Long delay after DFU completion SDK 12.1
We currently have an application that is running SDK 12.1 on the NRF52832. We have no issues doing a firmware update using the iOS SDK. What we are seeing is a long delay between the iOS completion callback, and the actual application running again on the NRF52. In our case this is generally around 30 seconds.
SDK 14 has the following define:NRF_DFU_POST_SD_BL_TIMEOUT_MS, but I do not see anything related to this in SDK 12.
Is there some way I am missing to diminish this timeout?
Thanks in advance for the feedback.
    Are you testing with a custom iOS app, or have you tried the same with nRF connect / nRF toolbox on ios? I was unable to reproduce this delay with the default bootloader from SDK 12.1.0 (testet DFU of APP).
    There's no timeouts or other delays in SDK 12 that should cause the activation process to take 30 seconds as far as I can tell. DFU timeout was introduced SDK 14 as you already mentioned.
    Vidar
    Update 3/8
    I failed to reproduce this initially because I was doing  single bank updates. Can now confirm that the activation process can take >10 seconds to complete for larger application images. The long delay is mainly caused by the flash operations needed for replacing the old application image in bank 0.
    Attached is a slightly modified version of nrf_dfu_utils.c from SDK 12.1.0 that reduces the activation time (removed redundant page erases in copy routine) in addition to being more robust against unexpected resets. Changes were taken from from SDK 14.2.0
    /* Copyright (c) 2016 Nordic Semiconductor. All Rights Reserved.
     * The information contained herein is property of Nordic Semiconductor ASA.
     * Terms and conditions of usage are described in detail in NORDIC
     * SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
     * Licensees are granted free, non-transferable use of the information. NO
     * WARRANTY of ANY KIND is provided. This heading must NOT be removed from
     * the file.
    #include "nrf_dfu_utils.h"
    #include <string.h>
    #include "nrf_dfu_settings.h"
    #include "nrf_dfu_mbr.h"
    #include "nrf_bootloader_app_start.h"
    #include "nrf_bootloader_info.h"
    #include "crc32.h"
    #include "nrf_log.h"
    static uint32_t align_to_page(uint32_t val, uint32_t page_size)
        return ((val + page_size - 1 ) &~ (page_size - 1));
    static void nrf_dfu_invalidate_bank(nrf_dfu_bank_t * p_bank)
        // Set the bank-code to invalid, and reset size/CRC
        memset(p_bank, 0, sizeof(nrf_dfu_bank_t));
        // Reset write pointer after completed operation
        s_dfu_settings.write_offset = 0;
        // Reset SD size
        s_dfu_settings.sd_size = 0;
        // Promote dual bank layout
        s_dfu_settings.bank_layout = NRF_DFU_BANK_LAYOUT_DUAL;
        // Signify that bank 0 is empty
        s_dfu_settings.bank_current = NRF_DFU_CURRENT_BANK_0;
    /** @brief Function to continue App update
     * @details This function will be called after reset if there is a valid application in Bank1
     *          required to be copied down to bank0.
     * @param[in]       src_addr            Source address of the application to copy from Bank1 to Bank0.
     * @retval  NRF_SUCCESS                 Continuation was successful.
     * @retval  NRF_ERROR_NULL              Invalid data during compare.
     * @retval  FS_ERR_UNALIGNED_ADDR       A call to fstorage was not aligned to a page boundary or the address was not word aliged.
     * @retval  FS_ERR_INVALID_ADDR         The destination of a call to fstorage does not point to
     *                                      the start of a flash page or the operation would
     *                                      go beyond the flash memory boundary.
     * @retval  FS_ERR_NOT_INITIALIZED      The fstorage module is not initialized.
     * @retval  FS_ERR_INVALID_CFG          The initialization of the fstorage module is invalid.
     * @retval  FS_ERR_NULL_ARG             A call to fstorage had an invalid NULL argument.
     * @retval  FS_ERR_INVALID_ARG          A call to fstorage had invalid arguments.
     * @retval  FS_ERR_QUEUE_FULL           If the internal operation queue of the fstorage module is full.
     * @retval  FS_ERR_FAILURE_SINCE_LAST   If an error occurred in another transaction and fstorage cannot continue before
     *                                      the event has been dealt with.
    static uint32_t nrf_dfu_app_continue(uint32_t               src_addr)
        // This function only in use when new app is present in bank 1
        uint32_t const image_size  = s_dfu_settings.bank_1.image_size;
        uint32_t const split_size  = CODE_PAGE_SIZE; // Arbitrary number that must be page aligned
        uint32_t ret_val            = NRF_SUCCESS;
        uint32_t target_addr        = MAIN_APPLICATION_START_ADDR + s_dfu_settings.write_offset;
        uint32_t length_left        = (image_size - s_dfu_settings.write_offset);
        uint32_t cur_len;
        uint32_t crc;
        NRF_LOG_INFO("Enter nrf_dfu_app_continue\r\n");
        // This can be a continuation due to a power failure
    	src_addr += s_dfu_settings.write_offset;
        // Copy the application down safely
        do
            cur_len = (length_left > split_size) ? split_size : length_left;
            // Erase the target page
            ret_val = nrf_dfu_flash_erase((uint32_t*) target_addr, split_size / CODE_PAGE_SIZE, NULL);
            if (ret_val != NRF_SUCCESS)
                return ret_val;
            // Flash one page
            ret_val = nrf_dfu_flash_store((uint32_t*)target_addr, (uint32_t*)src_addr, cur_len, NULL);
                return ret_val;
            ret_val = nrf_dfu_mbr_compare((uint32_t*)target_addr, (uint32_t*)src_addr, cur_len);
                // We will not retry the copy
                NRF_LOG_INFO("Invalid data during compare: target: 0x%08x, src: 0x%08x\r\n", target_addr, src_addr);
                return ret_val;
            // Erase the head (to handle growing bank 0)
            /*ret_val = nrf_dfu_flash_erase((uint32_t*) src_addr, split_size / CODE_PAGE_SIZE, NULL);
                NRF_LOG_INFO("App update: Failure erasing page at addr: 0x%08x\r\n", src_addr);
                return ret_val;
            s_dfu_settings.write_offset += cur_len;
            (void)nrf_dfu_settings_write(NULL);
            target_addr += cur_len;
            src_addr += cur_len;
            length_left -= cur_len;
        while(length_left > 0);
        // Check the crc of the copied data. Enable if so.
        crc = crc32_compute((uint8_t*)MAIN_APPLICATION_START_ADDR, image_size, NULL);
        if (crc == s_dfu_settings.bank_1.image_crc)
            NRF_LOG_INFO("Setting app as valid\r\n");
            s_dfu_settings.bank_0.bank_code = NRF_DFU_BANK_VALID_APP;
            s_dfu_settings.bank_0.image_crc = crc;
            s_dfu_settings.bank_0.image_size = image_size;
            NRF_LOG_INFO("CRC computation failed for copied app: src crc: 0x%08x, res crc: 0x08x\r\n", s_dfu_settings.bank_1.image_crc, crc);
        nrf_dfu_invalidate_bank(&s_dfu_settings.bank_1);
        return ret_val;
    /** @brief Function to execute the continuation of a SoftDevice update.
     * @param[in]       src_addr            Source address of the SoftDevice to copy from.
     * @param[in]       p_bank              Pointer to the bank where the SoftDevice resides.
     * @retval NRF_ERROR_INVALID_LENGTH Invalid len
     * @retval NRF_ERROR_NO_MEM if UICR.NRFFW[1] is not set (i.e. is 0xFFFFFFFF).
     * @retval NRF_ERROR_INVALID_PARAM if an invalid command is given.
     * @retval NRF_ERROR_INTERNAL indicates that the contents of the memory blocks where not verified correctly after copying.
     * @retval NRF_ERROR_NULL If the content of the memory blocks differs after copying.
    static uint32_t nrf_dfu_sd_continue_impl(uint32_t             src_addr,
        uint32_t   target_addr  = SOFTDEVICE_REGION_START + s_dfu_settings.write_offset;
        uint32_t   length_left  = align_to_page(s_dfu_settings.sd_size - s_dfu_settings.write_offset, CODE_PAGE_SIZE);
        uint32_t   split_size   = align_to_page(length_left / 4, CODE_PAGE_SIZE);
        NRF_LOG_INFO("Enter nrf_bootloader_dfu_sd_continue\r\n");
        if (s_dfu_settings.sd_size != 0 && s_dfu_settings.write_offset == s_dfu_settings.sd_size)
            NRF_LOG_INFO("SD already copied\r\n");
            return NRF_SUCCESS;
        NRF_LOG_INFO("Updating SD. Old SD ver: 0x%04x\r\n", SD_FWID_GET(MBR_SIZE));
        do
            NRF_LOG_INFO("Copying [0x%08x-0x%08x] to [0x%08x-0x%08x]: Len: 0x%08x\r\n", src_addr, src_addr + split_size, target_addr, target_addr + split_size, split_size);
            // Copy a chunk of the SD. Size in words
            ret_val = nrf_dfu_mbr_copy_sd((uint32_t*)target_addr, (uint32_t*)src_addr, split_size);
                NRF_LOG_INFO("Failed to copy SD: target: 0x%08x, src: 0x%08x, len: 0x%08x\r\n", target_addr, src_addr, split_size);
                return ret_val;
            NRF_LOG_INFO("Finished copying [0x%08x-0x%08x] to [0x%08x-0x%08x]: Len: 0x%08x\r\n", src_addr, src_addr + split_size, target_addr, target_addr + split_size, split_size);
            // Validate copy. Size in words
            ret_val = nrf_dfu_mbr_compare((uint32_t*)target_addr, (uint32_t*)src_addr, split_size);
                NRF_LOG_INFO("Failed to Compare SD: target: 0x%08x, src: 0x%08x, len: 0x%08x\r\n", target_addr, src_addr, split_size);
                return ret_val;
            NRF_LOG_INFO("Validated 0x%08x-0x%08x to 0x%08x-0x%08x: Size: 0x%08x\r\n", src_addr, src_addr + split_size, target_addr, target_addr + split_size, split_size);
            target_addr += split_size;
            src_addr += split_size;
            if (split_size > length_left)
                length_left = 0;
                length_left -= split_size;
            NRF_LOG_INFO("Finished with the SD update.\r\n");
            // Save the updated point of writes in case of power loss
            s_dfu_settings.write_offset = s_dfu_settings.sd_size - length_left;
        while (length_left > 0);
        return ret_val;
    /** @brief Function to continue SoftDevice update
     * @details     This function will be called after reset if there is a valid SoftDevice in Bank0 or Bank1
     *          required to be relocated and activated through MBR commands.
    static uint32_t nrf_dfu_sd_continue(uint32_t             src_addr,
        uint32_t ret_val;
        ret_val = nrf_dfu_sd_continue_impl(src_addr, p_bank);
            NRF_LOG_INFO("SD update continuation failed\r\n");
            return ret_val;
        nrf_dfu_invalidate_bank(p_bank);
        return ret_val;
    /** @brief Function to continue Bootloader update
     * @details     This function will be called after reset if there is a valid Bootloader in Bank0 or Bank1
     * @param[in]       src_addr            Source address of the BL to copy from.
     * @return This fucntion will not return if the bootloader is copied succesfully.
     *         After the copy is verified the device will reset and start the new bootloader.
     * @retval NRF_ERROR_INVALID_LENGTH Invalid length of flash operation.
     * @retval NRF_ERROR_NO_MEM if no parameter page is provided (see sds for more info).
     * @retval NRF_ERROR_INTERNAL internal error that should not happen.
     * @retval NRF_ERROR_FORBIDDEN if NRF_UICR->BOOTADDR is not set.
    static uint32_t nrf_dfu_bl_continue(uint32_t src_addr, nrf_dfu_bank_t * p_bank)
        uint32_t const  len         = (p_bank->image_size - s_dfu_settings.sd_size);
        // if the update is a combination of BL + SD, offset with SD size to get BL start address
        src_addr += s_dfu_settings.sd_size;
        NRF_LOG_INFO("Verifying BL: Addr: 0x%08x, Src: 0x%08x, Len: 0x%08x\r\n", MAIN_APPLICATION_START_ADDR, src_addr, len);
        // If the bootloader is the same as the banked version, the copy is finished
        ret_val = nrf_dfu_mbr_compare((uint32_t*)BOOTLOADER_START_ADDR, (uint32_t*)src_addr, len);
        if (ret_val == NRF_SUCCESS)
            NRF_LOG_INFO("Bootloader was verified\r\n");
            // Invalidate bank, marking completion
            NRF_LOG_INFO("Bootloader not verified, copying: Src: 0x%08x, Len: 0x%08x\r\n", src_addr, len);
            // Bootloader is different than the banked version. Continue copy
            // Note that if the SD and BL was combined, then the split point between them is in s_dfu_settings.sd_size
            ret_val = nrf_dfu_mbr_copy_bl((uint32_t*)src_addr, len);
            if(ret_val != NRF_SUCCESS)
                NRF_LOG_INFO("Request to copy BL failed\r\n");
        return ret_val;
    /** @brief Function to continue combined Bootloader and SoftDevice update
     * @details     This function will be called after reset if there is a valid Bootloader and SoftDevice in Bank0 or Bank1
     * @param[in]       src_addr            Source address of the combined Bootloader and SoftDevice to copy from.
    static uint32_t nrf_dfu_sd_bl_continue(uint32_t src_addr, nrf_dfu_bank_t * p_bank)
        NRF_LOG_INFO("Enter nrf_dfu_sd_bl_continue\r\n");
            NRF_LOG_INFO("SD+BL: SD copy failed\r\n");
            return ret_val;
        ret_val = nrf_dfu_bl_continue(src_addr, p_bank);
            NRF_LOG_INFO("SD+BL: BL copy failed\r\n");
            return ret_val;
        return ret_val;
    static uint32_t nrf_dfu_continue_bank(nrf_dfu_bank_t * p_bank, uint32_t src_addr, uint32_t * p_enter_dfu_mode)
        switch (p_bank->bank_code)
           case NRF_DFU_BANK_VALID_APP:
                NRF_LOG_INFO("Valid App\r\n");
                if(s_dfu_settings.bank_current == NRF_DFU_CURRENT_BANK_1)
                    // Only continue copying if valid app in bank1
                    ret_val = nrf_dfu_app_continue(src_addr);
           case NRF_DFU_BANK_VALID_SD:
                NRF_LOG_INFO("Valid SD\r\n");
                // There is a valid SD that needs to be copied (or continued)
                ret_val = nrf_dfu_sd_continue(src_addr, p_bank);
                (*p_enter_dfu_mode) = 1;
            case NRF_DFU_BANK_VALID_BL:
                NRF_LOG_INFO("Valid BL\r\n");
                // There is a valid BL that must be copied (or continued)
            case NRF_DFU_BANK_VALID_SD_BL:
                NRF_LOG_INFO("Single: Valid SD + BL\r\n");
                // There is a valid SD + BL that must be copied (or continued)
                ret_val = nrf_dfu_sd_bl_continue(src_addr, p_bank);
            case NRF_DFU_BANK_INVALID:
                NRF_LOG_INFO("Single: Invalid bank\r\n");
        return ret_val;
    uint32_t nrf_dfu_continue(uint32_t * p_enter_dfu_mode)
        uint32_t            ret_val;
        nrf_dfu_bank_t    * p_bank;
        uint32_t            src_addr = CODE_REGION_1_START;
        NRF_LOG_INFO("Enter nrf_dfu_continue\r\n");
        if (s_dfu_settings.bank_layout == NRF_DFU_BANK_LAYOUT_SINGLE )
            p_bank = &s_dfu_settings.bank_0;
        else if(s_dfu_settings.bank_current == NRF_DFU_CURRENT_BANK_0)
            p_bank = &s_dfu_settings.bank_1;
            src_addr += align_to_page(s_dfu_settings.bank_0.image_size, CODE_PAGE_SIZE);
        ret_val = nrf_dfu_continue_bank(p_bank, src_addr, p_enter_dfu_mode);
        return ret_val;
    bool nrf_dfu_app_is_valid(void)
        NRF_LOG_INFO("Enter nrf_dfu_app_is_valid\r\n");
        if (s_dfu_settings.bank_0.bank_code != NRF_DFU_BANK_VALID_APP)
           // Bank 0 has no valid app. Nothing to boot
           NRF_LOG_INFO("Return false in valid app check\r\n");
           return false;
        // If CRC == 0, this means CRC check is skipped.
        if (s_dfu_settings.bank_0.image_crc != 0)
            uint32_t crc = crc32_compute((uint8_t*) CODE_REGION_1_START,
                                         NULL);
            if (crc != s_dfu_settings.bank_0.image_crc)
                // CRC does not match with what is stored.
                NRF_LOG_INFO("Return false in CRC\r\n");
                return  false;
        NRF_LOG_INFO("Return true. App was valid\r\n");
        return true;
    uint32_t nrf_dfu_find_cache(uint32_t size_req, bool dual_bank_only, uint32_t * p_address)
        // TODO: Prevalidate p_address and p_bank
        uint32_t free_size =  DFU_REGION_TOTAL_SIZE - DFU_APP_DATA_RESERVED;
        NRF_LOG_INFO("Enter nrf_dfu_find_cache\r\n");
        // Simple check if size requirement can me met
        if(free_size < size_req)
            NRF_LOG_INFO("No way to fit the new firmware on device\r\n");
            return NRF_ERROR_NO_MEM;
        NRF_LOG_INFO("Bank content\r\n");
        NRF_LOG_INFO("Bank type: %d\r\n", s_dfu_settings.bank_layout);
        NRF_LOG_INFO("Bank 0 code: 0x%02x: Size: %d\r\n", s_dfu_settings.bank_0.bank_code, s_dfu_settings.bank_0.image_size);
        NRF_LOG_INFO("Bank 1 code: 0x%02x: Size: %d\r\n", s_dfu_settings.bank_1.bank_code, s_dfu_settings.bank_1.image_size);
        // Setting bank_0 as candidate
        // Setting candidate address
        (*p_address) = MAIN_APPLICATION_START_ADDR;
        // Calculate free size
        if (s_dfu_settings.bank_0.bank_code == NRF_DFU_BANK_VALID_APP)
            // Valid app present.
            NRF_LOG_INFO("free_size before bank select: %d\r\n", free_size);
            free_size -= align_to_page(p_bank->image_size, CODE_PAGE_SIZE);
            NRF_LOG_INFO("free_size: %d, size_req: %d\r\n", free_size, size_req);
            // Check if we can fit the new in the free space or if removal of old app is required.
            if(size_req > free_size)
                // Not enough room in free space (bank_1)
                if ((dual_bank_only))
                    NRF_LOG_INFO("Failure: dual bank restriction\r\n");
                // Can only support single bank update, clearing old app.
                s_dfu_settings.bank_layout = NRF_DFU_BANK_LAYOUT_SINGLE;
                NRF_LOG_INFO("Enforcing single bank\r\n");
                // Room in bank_1 for update
                // Ensure we are using dual bank layout
                s_dfu_settings.bank_current = NRF_DFU_CURRENT_BANK_1;
                // Set to first free page boundry after previous app
                (*p_address) += align_to_page(s_dfu_settings.bank_0.image_size, CODE_PAGE_SIZE);
                NRF_LOG_INFO("Using second bank\r\n");
            // No valid app present. Promoting dual bank.
            NRF_LOG_INFO("No previous, using bank 0\r\n");
        // Store the Firmware size in the bank for continuations
        p_bank->image_size = size_req;
        return NRF_SUCCESS;
  • Hi Vidar,
    I have tested with both our custom application, as well as the latest version of nRF toolbox, and both result in the same delay after the iPhone says the process is complete.
    We have modified to use the S332 soft device.
    In our situation, the user has the ability to do a power reset on the device. If this is done during that 30s delay, the device will end up being stuck in the bootloader. It seems like the bootloader is doing some verification or copying of the new application?
    Nick
  • Hi Nick,
    The bootloader resets itself after receiving the new FW image, then on subsequent startup, it proceeds to active the new image. That is, replace old app image in bank 0, with new one, then update bootloader settings to validate the app (dual bank update). It sounds like the problem occurs in the activation stage while the image is being copied, but I don't see any reasons for why it would take >30 seconds to complete.  Are you able to share your project so I can debug it on my side (you may create a private support ticket if you don't want to make it public)? Also, have you made other code changes that may be relevant, except for updating the SD API?
    As a side note, the activation process should complete on following startup if interrupted by an unexpected reset, but it doesn't always work depending on when the reset occurs. The copy routine was made more robust in SDK 14.2.0, so you may consider back-porting it to SDK 12.1.0 if resets are likely to occur during activation.
  • Thanks Vidar,
     I am currently running all the SDK 12.1 code for the bootloader with no changes except for changing to the S332, and I am still seeing the issue.
    I have started a private ticket.
    Nick
