NRF51822 SDK 12.3.0 SD 130 fstorage crashes after BLE disconnect
I am trying to use the fstorage lib in SDK 12.3.0. My code is based on this example: https://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.sdk5.v12.3.0%2Flib_fstorage.html&cp=4_0_5_3_38 .
I am initializing fstorage in main() right before entering the main loop. If I write anything to flash in my main loop while the device is connected to another device, the application runs normally until the peer disconnects. Normally the device should start advertising again, but it seems to be stuck in a SD function and never returns. I am only trying to write one word of data at this point.
static void fs_evt_handler(fs_evt_t const * const evt, fs_ret_t result)
    if (result != FS_SUCCESS)
        // An error occurred.
FS_REGISTER_CFG(fs_config_t fs_config) =
    .callback  = fs_evt_handler, // Function for event callbacks.
    .num_pages = 1,       // Number of physical flash pages required.
    .priority  = 0xFE            // Priority for flash usage.
void flash_write() {
static uint32_t data = 0xAAAAAAAA;
fs_ret_t ret = fs_store(&fs_config, fs_config.p_start_addr, &data, 1, NULL);
if (ret != FS_SUCCESS)
Thanks for your help,
   Thilo
