Alternative to NRF_MODULE_ENABLED system?
We are all familiar with NRF_MODULE_ENABLED macros, what is their purpose and why are they required.
However, I am wondering if there could be a better way to implement such selection system, one which would be "future proof" - GCC 7 and Clang emits warning -Wexpansion-to-defined for such macros.
The warning can be suppressed, however this behaviour pulls other problems with it - as example, I described one of the most annoying in the JetBrains ticket 'defined' preprocessor operator and token concatenation, because I thought that is their bug.
I know that older SDKs had a system which actually didn't have that problem, however I do agree that this new system is more elegant and practical. Is there any compromise between the two?
  • I found a solution.
    It is quite a strict one, but luckily long ago I took a time to compare numerous sdk_config.h files to make one with all configuration defines in it.
    I changed
    //lint -emacro(491,NRF_MODULE_ENABLED) // Suppers warning 491 "non-standard use of 'defined' preprocessor operator"
    #define NRF_MODULE_ENABLED(module) \
        ((defined(module ## _ENABLED) && (module ## _ENABLED)) ? 1 : 0)
    to
    #define NRF_MODULE_ENABLED(module) ((module ## _ENABLED) ? 1 : 0)
    in the nordic_common.h file. Now everything is working fine.
