Hi ,I am using nrf52 DK with mpu9255.I am using source code given here here.of this link,I have taken 'nrf5-ble-data-ready-interrupts' example .code builts fine in keil v5 though.I am not getting accel values.
help will be appreciated.
hi,i am using these pins i.e P0.17, P0.19 , P0.21, P0.20 as spi pins as any of GPIO pins can be used for spi/twi
yes you can use any gpio for spi/twi. i have got succeed using twi. the sdk i used is 14.2. so only i mentioned you to try with twi first. for that you no need to do any modification rather than # define mpu 9255 in target menu. if i want to check in spi i need couple of days to do it.
regards
hi,please confirm me with these mentioned pins which i am using for spi to interface with dk board.
hi,
in the zip file go to pca10056.h file in there they have mentioned the pin numbers like this
check as per your needs
hi,tried with given link ,code shows errors as cannotopen source input file "app_mpu.h" ," ble_mpu.h", " mpu9255_register_map.h"
shall i include the same file given in here?
