Porting nRF52 adc example to sdk 14.0
I want to start with the following nRF52 ADC example.
While doing so, I found that the example is built on SDK v13 and SDK v13 doesn't have Seggar Embedded Studio support.
I'm a Seggar Embedded studio user and I want to get it working with the same. How can I proceed?
I tried the following - Open up ble_app_uart from sdk v14 and try top integrate the following example but a lot of files and implementations have changed which didn't allow me to build the solution.
1) Is there a way where I can build my ses project for a given application with SDK V13?
2) Do I have to open up the ses project file supplied with SDK v14 and try to modify until the build is successful?
    1. As you realized, there is no support for SES in SDK 13. I'm not sure what you mean with your question, but you will not be able to build any SES projects from SDK 14 without modifications in SDK 13, as the toolchain files are not included in the SDK. There is a guide on porting projects to SES in pre-v14 SDKs here, but I do not recommend using this when you have the posibility to create the project in SDK 14 with native SES support.
    2. Yes, I would recommend to start with the base examples mentioned in the GitHub repository (ble_app_uart), and add the SAADC functionality.
    I will try to port both SAADC examples on GitHub to SDK 14 as soon as I have the available time.
    Jørgen
  • That worked! Thank you.
    Started with SDKv14 ble_app_uart example and added saadc and timer functionality in main.c. Then accordingly changed sdk_config and included timer and saadc drivers. Worked just fine! The code being almost similar made it easy.
  • Hi sprasad,
    Can you please share the files main.c and sdk_config.h? I'm dealing with the same problem...
    Thanks!
     * Copyright (c) 2014 - 2017, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_drv_saadc.h"
    #include "nrf_drv_ppi.h"
    #include "nrf_drv_timer.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_FEATURE_NOT_SUPPORTED       BLE_GATT_STATUS_ATTERR_APP_BEGIN + 2        /**< Reply when unsupported features are requested. */
    #define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_TIMEOUT_IN_SECONDS      180                                         /**< The advertising timeout (in units of seconds). */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    #define SAADC_SAMPLES_IN_BUFFER         4
    #define SAADC_SAMPLE_RATE		5000                                         /**< SAADC sample rate in ms. */
    BLE_NUS_DEF(m_nus);        /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    volatile uint8_t state = 1;
    static const nrf_drv_timer_t   m_timer = NRF_DRV_TIMER_INSTANCE(3);
    static nrf_saadc_value_t       m_buffer_pool[2][SAADC_SAMPLES_IN_BUFFER];
    static nrf_ppi_channel_t       m_ppi_channel;
    static uint32_t                m_adc_evt_counter;
    //Thermistor
    float steinhart;
    int therm_data;
    int therm_data_converted;
    bool uart_dis =0;
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_nus    Nordic UART Service structure.
     * @param[in] p_data   Data to be send to UART module.
     * @param[in] length   Length of the data.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length-1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
        uint32_t       err_code;
        ble_nus_init_t nus_init;
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        APP_ERROR_HANDLER(nrf_error);
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                NRF_LOG_INFO("Disconnected");
    #ifndef S140
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
    #if !defined (S112)
             case BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST:
                ble_gap_data_length_params_t dl_params;
                // Clearing the struct will effectivly set members to @ref BLE_GAP_DATA_LENGTH_AUTO
                memset(&dl_params, 0, sizeof(ble_gap_data_length_params_t));
                err_code = sd_ble_gap_data_length_update(p_ble_evt->evt.gap_evt.conn_handle, &dl_params, NULL);
            } break;
    #endif //!defined (S112)
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
            case BLE_EVT_USER_MEM_REQUEST:
                err_code = sd_ble_user_mem_reply(p_ble_evt->evt.gattc_evt.conn_handle, NULL);
            case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
                ble_gatts_evt_rw_authorize_request_t  req;
                ble_gatts_rw_authorize_reply_params_t auth_reply;
                req = p_ble_evt->evt.gatts_evt.params.authorize_request;
                if (req.type != BLE_GATTS_AUTHORIZE_TYPE_INVALID)
                    if ((req.request.write.op == BLE_GATTS_OP_PREP_WRITE_REQ)     ||
                        (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_NOW) ||
                        (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL))
                        if (req.type == BLE_GATTS_AUTHORIZE_TYPE_WRITE)
                            auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
                            auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_READ;
                        auth_reply.params.write.gatt_status = APP_FEATURE_NOT_SUPPORTED;
                        err_code = sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle,
        &auth_reply);
            } break; // BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        ret_code_t err_code;
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, 64);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)))
                    do
                        err_code = ble_nus_string_send(&m_nus, data_array, &length);
                        if ( (err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_BUSY) )
                    index = 0;
                NRF_UART0->TASKS_STOPRX = 1;
                uart_dis = 1;
                app_uart_flush();
                //APP_ERROR_HANDLER(p_event->data.error_communication);
            case APP_UART_FIFO_ERROR:
                uart_dis = 1;
                app_uart_flush();
                //APP_ERROR_HANDLER(p_event->data.error_code);
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .flow_control = APP_UART_FLOW_CONTROL_ENABLED,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_4800
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
    //Thermistorfunction
    int therm_data_conv(int temp_value)
      int therm_data_local;
      const int SERIESRESISTOR = 10000;
      const int NOMINAL_RESISTANCE = 10000;
      const int NOMINAL_TEMPERATURE = 25;
      float ADCvalue;
      float Resistance;
     const int BCOEFFICIENT = 3420;
      ADCvalue = temp_value;
            Resistance = (1023 / ADCvalue) - 1;
    	Resistance = SERIESRESISTOR / Resistance;
     steinhart =Resistance / NOMINAL_RESISTANCE;
     steinhart = log(steinhart);  // ln(R/Ro)
     steinhart /= BCOEFFICIENT;  // 1/B * ln(R/Ro)
     steinhart += 1.0 / (NOMINAL_TEMPERATURE + 273.15);  // + (1/To)
     steinhart = 1.0 / steinhart;  // Invert
     steinhart -= 273.15;   // convert to C
     return (int)steinhart;
    //Strain Guage function
    int strain_data_conv(int vout_strained)
      const int GAUGEFACTOR = 2;
      const int Vex = 5;
      int Voltageratio;
      const float VOut_unstrained = 0;
      int strain;
      //int16_t ADCvalue = VOut_strained;
      Voltageratio  = (vout_strained-VOut_unstrained)/Vex;
      strain = -Voltageratio/GAUGEFACTOR;
      return (int)strain;
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        init.config.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
    /**@brief Function for placing the application in low power state while waiting for events.
    static void power_manage(void)
        uint32_t err_code = sd_app_evt_wait();
    void timer_handler(nrf_timer_event_t event_type, void* p_context)
        nrf_drv_timer_config_t timer_config = NRF_DRV_TIMER_DEFAULT_CONFIG;
        timer_config.frequency = NRF_TIMER_FREQ_31250Hz;
        err_code = nrf_drv_timer_init(&m_timer, &timer_config, timer_handler);
        /* setup m_timer for compare event */
        uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer,SAADC_SAMPLE_RATE);
        nrf_drv_timer_extended_compare(&m_timer, NRF_TIMER_CC_CHANNEL0, ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);
        uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer, NRF_TIMER_CC_CHANNEL0);
        uint32_t saadc_sample_event_addr = nrf_drv_saadc_sample_task_get();
        err_code = nrf_drv_ppi_channel_assign(m_ppi_channel, timer_compare_event_addr, saadc_sample_event_addr);
            uint16_t adc_value;
            uint8_t value[SAADC_SAMPLES_IN_BUFFER*2];
            uint8_t bytes_to_send;
            // set buffers
            err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAADC_SAMPLES_IN_BUFFER);
            // print samples on hardware UART and parse data for BLE transmission
            printf("ADC event number: %d\r\n",(int)m_adc_evt_counter);
            for (int i = 0; i < SAADC_SAMPLES_IN_BUFFER; i++)
                printf("%d\r\n", p_event->data.done.p_buffer[i]);
                adc_value = p_event->data.done.p_buffer[i];
                if (i == 0)
                  //Thermistor code
                  printf("Temperature = %d\n", therm_data_conv(adc_value));
                value[i*2] = adc_value;
                value[(i*2)+1] = adc_value >> 8;
            // Send data over BLE via NUS service. Makes sure not to send more than 20 bytes.
            if((SAADC_SAMPLES_IN_BUFFER*2) <= 20)
                bytes_to_send = (SAADC_SAMPLES_IN_BUFFER*2);
                bytes_to_send = 20;
            err_code = ble_nus_string_send(&m_nus, value, bytes_to_send);
    	m_adc_evt_counter++;
    void saadc_init(void)
        nrf_drv_saadc_config_t saadc_config = NRF_DRV_SAADC_DEFAULT_CONFIG;
        saadc_config.resolution = NRF_SAADC_RESOLUTION_12BIT;
        nrf_saadc_channel_config_t channel_0_config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN4);
        channel_0_config.gain = NRF_SAADC_GAIN1_4;
        channel_0_config.reference = NRF_SAADC_REFERENCE_VDD4;
        nrf_saadc_channel_config_t channel_1_config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN5);
        channel_1_config.gain = NRF_SAADC_GAIN1_4;
        channel_1_config.reference = NRF_SAADC_REFERENCE_VDD4;
        nrf_saadc_channel_config_t channel_2_config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN6);
        channel_2_config.gain = NRF_SAADC_GAIN1_4;
        channel_2_config.reference = NRF_SAADC_REFERENCE_VDD4;
        nrf_saadc_channel_config_t channel_3_config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN7);
        channel_3_config.gain = NRF_SAADC_GAIN1_4;
        channel_3_config.reference = NRF_SAADC_REFERENCE_VDD4;
        err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback);
        err_code = nrf_drv_saadc_channel_init(0, &channel_0_config);
        err_code = nrf_drv_saadc_channel_init(1, &channel_1_config);
        err_code = nrf_drv_saadc_channel_init(2, &channel_2_config);
        err_code = nrf_drv_saadc_channel_init(3, &channel_3_config);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0],SAADC_SAMPLES_IN_BUFFER);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1],SAADC_SAMPLES_IN_BUFFER);
    void gps_data_read()
            uint8_t cr[50];
            int gps_idx = 0;
            if (uart_dis)
              NRF_UART0->TASKS_STARTRX = 1;
            while (app_uart_get(&cr[gps_idx]) != NRF_SUCCESS);
            while (cr[gps_idx] != '\r') {
              gps_idx++ ;
            printf("\rOne line end\r");
            for (int j=0; j<=gps_idx; j++) {
              printf("%c", cr[j]);
            printf("\rLine printed\r");
            gps_idx = 0;
    /**@brief Application main function.
        uint32_t err_code;
        bool     erase_bonds;
        // Initialize.
        err_code = app_timer_init();
        uart_init();
        log_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        saadc_sampling_event_init();
        saadc_init();
        printf("\r\nUART Start!\r\n");
        NRF_LOG_INFO("UART Start!");
        err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
        // Enter main loop.
        for (;;)
             // Read and print GPS data
            gps_data_read();
            UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
            power_manage();
    1768.sdk_config.h
    I have changed my code significantly after porting. These are the initial backups that I had. Hope these work fine. Let me know if you are stuck, I can help you.
