s110 connection parameters negotiation
My peripheral device connects with central one very rarely. I decided that I don't want peripheral to negotiate connection parameters with central, just use settings imposed by central. I've used function from some example:
static void conn_params_init(void){
I just commented it line with call of this function, and I don't receive BLE_GAP_EVT_CONN_PARAM_UPDATE events anymore. That would solve my problem, but after connecting and disconnecting (without any negotiations...) my device doesn't advertise anymore. I use timers to call advertising start/stop. No assert is shown on debug after that. Is it possible that interrupts stop working somehow?
  • Hi
    To not send any connection parameter update request to the central, simply don't create the timer that triggers the connection parameter update request. Do that by replacing
    return app_timer_create(&m_conn_params_timer_id, APP_TIMER_MODE_SINGLE_SHOT, update_timeout_handler);
    with
    return NRF_SUCCESS;
    in ble_conn_params_init function in the ble_conn_params.c file.
  • It turned out that was not good idea to replace the code as you said.
    My application uses other timers and while receiving events such as gap disconnect, the m_conn_params_timer_id code that wasn't removed messed up with my timer (actually it stopped it). So i just set min/max connection parameters same on central and peripheral.
  • This is the criteria that is used in ble_conn_params.c to decide if a connection parameter update request is started or not:
        // Check if interval is within the acceptable range.
        // NOTE: Using max_conn_interval in the received event data because this contains
        //       the client's connection interval.
        if (
            (p_conn_params->max_conn_interval >= m_preferred_conn_params.min_conn_interval)
            (p_conn_params->max_conn_interval <= m_preferred_conn_params.max_conn_interval)
    Therefore, the best way to avoid starting a connection parameter update request is to define the minimum m_preferred_conn_params.min_conn_interval and maximum m_preferred_conn_params.max_conn_interval allowed by the BLE standard for your peripheral device, i.e.:
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(7.5, UNIT_1_25_MS)
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(4000, UNIT_1_25_MS)
