Bug in app_button_is_pushed()?
Within app_button module, code for app_button_is_pushed() seems to have changed from SDK version 5.1 to 6.0. I notice my code has stopped working properly with that update. Debugger makes it apparent that this is the problematic line:
app_button_cfg_t * p_btn = &mp_buttons[pin_no];  // excerpt from app_button_is_pushed SDK 6.0
For instance, if there is only 1 button attached to pin 0.30, I would expect to pass in pin_no=30 (just as I did in version 5.1). But mp_buttons[30] is way out of bounds; only mp_buttons[0] is valid for a single button scenario. The ensuing pointer assignment to p_btn is way off in the weeds.
Is this a bug or am I missing something?
For convenience, the 6.0 function call:
uint32_t app_button_is_pushed(uint8_t pin_no, bool * p_is_pushed)
    uint32_t err_code;
    uint32_t active_pins;
    if (mp_buttons == NULL)
    err_code = app_gpiote_pins_state_get(m_gpiote_user_id, &active_pins);
    if (err_code != NRF_SUCCESS)
        return err_code;
    if(p_btn->active_state == APP_BUTTON_ACTIVE_LOW)
        // If the pin is active low, then the pin being high means it is not pushed.
        if(((active_pins >> pin_no) & 0x01))
            *p_is_pushed = false;
            *p_is_pushed = true;
    else if(p_btn->active_state == APP_BUTTON_ACTIVE_HIGH)
        // If the pin is active high, then the pin being high means it is pushed.
    return NRF_SUCCESS;
and the 5.1 function call:
    uint32_t err_code;
    uint32_t pin_mask    = 0;
        return err_code;
    pin_mask = (1 << pin_no);
    if ((pin_mask & active_pins) == 0)
        *p_is_pushed = ((m_active_low_states_mask & pin_mask) ? true : false);
        *p_is_pushed = ((m_active_high_states_mask & pin_mask) ? true : false);
    return NRF_SUCCESS;
