How to create two task with different task priority?
SDK version: 14.2.0
I use "ble_app_hrs_freertos" as code base and modify it to create a "ble_app_template_freertos" project.
"softdevice_task" is already in this project (uxPriority = 2).
I can use "xTaskCreate" to create a new task "task1" and the uxPriority is 1, and work normally.
And I modify "softdevice_task" uxPriority to 5, and "task1" uxPriority is 1 it works normally too.
But when I add a new task "task2" and the uxPriority set to 2, the system not work.
And I found when this project only have "softdevice_task"(uxPriority = 5) and "task1"(uxPriority = 2), it doesn't work too.
How to solve this issue?
The code config below doesn't work.
    bool erase_bonds;
    clock_init();
    if (pdPASS != xTaskCreate(task1_thread, "TASK1", 128, p_context, 1, &m_task1_thread))
        APP_ERROR_HANDLER(NRF_ERROR_NO_MEM);
    if (pdPASS != xTaskCreate(task2_thread, "TASK2", 128, p_context, 2, &m_task2_thread))
    // Activate deep sleep mode.
    SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;
    // Configure and initialize the BLE stack.
    ble_stack_init();
    // Initialize modules.
    timers_init();
    gap_params_init();
    gatt_init();
    advertising_init();
    services_init();
    sensor_simulator_init();
    conn_params_init();
    peer_manager_init();
    application_timers_start();
    // Create a FreeRTOS task for the BLE stack.
    // The task will run advertising_start() before entering its loop.
    nrf_sdh_freertos_init(advertising_start, &erase_bonds);
    // Start FreeRTOS scheduler.
    vTaskStartScheduler();
    while (true)
        APP_ERROR_HANDLER(NRF_ERROR_FORBIDDEN);
  • can you add the code for m_task1_thread and m_task2_thread? so that i can run them on my desk .
  • My test code is really simple like below.
    task1.c
    #include "task1.h"
    #include "FreeRTOS.h"
    #include "task.h"
    #include "semphr.h"
    #include "nrf_drv_gpiote.h"
    static TaskHandle_t m_task1_thread;
    SemaphoreHandle_t task1_sem;
    static void task1_thread(void * arg)
    	task1_sem = xSemaphoreCreateBinary();
    	if (NULL == task1_sem)
    	uint32_t err_code;
    	nrf_drv_gpiote_out_config_t pin_config = GPIOTE_CONFIG_OUT_SIMPLE(false);
    	err_code = nrf_drv_gpiote_out_init(LED_4, &pin_config);
    	while(1)
    		xSemaphoreTake(task1_sem, 1024);
    		nrf_drv_gpiote_out_toggle(LED_4);
    void task1_thread_init(void * p_context)
    task2.c
    #include "task2.h"
    #include "task.h"
    #include "semphr.h"
    static TaskHandle_t m_task2_thread;
    SemaphoreHandle_t task2_sem;
    static void task2_thread(void * arg)
    	task2_sem = xSemaphoreCreateBinary();
    	if (NULL == task2_sem)
    	uint32_t err_code;
    	err_code = nrf_drv_gpiote_out_init(LED_3, &pin_config);
    	while(1)
    		xSemaphoreTake(task2_sem, 512));
    		nrf_drv_gpiote_out_toggle(LED_3);
    void task2_thread_init(void * p_context)
  •  The task which is neither executing my last  in html coding program,It's not in running about Create (task1_thread, "TASK1", 128, p_context, high priority or equal priority task is executing appear under the  priority section. I have the learning option with experts at Phd dissertation writing service.
  • Hi Aryan
    Have you tested my code?
    Got the same result or work normally?
    I try to found the issue, but still not working.
  • I disabled the logs and it worked just fine. for logs , i think you need to increase the heap size.  configTOTAL_HEAP_SIZE
