Storing values using Flash-manager
Hi Team
I would like to store a simple integer value in flash and read it back after a power cycle. I already studied the library Flash-manager of the nRF5 SDK for Mesh v1.0.1. Since I found no example code this seems quite hard to do. Can you give us some example lines of code to write and read simple values to/from flash?
kind regards
Gerry
  • Hi
    I tried to implement this on the server-side of the light switch example with nrf5-SDK-for-mesh 320,
    There some strange behavior when read and write.
    I added flash manager instance and I think it disturbs the mesh flash manager instance then the program collapse.
    Does anyone succeed adding the flash manager to the server?
    Thanks.
    Does anyone have example with Mesh SDK 4.0. It seems that
    dsm_flash_area_get()
    was removed. I don't know how to handle that.
    Thank you very much
    It's working with flash_manager_recovery_page get() but after a reset I have an error ( "Data in the persistent memory was corrupted. Device starts as unprovisioned ")
    Thank you
  • Hi, I have the same problem, did you solve it?
    If so, you would have an example of the changes needed for Mesh SDK 4.0.
    Thanks in advance
1 2 3 4
