The wake on GPIO is working all the time now.
Unfortunately, I want to disable it except when needed.
Here is the scenario:
- Power up, pushbutton pin senses clicks to allow pairing or to clear pairing, depending on number of clicks.
- On timeout, I want to start SYSTEMOFF for a low power mode, with a wakeup on GPIO, it works fine:
nrf_gpio_cfg_sense_input(PIN_GPIO_WAKEUP, BUTTON_PULL, NRF_GPIO_PIN_SENSE_LOW);
// Workaround for PAN_028 rev1.1 anomaly 22 - System: Issues with disable System OFF mechanism
nrf_delay_ms(1);
NRF_POWER->SYSTEMOFF = 0x1;
- When it wakes on the GPIO Pushbutton click, I then want the pushbutton to return to working as in step 1 above. I have used several attempts, all do not disable the wake on GPIO from happening while running, eg. When I click the pushbutton it resets the CPU, and starts up again. Here are the things I have tried:
nrf_gpio_cfg_sense_set(PIN_GPIO_WAKEUP,NRF_GPIO_PIN_NOSENSE);
or
nrf_gpio_cfg_sense_input(PIN_GPIO_WAKEUP, BUTTON_PULL, NRF_GPIO_PIN_NOSENSE);
or
nrf_gpio_input_disconnect(PIN_GPIO_WAKEUP);
or
setting the wake on GPIO to another unused pin
or
nrf_gpio_cfg_input(PIO_PUSHBUTTON, NRF_GPIO_PIN_NOPULL);
Do you know of any way to disable wake on GPIO after its been setup,
so that I can use the pushbutton when the unit is running, since I don’t need to wake it up when its running ?!!
The wake on GPIO code is here:
// power down CPU in specified power mode: wakeup on GPIO (pushbutton)
nrf_gpio_cfg_sense_input(PIN_GPIO_WAKEUP, NRF_GPIO_PIN_PULLDOWN, NRF_GPIO_PIN_SENSE_HIGH);
nrf_delay_ms(1);
//on wake up code to config pins:
void setup_pw_pins()
nrf_gpio_cfg_input(PIN_GPIO_WAKEUP, NRF_GPIO_PIN_NOPULL);
//1st reset GPIO by setting cfg to: Input with the input buffer disconnected, no pull, standard drives, and pin sensing disabled
nrf_gpio_cfg_input(PIO_SEL_PIN_0, NRF_GPIO_PIN_NOPULL); //BIT0
nrf_gpio_cfg_input(PIO_SEL_PIN_1, NRF_GPIO_PIN_NOPULL); //BIT1
nrf_gpio_cfg_input(PIO_SEL_PIN_2, NRF_GPIO_PIN_NOPULL); //BIT2
nrf_gpio_cfg_input(PIO_SEL_PIN_3, NRF_GPIO_PIN_NOPULL); //BIT3
nrf_gpio_cfg_input(PIO_INTERRUPT, NRF_GPIO_PIN_NOPULL);
nrf_gpio_cfg(PIO_LED_RED, NRF_GPIO_PIN_DIR_INPUT, NRF_GPIO_PIN_INPUT_DISCONNECT, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_H0D1, NRF_GPIO_PIN_NOSENSE);
nrf_gpio_cfg(PIO_LED_BLUE, NRF_GPIO_PIN_DIR_INPUT, NRF_GPIO_PIN_INPUT_DISCONNECT, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_H0D1, NRF_GPIO_PIN_NOSENSE);
nrf_gpio_cfg_input(PIO_3V_nTX_EN, NRF_GPIO_PIN_NOPULL);
nrf_gpio_cfg_input(PIO_MUX_DISABLE, NRF_GPIO_PIN_NOPULL);
nrf_gpio_cfg_input(PIO_MUX_B, NRF_GPIO_PIN_NOPULL);
nrf_gpio_cfg_input(PIO_MUX_A, NRF_GPIO_PIN_NOPULL);
nrf_gpio_cfg_input(PIO_5V_nTX_EN, NRF_GPIO_PIN_NOPULL);
nrf_gpio_cfg_input(PIO_5V_nRX_EN, NRF_GPIO_PIN_NOPULL);
nrf_gpio_cfg_input(PIO_SUSTAIN, NRF_GPIO_PIN_NOPULL);
nrf_gpio_cfg_input(PIO_USB_EN, NRF_GPIO_PIN_NOPULL);
nrf_delay_ms(50); //settle
//2nd config as desired:
nrf_gpio_cfg_input(PIO_SEL_PIN_0, NRF_GPIO_PIN_PULLUP); //BIT0
nrf_gpio_cfg_input(PIO_SEL_PIN_1, NRF_GPIO_PIN_PULLUP); //BIT1
nrf_gpio_cfg_input(PIO_SEL_PIN_2, NRF_GPIO_PIN_PULLUP); //BIT2
nrf_gpio_cfg_input(PIO_SEL_PIN_3, NRF_GPIO_PIN_PULLUP); //BIT3
//bit 5 is battery detect
nrf_gpio_cfg(PIO_LED_RED, NRF_GPIO_PIN_DIR_OUTPUT, NRF_GPIO_PIN_INPUT_DISCONNECT, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_H0D1, NRF_GPIO_PIN_NOSENSE);
nrf_gpio_cfg(PIO_LED_BLUE, NRF_GPIO_PIN_DIR_OUTPUT, NRF_GPIO_PIN_INPUT_DISCONNECT, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_H0D1, NRF_GPIO_PIN_NOSENSE);
nrf_gpio_cfg_output(PIO_3V_nTX_EN);
nrf_gpio_cfg_output(PIO_MUX_DISABLE);
// Unlock the NFC pins as GPIO
uint32_t nfcpins = (*(uint32_t *)0x1000120C);
if (nfcpins & 1) {
nrf_nvmc_write_word(0x1000120C, 0xFFFFFFFE);
NVIC_SystemReset();
nrf_gpio_cfg_output(PIO_MUX_B);
nrf_gpio_cfg_output(PIO_MUX_A);
nrf_gpio_cfg_output(PIO_5V_nTX_EN);
nrf_gpio_cfg_output(PIO_5V_nRX_EN);
nrf_gpio_cfg_output(PIO_SUSTAIN);
nrf_gpio_cfg_output(PIO_USB_EN);
Definition:
#define PIN_GPIO_WAKEUP PIO_INTERRUPT /**< Wake up pin number. */
or
#define PIN_GPIO_WAKEUP PIO_PUSHBUTTON /**< Wake up pin number. */
