SPI communication and BLE advertising data with nRF52 DK
Hi everyone!
I have already developed a couple projects in nRF52 DK and the result was quite messy. I want to make it right this time and that's why I am requesting your help.
I am using nRF52 DK and SDK 13.0.0. and Eclipse Mars 2 (C/C++) with the setup explained in this Devzone Tutorial.
My goal is to create a project starting from some examples, modifying and merging them. I intend to comunicate with a SPI peripheral and send the recieved data through BLE advertising mode (broadcast).
I have compiled and tested the SPI example and it works just fine. Now, I need to send that data over BLE advertising. The requirement is it to be sent at least 10 times every second.
I would be very grateful if you could guide me on this. Some pages that I should read, any example that broadcasts data over BLE, any question already answered on this topic (I have searched and I did not find that much), any help will be very welcome. I really want to learn how to use Nordic hardware but my previous experience has only been frustrating so far.
Thank you so much for your time!
AGB
  • Hi Ander,
    for changing major and minor value change the following #define in main.c
    #define APP_MAJOR_VALUE 0x01,0x02 /**< Major value used to identify Beacons. */
    #define APP_MINOR_VALUE 0x03, 0x04 /**< Minor value used to identify Beacons. */
    same for all the values which u need to change. UUID and company field.
  • Thank you for your early reply. That's what I tried, but it did change nothing in the advertising packet. I found the issue, instead of linking the main.c file of my local repository folder I linked to the project the main.c file of the examples folder by mistake. Sorry for the trouble.
    If I want to programatically change one BLE field to send the data from my SPi sensor, what field would you advise me to use?
  • It depends upon your sensor value.. You can use any field from advertisement packet e.g major number.
  • I am now trying to merge both main.c (the one from the "ble_app_beacon" example and the other from "spi") files into just one project. I soon started to get errors, so my first approach was going to the sdk_config.h file to enable the spi. And then some errors like "SPI_SS_PIN is not declared " started to pop up.
    These defines are normally placed in the sdk_config.h file as well, but they are not. I thought that the sdk_config.h file was a macro equal for all the projects and examples and you could configure it, but the ble_app_beacon's sdk_config.h file does not have the declarations of SPI_SS_PIN, SPI_SCK_PIN,... Is that normal?
    I started to define all of them by hand. And now I only have 2 errors: undefined reference to 'nrf_drv_spi_init' and undefined reference to 'nrf_drv_spi_transfer'. Both of this functions are declared in nrf_drv_spi.h which, by the way, is included in my project. Why does Eclipse not recognise them? Or what is the problem?
  • Yes you can add you #defines for spi in you sdk_config file for ble_app_beacon example. It is normal. Try to setup same files and libraries which you are using for simple spi example into your beacon example. And make sure you have added path to all your libraries and files.
    have you included all required files for spi into main.c?
