nrf52832 UART send multiple bytes
Hi all,
    I am trying to send a command to the sensor so that the sensor will response with sending something back for acknowledgement, via UART.
    Let say, I want to send a command "SEND" to sensor, and the sensor will send its data back. However, I don't know how to modify the example code in
    nRF5_SDK_14.2.0_17b948a\examples\peripheral\uart
    so that the code are fetching the FIFO when the '\n' is met, instead of response in every character. Right now the example is doing this for single character.
    I am not sure how to change from the example to achieve, it seems rx/tx are having independent fifo buffer, how they operate and connected?
    m_rx_fifo, m_tx_fifo
    tx_buffer[], rx_buffer[]
    nrf_drv_uart_rx(), nrf_drv_uart_tx()
    app_uart_get(), app_uart_put()
Please share your thoughts if you have any idea. Thanks Slight smile
    I would use app_uart_get() whenever a APP_UART_DATA_READY event arrives and check if it's a '\n' character. When that's the case, just loop app_uart_put with all your response bytes.
    If I understand correctly, you want to do something like this:
    #include "string.h"  ///< strcmp()
    uint8_t cr;
    char cmd[MAX_CMD_LEN];
    uint8_t cmdIndex = 0;
    void sendAction()
        uint8_t i;
        for(i = 0; i < SENSOR_VALUE_LEN; i++)
            while (app_uart_put(sensorValue[i]) != NRF_SUCCESS);
    void uart_handle(app_uart_evt_t * p_event)
        else if (p_event->evt_type == APP_UART_DATA_READY)
            while (app_uart_get(&cr) != NRF_SUCCESS);
            cmd[cmdIndex++] =  cr;
            cmd[cmdIndex] = 0;
            if(cr == '\n')
                printf("RX end! Command is : %s\r\n", cmd);
                if(strcmp(cmd, "SEND\n") == 0)
                    sendAction();
                else if(strcmp(cmd, "STATUS\n") == 0)
                cmdIndex = 0;
    Hope this helps.
  • Thanks for the reply. I want to clarify about the usage of app_uart_put/app_uart_get. From the app_uart.h, the app_uart_put() is described to put a byte on the UART on TX buffer for transmission, I guess it means send data/command from nrf52 to sensor in my case.
    May I ask what is the difference between the uart handler from app_uart_evt_t
    and nrf_drv_uart_event_t from app_uart_fifo.c
    static void uart_event_handler(nrf_drv_uart_event_t * p_event, void* p_context)
        app_uart_evt_t app_uart_event;
        uint32_t err_code;
        switch (p_event->type)
            case NRF_DRV_UART_EVT_RX_DONE:
    The uart_event_handler in app_uart_fifo.c basically passes the event to your application handler you provided in the APP_UART_FIFO_INIT.
    Can you be more specific with the data you supposed to send/receive to/from the sensor?
  • To make it simple, let say I just want to send command "SEND" to sensor, no matter from PC PuTTY or hard code in nrf MCU. When sensor receive any signal "SEND", it will response back with its temperature value which is stored in 2 bytes.
    I think I shouldn't worry about anything in app_uart_fifo.c, only modify the application handler provided in APP_UART_FIFO_INIT. But I am not sure if I need to change the FIFO buffer size for tx/rx in my case.
    You can check CLI example. I think it is what you need.
