Need help to improve Bluetooth Mesh throughput
I am currently using two nRF52832 SDK boards to implement text message exchange with another nRF52832 SDK board via BLE Mesh.
I based my development on the Light Switch example that was included with the Mesh SDK 1.0.0
One of the board was based on the Lightswitch Client and the other board is based on Lightswitch Server.
I added two opcodes to the original _SET, _GET, _SET_UNRELIABLE and _STATUS. One opcode is called "SEND_COMMAND "and the second opcode is "SEND_RESPONSE".  I avoided building a custom model at this time so that I can avoid any issue with the provisioning. The main purpose is to test the throughput and latency to see if it is useable for a new product that we are developing.
The client board is programmed to send a text string about 15 characters. The opcode "SEND_COMMAND" is appended to the message.opcode together with a data structure that contains the text string and the length. The "access_model_publish() function is called to send out the packet. The command is published to a group address so that all the servers board will receive the command (currently I only have 1 server connected but the plan is to have all servers that subscribed to the group to receive the command in future)
The server board upon receiving the packet will decode the packet and then send a response. The response is sent with the opcode "SEND_RESPONSE" together with a response string of about 20 characters back to the client. The server too send the response using "access_model_publish()" function.
So far the application codes on both the client and server works well when triggering the client once a second to send the command text string and it does receive the response text string from the server most of the time.
However, when I try to increase the frequency of sending the command the communication seem to choke. The client could barely send and receive more than 2 command/response packets per second before it starts to choke and lose communication. Once the client stop sending the command you can see some of  the previous packets being sent through but could take a few seconds to complete.
Has anyone experienced the same kind of throughput issue as I did? Is there any parameters that I can adjust to increase the throughput? I read somewhere on this forum that it may be possible for a node to send message of up to 24Hz (I assume it means the client could send up to 24 packets a second) but currently I could not even send and receive faster than 2 packets a second.
Hopefully anyone who has gone through the same experience could point me to possible solutions.
Thank you!
  • Is there any need to change something in the node configuration or node setup on the provisioner side?
  • Hi aleccontrol,
    I have facing same issue in my current project i have developed complete application using nRF mesh technology. But my sensor data is 24KB this all data is transmitted but it took near about 2 minutes. But this time is much more we want to send this all data within 5-6 second. Can you tell me is it possible in nRF mesh technology. currently i have using mesh experimental instabrust feature for increase throughput and larger bandwidth. using this feature it took 2 minutes.
    Can anyone tell me is it possible to transmit 24-25 KB data within less than 10 second in mesh network with relaying functionality.
    Thanks..
  • Just to summarize, you are looking at a
    1. Throughput of about 200 kbits per 10 second per node (25 KBytes per 10 seconds per node)
    - This will mean that the bandwidth at the gateway/exit node from the mesh is number of nodes multiplied by the per node bandwidth , i.e. for 15 nodes it would mean  15 x 200 kbits per 10 seconds , i.e. 3000 kbits per 10 seconds or 300 kbits per second.
    2. Number of nodes sending data : assumed to be 15
    - We assume 1 exit node in addition
    3. Maximum number of hops : Let me assume 2 hops
    As you can see the throughput at the gateway node will need to scale for the number of nodes, so you need to look at that to see if it is viable for your products final configuration or examine ways to reduce data being generated from the nodes.
    More hops will also degrade the bandwidth substantially even with instaburst
    To test the instaburst, I would suggest using only 2 nodes first, i.e. 1 node sending the data and 1 node receiving the data as gateway or exit node measure the time taken and then add more nodes to understand the behavior that you see. Additionally get the statistical data from the mesh so you see where the bottlenecks are.
    Your usecase is using significant bandwidth and I think will need tuning and good understanding of hops and node count to get the numbers you want, so approach this carefully.
    You can also consider using the Fruity Mesh as the mesh backend for your project as that is connection oriented and could get better throughput.
