifiers or ‘...’ before ‘(’ token
#define PUSHED_HEADER_SIZE (sizeof(nrf_log_pushed_header_t)/sizeof(uint32_t))
#define STATIC_ASSERT_SIMPLE(EXPR)      static_assert(EXPR, "unspecified message")
  Maybe this is a configuration problem. Does anyone know how to configure segger properly?
Renato Morelli
