PPK.py for PPK does not ID properly the board - How do I setup PPK for measuring custom boards?
I connected via a USB cable my ppk to my computer. But when I fire up ppk.py, it says "no response from ppk. Check power, debugger connection and make sure the firmware is flashed on the ppk".
This happened after I ran ppk.py for the first time and it reminded me to upgrade certain firmware, which I did, and in the middle of upgrade, the same error message above started to appear.
What should I do next? I suspect the old firmware of the ppk board was erased but the new one did not really get mounted, however I don't know how to download any firmware or where I can find the proper firmware...
  • Hello Mitchell,
    Have you gone through the Troubleshooting tips? (like run the recover_ppk.py script)
    Here is another thread you could check out if the troubleshooting tips don't work:
    Hello I have this error: Checking installed packages pyside: 1.2.4 pyqtgraph: 0.10.0 numpy: 1.12.1 pynrfjprog: 9.0.0 Warning: The software is tested with PyQtGraph 0.9.10, and may not work with…
    By in Nordic DevZone > Nordic Q&A
