Hello!
I'm a beginner with Nordic products and I'm taking over the nRF52840 Preview Development Kit.
I want to send advertisings at regular intervals (every second). Between advertisings, I want to go in sleep mode. To do this, I used the following example program, with some minor changes:
<InstallFolder>\examples\ble_peripheral\ble_app_beacon. I used nRF5 SDK v14.1.0 and S132 softdevice.
I want to put an external power supply that consumes a minimum of energy, to power directly my nRF52840. My software must obviously continue to work.
I tried to put the external power supply (3V) on the P21 connector (Switch SW6 is on “nRF only” / Switch SW9 is on position VDD). But, I consume about 2.6mA, which doesn't correspond at all to sleep mode... If I measure on connector P22 with a good multimeter (with SB40 cutted), the current consumption is about 2uA in sleep mode, as desired.
Where should I put the external power supply for minimum power consumption only (some uA in sleep mode)? Do I have to modifie other switches or solder bridges?
Thank you in advance for your answers!
