How to disable safely the repeat / relay for certain nodes in a Bluteooth mesh network ?
Hi !
My goal is to create a large mesh network (over 100 nodes).
I plan to have 3 kind of nodes : a client (connected to a PC), several server relay nodes (not on battery), many server node (on battery, I will call them low power, even though the true low power nodes are not yet available with the SDK).
At this point I would like to enable only certain nodes to repeat/relay packets from the "low-power" nodes, in order to avoid a massive flood of the network and to save power.
How can I (safely) disable the relay/repeat feature for certain nodes ?
Thank!
  • hello Pseudoincorrect,
    The Bluetooth Mesh specification allows for the features (Relay, Proxy, Friend etc.) of a mesh node to be dynamically set (enabled/disabled) via use of the Configuration Client and (mandatory) Server models.
    Within the Nordic Mesh SDK, the config_client_relay_set() function should allow you to achieve your requirement. There aren't any examples in the Mesh v1.0.1 SDK but taking a look at the unit test cases should help you progress. We're working on something similar so if you get stuck, comment back and we can try to help you further.
  • Thanks a lot Leonwj,
    I will then use the client model instead of the server one for the relays nodes !
  • No problem, but don't forget the mesh spec enforces all mesh nodes to support the Configuration Server model (it's mandatory), so each node when it receives a *_relay_set() or *_relay_get() message from a Configuration Client (typically this config client functionality will be coded into a Provisioner or Network management type node) will either enable/disable relay functionality or report back its status (I'm not sure if it can report back that the feature is unsupported on that node).
    Note that you can also set a nodes ttl and retransmission values in the same message call to further optimize/control overall network message delivery across the entire mesh network.
