timing information
  • I am running Keil uVision V5.23.0.0, debugging a 51822 using the J-LINK / J-TRACE interface built into the chips
  • My code uses SD110, SDK 7.2
  • I need to get ABSOLUTE timing info on my product
  • Ideally, something simple like a time-stamp from the PC at the start of a routine and another one when the routine ends would be GREAT!
  • I have tried SEVERAL different things to get this info, including:
    • using a ULINK 2
      • It seems this is just the same as using the built-in J-LINK interface and doesn't provide any more info that the native debug interface
    • including a debugger init file that, when called from break points set at the proper addresses, prints the number of states
      • However, this always just prints out 0 states....
      • watching the variable "states" shows only a 0x00
    • using the "PA" command from the command window...
      • ALL accesses come back with 0 hits...
  • I have looked through thousands of postings about how Trace could help but it seems as if it only works with an nRF52 device, not the nRF51 that I am using
    • AND it needs a ULINKpro to go with it
Can anyone please tell me how I can get this info from the Keil interface please?
Thanks!
    The easiest, and also maybe the best way to measure “ABSOLUTE timing” is to toggle a GPIO when you start the routine, and toggle it again when you exit the routine. You can then use a logic analyzer or scope to measure the timing.
  • Thanks, Sigurd,
    Ya. Did that. Perhaps a bit of background on what I'm trying to do. A bit of a long read, so I apologize in advance.
    • My nRF51 code needs to keep the amount of accumulated time-error down as much as possible
      • Hence the need for "absolute time"
    • My code uses the SD110-based RTC0 tick timer, set for 1mSec interrupts
      • Every interrupt, I need to update a display to prevent blinking
      • I already know that the 1mSec is in reality 1.007 mSec long (32.768KHz clock), so that's an easy one to correct for
    • However, what I've seen is that when BLE events happen, the RTC0 Tick can go away for as long as 4 mSec...
      • It seems to happen when the nRF does it's thing to keep the BLE connection alive
      • I determined this by twiddling a GPIO pin in the Tick Timer ISR and using my logic analyzer set up to capture events LONGER than 1.007 mSec apart
      • However, the regularity of this is difficult to determine, to see how the error accumulates over time and whether I can brute-force some sort of correction every 's' Secs or so
    • So, what I would like is to see independent time stamps from something OUTSIDE the development system (my board, the Keil IDE, etc.)
      • This would be the PC
      • I could run the code for an hour or two and log the time stamps and determine the rate of error accumulation and correct for it
      • I tried using the time stamps on the nRF Toolbox UART app (which receives messages from my nRF along with time-stamps generated by the nRF) but the problem here is that there is unknown and non-repeatable latency in when the message actually is received by the app on the phone...
    • I have even gone further in this investigation by using a 1MHz crystal oscillator as an input to a GPIO pin.
      • This pin is set up as a GPIOTE event
      • Timer2 set up as a counter with the GPIOTE as an input, via PPI
      • I count the number of oscillator pulses when the 1 mSec interrupt happens
      • Again, I can confirm that this DOES show larger than normal oscillator pulse counts every so often
    On the other hand, you could also tell me why the SD is taking away my Timer Ticks when it gets busy with BLE stuff? The docs seem to indicate that this should NOT happen....
    But, at the very least, I'd like to know how to get time-stamps from the PC which is running my Keil IDE into the debug environment...
    Thanks!
  • Sigurd....
    I wrote ALL that detailed stuff and you come back with this...
    Never mind
    Thanks
    The first step would be to switch to RTC1.
    You could then to send the RTC-tick measurements over to the PC using Segger RTT or UART. What is the main-goal of the timestamp ? Measure how long time different functions/routines takes? or to keep track of time in general ? If it is for general timekeeping in the application, then you should take look at the nrf-calendar-example that we have on GitHub.
  • I just realized that I HAVE tried this already (done SO many things...)
    I found the following from Ole Morten on on one of the conversations (devzone.nordicsemi.com/.../rtc0-rtc1-and-the-app_timer-with-softdevice):
    It is correct that the softdevice itself only requires RTC0, but as you've seen, some of the SDK modules use RTC1, most notably app_timer, which is again used by the connection parameters module.
    It is perfectly possible to build an application without app_timer, but it will require some modifications to the SDK modules that uses it. You should however note that the connection parameters module isn't strictly required, since you can send connection parameter update requests manually by using the softdevice API directly. All modules using app_timer are optional, and you can just avoid using them. It is of course also an option to modify app_timer to cope with both your needs while still maintaining an API that the other modules can use. Exactly how to solve this is an application choice.
    There isn't any way to run different timers with different priorities with the current app_timer implementation.
  • Could you clarify the purpose for this timing information?
    Is this
     1)
    Some general time keeping mechanism (e.g hour:minute:second: 12:30:09,  date:06.03.2018) running on the nRF51 that the your application needs? If this is running on the SoC, without input from some external source PC/phone, then the clock accuracy will depend on the accuracy of the crystal you have on the board. I.e RTC running on the 32.768 kHz crystal oscillator on the DK, will have 20 ppm accuracy. If you are using the 32.768 kHz RC oscillator, you will have 250/500 ppm accuracy.
    OR 2)
    You just want timestamps on the PC, created on the PC, when the nRF51 calls certain functions?
    Then you could just send data over UART, and the PC could generate the timestamps when it received the message. In the terminal software Termite, this would look something liks this:
    Is this
     1)
    OR 2)
