BLE_LSB nAN-36 Broken
Nordic,
After upgrading to S110 7.0.0 the BLE_LBS example no longer works as downloaded from GitHub. I adjusted the flash algorithm size which fixed the first problem and where the application could be placed in ROM. Would it be possible for you to update the example on GitHub or even better, distribute the example code with the SDK?
Regards, Nate
Parents Reply
  • Thanks for the info, I have downloaded it, and now compiles, but sadly when I go to Options for Target 'n51822_xxaa_s110 (256K)' it shows an Error: Device Support not found, linking me to the same page you showed me. If I press OK, the device is there as an option, but when trying to load it it shows: "No ULINK Device found". SO it seems it does not load it correcly.
